- What's New
Service Overview(2.0)
- What Is APM
- Functions
- Application Scenarios
- Basic Concepts
- Edition Differences
- Permissions Management
Metric Overview
- Exception
- Basic Monitoring
- C3P0 Connection Pool Monitoring
- Cassandra Monitoring
- ClickHouse Database
- DBCP Connection Pool Monitoring
- Druid Connection Pool Monitoring
- EsRestClient Monitoring
- GaussDB Database
- HBase Monitoring
- Hikari Connection Pool Monitoring
- Jetcd Monitoring
- MongoDB Monitoring
- MySQL Database
- ObsClient Monitoring
- Oracle Database
- PostgreSQL Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Communication Protocol
- Privacy and Sensitive Information Protection Statement
- Data Collection
- Usage Restrictions
- Billing
- JavaAgent Updates
- Billing(2.0)
- Getting Started(2.0)
User Guide(2.0)
- Before You Start
- Application List
- CMDB Management
Application Metric Monitoring
- Overview
- Application Monitoring Details
Application Monitoring Configuration
- Configuration Details
- Configuring the MySQL Monitoring Item
- Configuring the HttpClient Monitoring Item
- Configuring the URL Monitoring Item
- Configuring the JavaMethod Monitoring Item
- Configuring the Druid Monitoring Item
- Configuring the ApacheHttpAsyncClient Monitoring Item
- Configuring the Redis Monitoring Item
- Configuring the Jedis Monitoring Item
- Configuring the HBase Monitoring Item
- Configuring the ApacheHttpClient Monitoring Item
- Configuring the Tomcat Monitoring Item
- Configuring the EsRestClient Monitoring Item
- Configuring the WebSocket Monitoring Item
- Configuring the KafkaProducer Monitoring Item
- Configuring the Hikari Monitoring Item
- Configuring the Exception Monitoring Item
- Configuring the Thread Monitoring Item
- Configuring the GC Monitoring Item
- Configuring the JVMInfo Monitoring Item
- Configuring the JVMMonitor Monitoring Item
- Configuring ProbeInfo Monitoring Item
- Monitoring Item Views
- Instance
- Collection Status
- Component Settings
- Tracing
- Application Topology
- URL Tracing
- Resource Tag Management
- Managing Tags
- Alarm Management
- AgentAgent Management
- Configuration Management
- System Management
- Change History
API Reference(2.0)
- Before You Start
- API Overview
- Calling APIs
- Examples
APIs
APM
- Querying the application list.
- Querying the Master Address
- Obtaining the AK/SK
- Searching for Components, Environments, and Agents in a Region
- Saving a Monitoring Item
- Querying the Monitoring Item List
- Querying All Agents of an Application
- Enabling or Disabling Collection for an Instance
- Deleting an Agent
- REGION
- CMDB
VIEW
- Querying Monitoring Item Configurations
- Querying the Trace Topology
- Querying Event Details
- Querying Span Data
- Obtaining All Data of a Trace
- Obtaining the Trend Graph
- Obtaining Summary Table Data
- Obtaining the Raw Data Table
- Obtaining Raw Data Details
- Obtaining the Instance Information
- Obtaining the Monitoring Item Information
- Obtaining the Details About a Monitoring Item
- AKSK
- ALARM
- TOPOLOGY
- TRANSACTION
- TRACING
APM
- Appendix
- Change History
- Best Practices(2.0)
- FAQs(2.0)
- Service Overview(1.0)
- Getting Started(1.0)
- Best Practices(1.0)
- User Guide
- API Reference
- SDK Reference
- General FAQs
- Consultation FAQs
Usage FAQs
- How Do I Obtain the AK/SK and Project ID?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Can I Do If No Data Is Found or the Data Is Abnormal?
- How Do I Connect APM to Non-Web Programs?
- How Are Tracing Time Lines Drawn?
- How Does APM Collect Probe Data?
- How Does APM Collect Mesh Data?
- How Do I Calculate the Number of Used Instances?
- How Do I Connect the JBoss Server in Standalone Mode to APM?
- What Can I Do If I Cannot Search for Logs Based on Trace IDs?
- How Do I Deploy APM Probes in CCE Containers?
- What Can I Do If the SSH Tunnel Process Is Abnormal?
- How Can I Do If No Topology or Data Is Displayed After the ICAgent and Java Probes Are Installed?
- Why Are Tomcat Thread Metrics Not Displayed on the JVM Monitoring Page?
- Why Is the Allocated Memory Greater Than the Preset Maximum Memory on the JVM Monitoring Page?
