- What's New
- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Process of Using APIG
- Creating a User and Granting APIG Permissions
- Creating a Gateway
- Opening APIs
- (Optional) Configuring Authorization for API Calling
- Calling APIs
Managing APIs
- Overview
- Viewing or Modifying API Information
- Configuring Custom API Authentication
- Configuring API Parameter Orchestration Rules
- Customizing Error Response for APIs
- Cloning an API
- Taking an API Offline
- Importing and Exporting APIs
API Design File Extension Definitions
- x-apigateway-auth-type
- x-apigateway-request-type
- x-apigateway-match-mode
- x-apigateway-cors
- x-apigateway-is-send-fg-body-base64
- x-apigateway-any-method
- x-apigateway-backend
- x-apigateway-backend.parameters
- x-apigateway-backend.httpEndpoints
- x-apigateway-backend.httpVpcEndpoints
- x-apigateway-backend.functionEndpoints
- x-apigateway-backend.mockEndpoints
- x-apigateway-backend-policies
- x-apigateway-backend-policies.conditions
- x-apigateway-ratelimit
- x-apigateway-ratelimits
- x-apigateway-ratelimits.policy
- x-apigateway-ratelimits.policy.special
- x-apigateway-access-control
- x-apigateway-access-controls
- x-apigateway-access-controls.policy
- x-apigateway-plugins
- x-apigateway-auth-opt
- x-apigateway-result-normal-sample
- x-apigateway-result-failure-sample
- x-apigateway-authorizer
- x-apigateway-response
- x-apigateway-responses
- x-apigateway-pass-through
- x-apigateway-sample
- x-apigateway-content-type
- x-apigateway-orchestrations
- Configuring API Policies
- Configuring a Credential Policy
- Managing APIG Gateways
- Viewing Metrics and Configuring Alarms
- Viewing Audit Logs
- Shared Gateway (for Existing Users)
Best Practices
- Overview
API Openness
- Selectively Exposing CCE Workloads with a Dedicated Gateway
- Selectively Exposing Service Capabilities of a Data Center Using a Dedicated Gateway
- Exposing Backend Services Across VPCs Using a Dedicated Gateway
- Routing gRPC Service Requests Using a Dedicated Gateway
- Forwarding WebSocket Service Requests Using a Dedicated Gateway
- HTTP-to-HTTPS Auto Redirection with a Dedicated Gateway
- Calling Different Backend Services Using a Dedicated Gateway
- API Authentication
- API Policies
- API Security
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
Dedicated Gateway APIs (V2)
- API Group Management
- Environment Management
- Environment Variable Management
- Request Throttling Policy Management
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API or Taking an API Offline
- Querying API Details
- Querying APIs
- Verifying the API Definition
- Debugging an API
- Publishing APIs or Taking APIs Offline
- Querying Historical Versions of an API
- Switching the Version of an API
- Querying the Runtime Definition of an API
- Querying API Version Details
- Taking an API Version Offline
- Signature Key Management
- Binding/Unbinding Signature Keys
- Binding/Unbinding Request Throttling Policies
- Excluded Request Throttling Configuration
- App Authorization Management
- Resource Query
- Domain Name Management
- Access Control Policy Management
- Binding/Unbinding Access Control Policies
- Custom Authorizer Management
- API Import and Export
VPC Channel Management
- Creating a VPC Channel
- Updating a VPC Channel
- Deleting a VPC Channel
- Querying VPC Channel Details
- Querying VPC Channels
- Adding or Updating Backend Instances
- Querying Backend Servers of a VPC Channel
- Updating Backend Instances
- Removing a Backend Server
- Enabling Backend Servers
- Disabling Backend Servers
- Modifying VPC Channel Health Check
- Adding or Updating a Backend Server Group of a VPC Channel
- Querying Backend Server Groups of a VPC Channel
- Querying a Backend Server Group of a VPC Channel
- Deleting a Backend Server Group of a VPC Channel
- Updating a Backend Server Group of a VPC Channel
- Monitoring Information Query
