- What's New
- Function Overview
- Service Overview (2.0)
- Billing (2.0)
- Getting Started (2.0)
User Guide (2.0)
- Using IAM to Grant Access to AOM
Connecting to AOM
- Connecting to AOM
- Managing Collector Base UniAgent
- Connecting Businesses to AOM
- Connecting Applications to AOM
Connecting Middleware and Custom Plug-ins to AOM
- Overview About Middleware and Custom Plug-in Connection to AOM
Connecting Middleware to AOM
- Ingesting MySQL Metrics to AOM
- Ingesting Redis Metrics to AOM
- Ingesting Kafka Metrics to AOM
- Ingesting Nginx Metrics to AOM
- Ingesting MongoDB Metrics to AOM
- Ingesting Consul Metrics to AOM
- Ingesting HAProxy Metrics to AOM
- Ingesting PostgreSQL Metrics to AOM
- Ingesting Elasticsearch Metrics to AOM
- Ingesting RabbitMQ Metrics to AOM
- Ingesting Other Middleware Metrics to AOM
- Connecting Custom Plug-ins to AOM
- Managing Middleware and Custom Plug-in Collection Tasks
- Connecting Running Environments to AOM
- Connecting Cloud Services to AOM
- Connecting Open-Source System to AOM
- Managing Log Ingestion
(New) Connecting to AOM
- AOM Access Overview
- Connecting Components to AOM
- Overview About Middleware Connection to AOM
- Managing Middleware Collection Tasks
- Ingesting Data to AOM Using Open-Source APIs and Protocols
- Managing Metric and Log Ingestion
- Observability Metric Browsing
- Dashboard Monitoring
- Alarm Monitoring
- (New) Log Management
- Log Management (Old)
Prometheus Monitoring
- Prometheus Monitoring Overview
- Managing Prometheus Instances
- Managing Prometheus Instance Metrics
- Using Prometheus Monitoring to Monitor CCE Cluster Metrics
- Configuring Multi-Account Aggregation for Unified Monitoring
- Configuring Metric Collection Rules for CCE Clusters
- Configuring Recording Rules to Improve Metric Query Efficiency
- Configuring Data Multi-Write to Dump Metrics to Self-Built Prometheus Instances
- Setting Metric Storage Duration
- Monitoring Prometheus Instance Metrics Through Dashboards
- Configuring the Remote Read Address to Enable Self-built Prometheus to Read Data from AOM
- Configuring the Remote Write Address to Report Self-Built Prometheus Data to AOM
- Checking Prometheus Instance Data Through Grafana
- Checking the Number of Metric Samples Reported by Prometheus Instances
- Infrastructure Monitoring
- Application Insights
- O&M Management
- Global Settings
- Querying AOM Traces
- Migrating Data from AOM 1.0 to AOM 2.0
Best Practices (2.0)
- AOM Best Practices
- Building a Comprehensive Metric System
- Alarm Noise Reduction
- Unified Metric Monitoring
- Customizing OS Images to Automatically Connect UniAgent
- Connecting Self-Built Middleware in the CCE Container Scenario
- Interconnecting Third-Party/IDC/Huawei Cloud Cross-Region Self-Built Prometheus with AOM Prometheus Instances
FAQs (2.0)
- Dashboard
- Alarm Management
- Log Analysis
- Application Monitoring
Collection Management
- Are ICAgent and UniAgent the Same?
- What Can I Do If an ICAgent Is Offline?
- Why Is an Installed ICAgent Displayed as "Abnormal" on the UniAgent Installation and Configuration Page?
- Why Can't I View the ICAgent Status After It Is Installed?
- Why Can't AOM Monitor CPU and Memory Usage After ICAgent Is Installed?
- How Do I Obtain an AK/SK?
- FAQs About UniAgent and ICAgent Installation
- How Do I Enable the Nginx stub_status Module?
- Why Does APM Metric Collection Fail?
- Why Cannot the Installation Script Be Downloaded When I Try to Install UniAgent on an ECS?
- CMDB (Unavailable Soon)
O&M Management (Unavailable Soon)
- How Can I Obtain the OBS Permission for Installing Packages?
- Why Can't Scheduled Tasks Be Triggered?
- Can I Specify Script Parameters and Hosts During Job Execution?
- Why Is a Parameter Error Displayed When I Create a Scheduled Task Using a Cron Expression?
- How Can I Set a Review for an Execution Plan?
- Why Is "delete success:{}" Displayed (Files Cannot Be Deleted) During Disk Clearance?
- What Can I Do If the Execution Plan Is Not Updated After I Modify the Job?
- What Can I Do If "agent not found" Is Displayed?
- Why Are the Hosts Listed in Execution Logs Inconsistent with Those I Configured for a Task?
- Why Did a Task Fail to Execute?