- How Do I Determine Whether an ICAgent Has Been Bound in CCE?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
User Guide (2.0) (Kuala Lumpur Region)
Service Overview
- What Is APM
- Functions
- Basic Concepts
Metric Overview
- Metric Overview
- Exception
- Basic Monitoring
- GaussDB Database
- HBase Monitoring
- Jetcd Monitoring
- MySQL Database
- Oracle Database
- URLs
- External Calls
- Cache
- Agent Monitoring
- Tomcat Monitoring
- Message Queues
- RPC
- IoT
- Data Collection
- Getting Started
User Guide
- Before You Start
- Application List
- CMDB Management
- Overview
- Tracing
- URL Tracing
- Managing Tags
- Alarm Management
- Agent Management
- System Management
- FAQs
- Change History
Service Overview
Uninstalling the ICAgent (Linux)
If the ICAgent on a server is uninstalled, server O&M will be affected, making topology and tracing functions unavailable. Exercise caution when performing this operation.
You can uninstall the ICAgent using either of the following methods:
- Uninstalling the ICAgent Through the APM Console: The ICAgent has been successfully installed, and needs to be uninstalled.
- Uninstalling the ICAgent Through Logging In to a Server: The ICAgent fails to be installed, and needs to be uninstalled.
- Remotely Uninstalling the ICAgent: The ICAgent has been successfully installed, and needs to be remotely uninstalled.
- Uninstalling the ICAgent in Batches: The ICAgent has been successfully installed, and needs to be uninstalled in batches.
- Log in to the APM console. In the navigation pane, choose Agent > Management.
- Select Other: user-defined nodes from the drop-down list on the right of the page.
- Select one or more servers whose ICAgent is to be uninstalled, and click Uninstall ICAgent. In the Uninstall ICAgent dialog box, click Yes.
Wait for about 1 minute to complete the uninstallation. When the ICAgent status changes from Uninstalling to Uninstall, the ICAgent is successfully uninstalled.
To reinstall the ICAgent, wait for 5 minutes after it is uninstalled. Otherwise, the ICAgent may be automatically uninstalled.
- Log in to the server from which the ICAgent is to be uninstalled as the root user.
- Run the following command to uninstall the ICAgent:
bash /opt/oss/servicemgr/ICAgent/bin/manual/uninstall.sh;
- Wait until the message "ICAgent uninstall success" is displayed.
In addition to the preceding methods, you can use a method similar to Inherited Installation to remotely uninstall the ICAgent.
- Run the following command (x.x.x.x indicates the server IP address) on the server where the ICAgent has been installed:
bash /opt/oss/servicemgr/ICAgent/bin/remoteUninstall/remote_uninstall.sh -ip x.x.x.x
- Enter the password of the root user of the server where the ICAgent is to be uninstalled as prompted.
- If both the expect tool and ICAgent have been installed on a server, the ICAgent is successfully uninstalled from the remote server after the preceding command is run. If the ICAgent has been installed on a server, but the expect tool has not, enter the information as prompted.
- Ensure that the root user can run the SSH and SCP commands on the Elastic Cloud Server (ECS) server where the ICAgent has been installed to communicate with the remote ECS server where the ICAgent is to be uninstalled.
- If the message "ICAgent uninstall success" is displayed, the ICAgent is successfully uninstalled. After the ICAgent is successfully uninstalled, choose Agent > Management in the navigation pane to view the ICAgent status.
If the ICAgent has been installed on a server and the installation package ICProbeAgent.zip exists in the /opt/ICAgent/ directory of the server, use this method to uninstall the ICAgent from multiple remote ECS servers with a few clicks.
The ECS servers must belong to the same Virtual Private Cloud (VPC) and network segment.
The IP addresses and passwords of all ECS servers where the ICAgent is to be uninstalled have been collected, sorted in the iplist.cfg file, and uploaded to the /opt/ICAgent/ directory on the ECS server where the ICAgent has been installed. As shown in the following example, each IP address and password in the iplist.cfg file must be separated by a space.
192.168.0.109 password (Enter the actual password.)
192.168.0.39 password (Enter the actual password.)
- Because the iplist.cfg file contains sensitive information, you are advised to clear it in time.
- If the passwords of all servers are the same, you only need to list IP addresses in the iplist.cfg file and enter the password once during execution. If the password of an IP address is different from those of other IP addresses, you need to list both passwords and IP addresses in the iplist.cfg file.
- Run the following command on the server where the ICAgent has been installed:
bash /opt/oss/servicemgr/ICAgent/bin/remoteUninstall/remote_uninstall.sh -batchModeConfig /opt/ICAgent/iplist.cfg
Enter the default password of the root user of the servers where the ICAgent is to be uninstalled as prompted. If the passwords of all IP addresses have been configured in the iplist.cfg file, press Enter to skip this step. Otherwise, enter the default password.
batch uninstall begin Please input default passwd: send cmd to 192.168.0.109 send cmd to 192.168.0.39 2 tasks running, please wait... End of uninstall agent: 192.168.0.109 End of uninstall agent: 192.168.0.39 All hosts uninstall icagent finish.
Wait until the message "All hosts uninstall icagent finish." is displayed, which indicates that the ICAgent has been successfully uninstalled from all the hosts listed in the configuration file.
- After the ICAgent is successfully uninstalled, choose Agent > Management in the navigation pane to view the ICAgent status.