- Group Response Management
- Tag Management
- Gateway Feature Management
- Configuration Management
Gateway Management
- Creating a Dedicated Gateway (Pay-Per-Use)
- Querying Dedicated Gateway Details
- Updating a Dedicated Gateway
- Querying the Creation Progress of a Dedicated Gateway
- Updating or Binding an EIP to a Dedicated Gateway
- Unbinding the EIP of a Dedicated Gateway
- Enabling Public Access for a Dedicated Gateway
- Updating the Outbound Access Bandwidth of a Dedicated Gateway
- Disabling Public Access for a Dedicated Gateway
- Enabling Public Inbound Access
- Updating Public Inbound Access Bandwidth of a Gateway
- Disabling Public Inbound Access for a Gateway
- Querying AZs
- Querying Dedicated Gateways
- Deleting a Dedicated Gateway
- Modifying the Specifications of a Pay-Per-Use Gateway
- Querying Gateway Constraints
- VPC Endpoint Management
- Gateway Tag Management
- Microservice Center Management
SSL Certificate Management
- Querying SSL Certificates
- Creating an SSL Certificate
- Binding a Domain Name with SSL Certificates
- Unbinding a Domain Name's SSL Certificates
- Querying Certificate Details
- Deleting an SSL Certificate
- Modifying an SSL Certificate
- Binding an SSL Certificate to a Domain Name
- Unbinding an SSL Certificate from a Domain Name
- Querying Domain Names of an SSL Certificate
Plug-in Management
- Creating a Plug-in
- Modifying a Plug-in
- Deleting a Plug-in
- Querying Plug-ins
- Querying Plug-in Details
- Binding a Plug-in to APIs
- Binding an API with Plug-ins
- Unbinding a Plug-in from All APIs
- Unbinding an API's Plug-ins
- Querying APIs Bound with a Plug-in
- Querying Plug-ins Bound to an API
- Querying APIs to Which a Plug-in Can Be Bound
- Querying Plug-ins That Can Be Bound to an API
Credential Management
- Creating an App
- Modifying an App
- Deleting an App
- Resetting the AppSecret of an App
- Verifying an App
- Querying App Details
- Querying Apps
- Creating an AppCode
- Generating an AppCode
- Deleting an AppCode
- Querying AppCode Details
- Querying AppCodes of an App
- Querying Quotas Associated with a Credential
- Configuring Access Control Settings for an App
- Querying Access Control Details About an App
- Deleting Access Control Settings of an App
Credential Quota Management
- Creating a Credential Quota
- Querying Credential Quota Details
- Querying Credential Quotas
- Modifying a Credential Quota
- Deleting a Credential Quota
- Querying the Credentials Bound to a Specified Quota
- Binding a Credential Quota with Credentials
- Unbinding a Credential Quota from a Credential
- Querying Credentials That Can Be Bound to a Credential Quota
- Asynchronous Task Management
- Orchestration Rule Management
- Gateway Custom Inbound Port Management
Shared Gateway APIs (for Existing Users)
API Management
- Object Model
- Creating an API
- Modifying an API
- Deleting an API
- Publishing an API
- Publishing Multiple APIs or Taking Multiple APIs Offline
- Querying an API List
- Querying Historical API Versions
- Taking an Effective Version of an API Offline
- Querying Details of an API Version
- Debugging an API
- App Management
- Binding Request Throttling Policies
Binding Access Control Policies
- Object Model
- Binding an Access Control Policy to an API
- Querying the List of Access Control Policies Bound to an API
- Querying the List of APIs Bound to an Access Control Policy
- Querying the List of APIs Not Bound to an Access Control Policy
- Unbinding an Access Control Policy from an API
- Unbinding Multiple Access Control Policies from APIs
- Querying Subscription Information in KooGallery
- Resource Query
- Binding Signature Keys
- VPC Channel Management
- Querying Metrics
- OpenAPI
- Appendix
- Change History
- SDK Reference
- Common FAQs
- Product Consulting FAQs
Opening APIs
- Why Can't I Create APIs?
- How Do I Define Response Codes for an API?
