Resource Tag Management
You can tag resources under your account for classification. This section describes how to use tags to query resources and how to modify and delete tags.
Resource tag management is related to Tag Management Service, Cost Center, and Billing Center.
- Each application supports up to 20 tags.
- It is recommended that you use the TMS predefined tag function to add the same tag to different cloud resources. For details, see Creating Predefined Tags.
Checking Resource Tags
- Click
on the left and choose Application > Application Performance Management. - In the navigation pane, choose Application Monitoring > Metrics.
- In the navigation tree on the left, click a target application and click the Resource Tag Management tab.
- Checking the tag list of the current application, as shown in the following figure.
Figure 1 Checking the tag list
Adding Resource Tags
To add a tag with the same key to all resources in the search result list, click Add Tag.
- In the navigation tree on the left, click the application to which you want to add a tag and choose Resource Tag Management > Add Tag.
Figure 2 Adding a tag
- Set tag parameters.
Figure 3 Setting tag parameters
Table 1 Tag parameters Parameter
Tag Key
- The tag key cannot be empty or start or end with a space.
- Enter 1 to 128 characters. Only letters, digits, spaces, and special characters (_.:=+-@) are allowed.
- Each tag key must be unique.
Tag Value
- Enter up to 255 characters. Only letters, digits, spaces, and special characters (_.:=+-@) are allowed.
- The resource tag value can be empty, but the predefined tag value cannot be empty.
- Click OK.
Editing Resource Tags
When you modify a tag, the modification applies only to the cloud resources that contain this tag. To modify a tag, perform the following steps:
- Click Edit in the Operation column to modify the tag content, as shown in the following figure.
- Click OK.
Deleting Resource Tags
- Click Remove in the Operation column to delete the target tag, as shown in the following figure.
- Click Yes.
