Updated on 2025-11-18 GMT+08:00
URL
This function monitors the calls of the current application by external services. It includes URL, Dubbo server, CSE server, CSEProvider cluster, and FunctionGraph monitoring. This type of monitoring item demonstrates the actual external status of the entire service. For example, if the average response time of a URL is long, it means that external users take a long time to query the corresponding data.
This section focuses on URL monitoring.
Setting the Maximum Number of Rows for Monitoring Metric Data Collection
When the number of collected metric data records of URL, Call, or SQL exceeds the default or configured value, a threshold-crossing alarm will be displayed.
You can configure Maximum number of rows for monitoring metric data collection on the URL, Call, and SQL tab pages. Take the URL page as an example. The procedure is as follows:
  1. Log in to the APM console.
  2. Click on the left and choose Management & Governance > Application Performance Management.
  3. In the navigation pane, choose Application Monitoring > Metrics.
  4. In the tree on the left, click next to the target environment. The URL tab page is displayed by default.
  5. Click Config in the alarm and change the value of Maximum number of rows for monitoring metric data collection.
  6. Click Confirm.
    • Only when the number of metric data records exceeds the default or configured value will a threshold-crossing alarm be displayed.
    • If the number of collected metric data records does not exceed the default or configured value, the value of Maximum number of rows for monitoring metric data collection cannot be configured.
    • For Maximum number of rows for monitoring metric data collection, the default value is 500. You can enter 10 to 2000.
    • If the number of collected metric data records exceeds the configured value, the system will stop metric collection to prevent excessive memory usage. The settings may take up to 5 minutes to take effect.
Going to the URL Page
  2. Click on the left and choose Application > Application Performance Management.
  4. In the tree on the left, click next to the target environment. On the URL tab page that is displayed, check URL monitoring information of all instances.
    Figure 1 Going to the URL page
  5. On the displayed URL tab page, select a target instance and monitoring item to view the monitoring data in different metric sets.
  6. Select a time range. Default: Last 20 minutes.
    Options: Last 20 minutes, Last hour, Last 3 hours, Last 6 hours, Last day, Today, Yesterday, Last week, Last month, or Custom.
  7. Click in the upper right corner of the list and select the target metric data.
  8. Click in the upper right corner of the list to export information. A maximum of 100 records can be exported.
Viewing URL Monitoring Data
URL summary
For common URL calls, the system collects the metrics of each URL. For details about the metrics, see Table 1.
Figure 2 URL summary under URL monitoring
Table 1 Parameters of the URL summary
Metric Set
Metric
URL summary
url
URL.
method
Request HTTP method.
Calls
Number of times that the URL is called.
Avg RT (ms)
Average response time of the URL in a collection period.
Errors
Number of call errors of the URL.
Max Concurrency
Maximum concurrency of the URL.
Max RT (ms)
Maximum response time of the URL in a collection period.
Apdex
Application performance index (Apdex), which indicates users' satisfaction. The value ranges from 0 to 1. The closer the value is to 1, the higher the satisfaction is.
For details, see Basic Concepts - Apdex.
Exceptions
Number of exceptions of the URL.
0 ms–10 ms
Number of requests with 0 ms–10 ms response time.
10 ms–100 ms
Number of requests with 10 ms–100 ms response time.
100 ms–500 ms
Number of requests with 100 ms–500 ms response time.
500 ms–1s
Number of requests with 500 ms–1s response time.
1s–10s
Number of requests with 1s–10s response time.
10s–n
Number of requests with response time longer than 10s.
  • URL invocation is the starting point of tracing. When you click a URL, the tracing page is displayed, showing the URL invocation condition in a certain period (default: 20 minutes).
  • You can add a URL for tracing by referring to Configuring URL Tracing.
  • Click a number in blue (such as those in the Calls or Avg RT (ms) column) to view more details.
Status code summary
APM supports status code-based summary. The system collects the metrics of each URL. For details about the metrics, see Table 2.
Table 2 Parameters of status code summary
Metric Set
Metric
Status code summary
code
Status code.
Count
Number of times that the status code occurred.
Latest URL
Sample URL which returns the status code in a collection period.
  • Click a status code in the code column. The tracing page is displayed, showing the invocation condition of the status code of the selected instance in the environment in last 20 minutes (default).
  • Click a number in the Count column to view the trend of the status code in a specified period.
  • Click the latest URL to view the invocation details of the corresponding status code.
Cluster summary
APM can summarize metrics by cluster. For details about the metrics, see Table 3.
Table 3 Parameters of the cluster summary
Metric Set
Cluster summary
Cluster ID
Cluster ID of the caller.
Calls
Number of times the cluster is called.
Avg RT (ms)
Average response time in a collection period.
Errors
Number of times that the cluster fails to be called.
Max Concurrency
Maximum concurrency of the cluster.
Max RT (ms)
Slowest call time in a collection period.
Overview
View the metric trend of the selected instance on the Overview tab page. For details about the metrics, see Table 4. When you hover over the graph, you can check the total requests, average RT (ms), errors, and Apdex in a specific time.
Table 4 Overview metrics
Metric Set
Metric
Overview
Total Requests
Total number of URL requests.
Avg RT (ms)
Average response time of the URL.
Errors
Total number of URL errors.
Apdex
Users' satisfaction with the URL.