- Can I Specify a Private Network Load Balancer Address for the Backend Service?
- Can I Specify the Backend Address as a Subnet IP Address?
- Does APIG Support Multiple Backend Endpoints?
- Can I Bind Private Domain Names for API Access?
- Why Do I Fail to Call an API Across Domains?
- How Do I Use APIG to Open Up Services Deployed on Huawei Cloud?
- Publishing an API
Calling APIs
- What Are the Possible Causes for an API Calling Failure?
- Why Am I Seeing the Error Message "414 Request URI too large" When I Call an API?
- Why Am I Seeing the Error Message "The API does not exist or has not been published in the environment" When I Call an API?
- Why Am I Seeing the Error Message "No backend available" When I Call an API?
- Why Am I Seeing the Error Message "Backend unavailable" or "Backend timeout" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Backend domain name resolution failed" When I Invoke the Backend Service?
- Why Am I Seeing the Error Message "Incorrect IAM authentication information" When I Call an API?
- Why Am I Seeing the Error Message "Incorrect app authentication information" When I Call an API?
- Why Doesn't Modification of the backend_timeout Parameter Take Effect?
- Does APIG Have a Limit on the Size of the API Request Body?
- Is There a Limit on the Size of the Response to an API Request?
- How Do I Call an API Using App Authentication in iOS System?
- Why Can't I Create a Header Parameter Named x-auth-token for an API Called Through IAM Authentication?
- Can Mobile Apps Call APIs?
- Can Applications Deployed in a VPC Call APIs?
- Does APIG Support WebSocket Data Transmission?
- How Will the Requests for an API with Multiple Backend Policies Be Matched and Executed?
- How Can I Access Backend Services over Public Networks Through APIG?
API Policies
- Can I Configure the Maximum Number of Concurrent Requests?
- Is the Restriction of 1,000 Requests Per Day to a Debugging Domain Name Applied to Enterprise Accounts?
- Does APIG Have Bandwidth Limits?
- Why Doesn't a Request Throttling Policy Take Effect?
- How Do I Provide an Open API to Specific Users?
- Are Client IP Addresses Verified for Access Control?
- Videos
More Documents
- Getting Started
- Comparing Versions
- Overview
API Management
- Creating an API Group
- Creating an Environment Variable
- Creating a Gateway Response
- Creating an API
- Cloning an API
- CORS
- Debugging an API
- Authorizing API Access
- Publishing an API
Importing and Exorting APIs
- Restrictions and Compatibility
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- Monitoring & Analysis
- Gateway Management
- SDKs
- Published API Calling
- Permissions Management
- Auditing
- Common FAQs
API Creation
- How Do I Specify the Host Port for a VPC Channel (or Load Balance Channel)?
- How Do I Set the Backend Address If I Will Not Use a VPC Channel (or Load Balance Channel)?
- How Can I Configure the Backend Service Address?
- What Should I Do After Applying for an Independent Domain Name?
- Why Does an API Failed to Be Called Across Domains?
API Calling
- What Should I Do If an Error Code Is Returned During API Calling?
- What Should I Do If "The API does not exist or has not been published in the environment." Is Displayed?
- Why Am I Seeing the Message "No backend available"?
- What Are the Possible Causes If the Message "Backend unavailable" or "Backend timeout" Is Displayed?
- Why Am I Seeing the Message "Backend domain name resolution failed" When a Backend Service Is Called?
- How Do I Switch the Environment for API Calling?
- What Is the Maximum Size of an API Request Package?
- How Do I Perform App Authentication in iOS System?
- App (Credential) FAQs
- Does APIG Support Persistent Connections?
API Authentication
- Does APIG Support HTTPS Two-Way Authentication?
- How Do I Call an API That Does Not Require Authentication?
- Which TLS Versions Does APIG Support?
- Does APIG Support Custom Authentication?
- Will the Request Body Be Signed for Security Authentication?
- Common Errors Related to IAM Authentication Information
- What Should I Do If the App Authentication Information Is Incorrect?
