Help Center/
API Gateway/
User Guide/
Shared Gateway (for Existing Users)/
VPC Channel Management/
Deleting a VPC Channel
Updated on 2024-04-03 GMT+08:00
You can delete VPC channels you no longer require.
VPC channels that are currently in use by published APIs cannot be deleted.
You have created a VPC channel.
- Access the shared gateway console.
- In the navigation pane, choose API Publishing > VPC Channels.
- Delete a VPC channel. You can use one of the following methods:
- In the Operation column of the VPC channel you want to delete, click Delete.
- Click the name of the target VPC channel, and click Delete in the upper right corner of the displayed VPC channel details page.
- Click Yes.
Parent topic: VPC Channel Management
