Updated on 2025-04-01 GMT+08:00
Viewing Stack Details
- Check stack details.
   On the stack details page, you will find six function modules. (The stack named stack_20221206_0933_uiyn is used as an example here.)
- Basic Information: displays basic information about the stack, as shown in Figure 1.
 - Resources: displays information about cloud services or resources that are generated when execution plans are applied and the stack is deployed, as shown in Figure 2.
 - Events: displays information about logs that are generated when execution plans are applied and the stack is deployed. Events are updated in real time based on the stack status. For example, Figure 3 shows that three resources are created.
 - Outputs: displays output parameters in the template, as shown in Figure 4:
 - Template: displays the template content used for creating a stack, as shown in Figure 5.
 - Execution Plans: displays different execution plans. After an execution plan is generated, you need to click Deploy to create resources in the template. After an execution plan is applied, its status changes from Available to Applied and the Deploy button disappears, as shown in Execution plans.
      Figure 6 Execution plans
      Click the execution plan name. The execution plan details page is displayed, as shown in Figure 7.
   Parent topic: Getting Started