- API Control Policies
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (Kuala Lumpur Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- Appendix
- Change History
- Getting Started
- Overview
API Management
- Importing a CCE Workload
- Creating an API
- Creating a gRPC API
- Cloning an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- HTTP 2.0
- API Policies
- Credentials
- SDKs
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Developer Guide (ME-Abu Dhabi Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- Tag Management
Gateway Management
- Querying AZs
Plug-in Management
- Querying Plug-ins
- Creating an App
- Modifying an App
- Deleting an App
- Verifying an App
- Querying Apps
- This API is used to creat a credential quota.
- Appendix
- Change History
Best Practices (ME-Abu Dhabi Region)
- Developing a Custom Authorizer with FunctionGraph
- Interconnecting a Dedicated Gateway with WAF
- Request Throttling 2.0 with a Dedicated Gateway
- Two-Factor Authentication with a Dedicated Gateway
- Client Authentication with a Dedicated Gateway
- Invoking an API Policy Backend via Frontend Authentication Parameters (System Parameter)
- Forwarding WebSocket Services Using Dedicated Gateway
- Change History
- User Guide (Paris Region)
Developer Guide (Paris Region)
- Application Scenarios
- Calling APIs Through App Authentication
- Calling APIs Through IAM Authentication
- Creating Signatures for Backend Requests
- Extended Definition
- API Import Precautions
- Examples of Importing APIs
- API Export Precautions
- Change History
API Reference (Paris Region)
- Before You Start
- Calling APIs
- Getting Started
Shared Gateway APIs
API Management
- Object Model
- Registering an API
- Modifying an API
- Deleting an API
- Publishing an API
- Debugging an API
- App Management
- Object Model
- Querying Subscription Information in the Marketplace
- Resource Query
- OpenAPI
- Appendix
- Change History
Dedicated API Gateway User Guide (Paris Region)
- Getting Started
- Overview
API Management
- Creating an API
- CORS
- Debugging an API
- Publishing an API
- Importing APIs
- Exporting APIs
Extended Definition
- x-apigateway-cors
- Viewing APIs
- API Policies
- Credentials
- Auditing
- Common FAQs
API Creation
API Calling
API Authentication
- API Publishing
- API Security
- Other FAQs
- Change History
- Dedicated API Gateway Developer Guide (Paris Region)
Dedicated API Gateway API Reference (Paris Region)
- Before You Start
- Calling APIs
API Management
- Creating an API
- Modifying an API
- Deleting an API
- Querying APIs
- Debugging an API
- Resource Query
- App Management
- Tag Management
Gateway Management
- Querying AZs
- Appendix
- Change History
Circuit Breaker
Circuit breaker policies protect your backend services when a performance issue occurs. If the backend service of an API times out for N consecutive times or if the latency is long, the downgrade mechanism of a circuit breaker policy is triggered to return an error to the API caller or forward requests to a specified backend. After the backend service recovers, the circuit breaker closes and requests become normal.
If your gateway does not support this policy, submit a service ticket to upgrade the gateway to the latest version.
- An API can be bound with only one circuit breaker policy for a given environment, but each circuit breaker policy can be bound to multiple APIs.
- Policies are independent of APIs. A policy takes effect for an API only after they are bound to each other. When binding a policy to an API, you must specify an environment where the API has been published. The policy takes effect for the API only in the specified environment.
- After you bind a policy to an API, unbind the policy from the API, or update the policy, you do not need to publish the API again.
- Taking an API offline does not affect the policies bound to it. The policies are still bound to the API if the API is published again.
- Policies that have been bound to APIs cannot be deleted.
Creating a Circuit Breaker Policy
- Go to the APIG console.
- Select a dedicated gateway at the top of the navigation pane.
- In the navigation pane, choose API Management > API Policies.
- On the Policies tab, click Create Policy.
- On the Select Policy Type page, select Circuit Breaker in the Plug-ins area.
- Set the policy information based on the following table.
Table 1 Circuit breaker parameters Parameter
Name
Enter a policy name. Using naming rules facilitates future search.
It can contain 3 to 255 characters and must start with a letter. Only letters, digits, and underscores (_) are allowed.
Type
Fixed as Circuit Breaker.
Description about the plug-in. Enter 1 to 255 characters.
Policy Content
Content of the plug-in, which can be configured in a form or using a script.
Policy Type
Circuit Breaker Type
Triggering type of the circuit breaker.
- Timeout downgrade: The circuit breaker will be triggered upon backend timeout.
- Condition downgrade: The circuit breaker will be triggered when configured match conditions are met.
Condition Type
Triggering mode of the circuit breaker.
- Count: Once the number of requests that meet conditions within a specified time window reaches the threshold, the circuit breaker is immediately triggered.
- Percentage: Once the percentage of requests that meet conditions within a specified time window reaches the threshold, the circuit breaker is triggered after the time window expires.
Match Condition
This parameter is required only when Circuit Breaker Type is set to Condition downgrade.
Configure triggering conditions for the circuit breaker.
- Response Error Codes: The circuit breaker will be triggered if the backend responds with specified status codes.
- Response Latency: The circuit breaker will be triggered if the backend response latency reached a specified threshold.
Time Window (s)
The period for determining how many times have the conditions been met. Use this parameter together with Threshold or Min Percentage. If the threshold or percentage is reached, the circuit breaker is triggered.
Threshold
This parameter is required only when Condition Type is set to Count.
Set the threshold for triggering the circuit breaker. Use this parameter together with Time Window. Once the number of backend requests that meet the conditions within the time window reaches the threshold, the circuit breaker is triggered.
If the threshold is reached within the time window for a gateway component, requests sent to the component trigger the circuit breaker, and other gateway components still forward requests normally.
A circuit breaker policy is triggered for a single gateway component. If your gateway has multiple components, the triggering for each component is determined separately.
A gateway component is a connection address of your gateway. To view the number of gateway components, go to the Gateway Information page of the gateway and view the number of IP addresses in Private Network Access IP.
Min Calls
This parameter is required only when Condition Type is set to Percentage.
Set the minimum number of API calls that will trigger the circuit breaker within the time period. The circuit breaker will not be triggered if the number of API calls within the time period is less than this value.
Min Percentage (%)
Set the threshold for triggering the circuit breaker. Use this parameter together with Time Window. Once the percentage of backend requests that meet the conditions within the time window reaches the threshold, the circuit breaker is triggered.
Control Duration (s)
Time for which the circuit breaker will be on. When the time is reached, the circuit breaker will be off.
Backend Downgrade
Determine whether to enable backend downgrade.
- Enable: Requests for APIs that have triggered a downgrade will be forwarded to a specified backend.
- Disable: Requests for APIs that have triggered a downgrade will not be forwarded to any backend. Instead, HTTP status code 503 and an error message indicating that the service is unavailable will be returned.
Backend Type
This parameter is required only when Backend Downgrade is enabled.
Specify the backend type to which requests will be forwarded when the circuit breaker is on. For security purposes, do not include sensitive information in these parameters.
- Mock: The defined response will be returned.
- Status Code: the status code to be included in the response
- Response: the response body, which is in JSON format
- Response Header: header parameters to be included in the response
- HTTP&HTTPS: Backend requests will be forwarded to a specified HTTP&HTTPS backend service.
- Load Balance Channel: Determine whether to use a load balance channel to access the backend service. If yes, create a load balance channel in advance.
- Backend URL: address of the backend service to forward requests to.
- Timeout (ms): backend request timeout. The default value is 5000 ms.
- FunctionGraph: Backend requests will be forwarded to a specified function.
- Function URN: the unique identifier of a function. Click Select to select a function.
- Function Name: automatically displayed after you select a function.
- Version/Alias: version or alias of the function to be used to receive backend requests.
- Invocation Mode: the mode in which the function is invoked.
Synchronous: When receiving an invocation request, FunctionGraph immediately processes the request and returns a result. The client closes the connection once it has received a response from the backend.
Asynchronous: After receiving an invocation request, FunctionGraph queues the request and returns the result after the request is successfully processed. The server processes the queuing requests one by one when it is idle. The client does not care about the invocation result.
- Passthrough: Backend requests will be forwarded to the original API backend.
To add header parameters to backend requests, click Add Parameter.
Downgrade Parameter Settings
Determine whether to enable downgrade parameter configuration. After this option is enabled, custom rules take precedence over the default triggering conditions and downgrade settings configured above.
- If a custom rule is matched, the triggering conditions and downgrade settings defined in the rule are applied. If the matched custom rule contains no triggering condition or downgrade settings, the default settings in Trigger Configuration and Backend Downgrade will be applied.
- If no custom rule is matched, the default settings will be applied.
Parameters
Define parameters for rule matching. For security purposes, do not include sensitive information in these parameters.
- Parameter Location: position of a parameter in API requests.
- Parameter Name: name of a parameter used for rule matching.
By default, the system provides the reqPath (request path) and method (request method) parameters. Click Add Parameter to add parameters.
Rules
Customize matching rules for the circuit breaker. Click Add Rule to add rules. The system matches rules from top to bottom. Adjust the rule priority by moving the rules up or down.
- Conditions: Click
to set condition expressions. If there are three or more expressions, you can layer them by clicking Set Lower Level.
- =: equal to
- !=: not equal to
- pattern: regular expression
- enum: enumerated values. Separate them with commas (,).
- For details about how to configure the triggering conditions and backend downgrade, see the instructions for the default settings above.
Example: You have enabled Downgrade Parameter Settings and added rules rule01 and rule02 in sequence. And you have disabled Trigger Configuration and enabled Backend Downgrade for rule01, and have enabled both options for rule02. With these settings, the circuit breaker first checks whether the conditions of rule01 are met. If yes, the circuit breaker is turned on based on the default settings because no triggering condition has been defined in rule01, and backend downgrade configured in rule01 is executed. If no, the check is continued for rule02.
- Click OK.
To clone this policy, click Clone in the Operation column. The name of a cloned policy cannot be the same as that of any existing policy.
- After the policy is created, perform the operations described in Binding the Policy to APIs to apply the policy for the API.
Example Script
{ "breaker_condition":{ "breaker_type":"timeout", "breaker_mode":"counter", "unhealthy_threshold":30, "time_window":15, "open_breaker_time":15, "unhealthy_percentage":51, "min_call_threshold":20 }, "scope":"share", "downgrade_default":{ "type":"http", "passthrough_infos":null, "func_info":null, "mock_info":null, "http_info":{ "isVpc":false, "vpc_channel_id":"", "address":"10.10.10.10", "scheme":"HTTP", "method":"GET", "path":"/demo", "timeout":5000 }, "http_vpc_info":null }, "downgrade_parameters":[ { "name":"reqPath", "type":"path", "value":"path", "disabled":true, "focused":true, "id":"92002eqbpilg6g" }, { "name":"method", "type":"method", "value":"method", "disabled":true, "focused":true, "id":"tuvxetsdqvcos8" }], "downgrade_rules":[ { "rule_name":"rule-test1", "parameters":[ "reqPath", "method" ], "match_regex":"[\"reqPath\",\"==\",\"/test\"]", "downgrade_backend":{ "type":"mock", "passthrough_infos":null, "func_info":null, "mock_info":{ "status_code":200, "result_content":"{status: ok}", "headers":[] }, "http_info":null, "http_vpc_info":null }, "breaker_condition":{ "breaker_type":"timeout", "breaker_mode":"percentage", "unhealthy_threshold":30, "time_window":15, "open_breaker_time":15, "unhealthy_percentage":51, "min_call_threshold":20 } }] }
- Click the policy name to go to the policy details page.
- Select an environment and click Select APIs.
- Select the API group, environment, and required APIs.
APIs can be filtered by API name or tag. The tag is defined during API creation.
- Click OK.
- If an API no longer needs this policy, click Unbind in the row that contains the API.
- If there are multiple APIs that no longer need this policy, select these APIs, and click Unbind above the API list. You can unbind a policy from a maximum of 1000 APIs at a time.