- Other FAQs
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
- Querying the Event Alarm Rule List
- Adding an Event Alarm Rule
- Modifying an Event Alarm Rule
- Deleting an Event Alarm Rule
- Querying Events and Alarms
- Counting Events and Alarms
- Reporting Events and Alarms
- Obtaining the Alarm Sending Result
- Deleting a Silence Rule
- Adding a Silence Rule
- Modifying a Silence Rule
- Obtaining the Silence Rule List
- Querying an Alarm Action Rule Based on Rule Name
- Adding an Alarm Action Rule
- Deleting an Alarm Action Rule
- Modifying an Alarm Action Rule
- Querying the Alarm Action Rule List
- Querying Metric or Event Alarm Rules
- Adding or Modifying Metric or Event Alarm Rules
- Deleting Metric or Event Alarm Rules
Monitoring
- Querying Time Series Objects
- Querying Time Series Data
- Querying Metrics
- Querying Monitoring Data
- Adding Monitoring Data
- Adding or Modifying One or More Service Discovery Rules
- Deleting a Service Discovery Rule
- Querying Existing Service Discovery Rules
- Adding a Threshold Rule
- Querying the Threshold Rule List
- Modifying a Threshold Rule
- Deleting a Threshold Rule
- Querying a Threshold Rule
- Deleting Threshold Rules in Batches
- Querying Expression Calculation Results in a Specified Period Using the GET Method
- (Recommended) Querying Expression Calculation Results in a Specified Period Using the POST Method
- Querying the Expression Calculation Result at a Specified Time Point Using the GET Method
- (Recommended) Querying Expression Calculation Results at a Specified Time Point Using the POST Method
- Querying Tag Values
- Obtaining the Tag Name List Using the GET Method
- (Recommended) Obtaining the Tag Name List Using the POST Method
- Querying Metadata
- Log
- Prometheus Instance
- Configuration Management
CMDB (AOM 2.0)
- Creating an Application
- Deleting an Application
- Querying the Details of an Application
- Modifying an Application
- Adding a Component
- Deleting a Component
- Querying the Details of a Component
- Modifying a Component
- Creating an Environment
- Deleting an Environment
- Querying the Details of an Environment
- Modifying an Environment
- Querying the Resource List of a Node
- Querying the Details of an Application Based on the Application Name
- Querying the Details of an Environment Based on the Environment Name
- Querying the Details of a Component Based on the Component Name
- Adding a Sub-application
- Deleting a Sub-application
- Modifying a Sub-application
Automation (AOM 2.0)
- Creating a Task
- Updating a Task
- Operating a Paused Task
- Obtaining the Execution Details of a Workflow
- Terminating a Task
- Querying a Script
- Querying the Script Version
- Performing Fuzzy Search on the Job Management Page
- Querying Execution Plans (Custom Templates) Based on Job ID
- Querying the Details of an Execution Plan
- Querying Tasks
- Querying the Execution History of a Task
- Executing a Workflow
Alarm
- Historical APIs
- Examples
- Appendix
- SDK Reference
Service Overview (1.0)
- What Is AOM?
- Product Architecture
- Functions
- Application Scenarios
- Edition Differences
Metric Overview
- Introduction
- Network Metrics and Dimensions
- Disk Metrics and Dimensions
- Disk Partition Metrics
- File System Metrics and Dimensions
- Host Metrics and Dimensions
- Cluster Metrics and Dimensions
- Container Metrics and Dimensions
- VM Metrics and Dimensions
- Instance Metrics and Dimensions
- Service Metrics and Dimensions
- Security
- Restrictions
- Privacy and Sensitive Information Protection Statement
- Relationships Between AOM and Other Services
- Basic Concepts
- Permissions
- Billing
- Change History
- Getting Started (1.0)
User Guide (1.0)
- Overview
- Subscribing to AOM
- Permissions Management
- Connecting Resources to AOM
- Monitoring Overview
- Alarm Management
- Resource Monitoring
- Log Management
- Resource Groups
- Auditing
- Upgrading to AOM 2.0
- Best Practices (1.0)
FAQs (1.0)
- User FAQs
Consultation FAQs
- What Is the Billing Policy of AOM?
- What Are the Usage Restrictions of AOM?
- What Are the Differences Between AOM and APM?
- How Do I Distinguish Alarms from Events?
- What Is the Relationship Between the Time Range and Statistical Cycle?
- Does AOM Display Logs in Real Time?
- Will Container Logs Be Deleted After They Are Dumped?
- How Can I Do If I Cannot Receive Any Email Notification After Configuring a Threshold Rule?
- Why Are Connection Channels Required?
Usage FAQs
- What Can I Do If I Do Not Have the Permission to Access SMN?
- What Can I Do If Resources Are Not Running Properly?
- How Do I Set the Full-Screen Online Duration?
- What Can I Do If the Log Usage Reaches 90% or Is Full?
- How Can I Check Whether a Service Is Available?
- Why Is the Status of an Alarm Rule Displayed as "Insufficient"?
- Why the Status of a Workload that Runs Normally Is Displayed as "Abnormal" on the AOM Page?
- How Do I Create the apm_admin_trust Agency?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Is the Billing Policy of Logs?
- Why Can't I See Any Logs on the Console?
- Why Can't the Host Be Monitored After ICAgent Is Installed?
- Why Is "no crontab for root" Displayed During ICAgent Installation?
- Why Can't I Select an OBS Bucket When Configuring Log Dumping on AOM?
- Why Can't Grafana Display Content?
- Videos
More Documents
User Guide (1.0) (Kuala Lumpur Region)
Service Overview
- What Is AOM?
- Functions
Metric Overview
- Introduction
- Restrictions
- Basic Concepts
- Permissions
- Getting Started
- Alarm Management
- Log Management
- Auditing
- User FAQs
Consultation FAQs
Usage FAQs
- Change History
Service Overview
User Guide (2.0) (Kuala Lumpur Region)
- Getting Started
- Introduction
- Access Center
- Dashboard
- Alarm Management
Metric Analysis
- Metric Browsing
- Resource Usage Statistics
- Log Analysis (Beta)
- Container Insights
- Process Monitoring
- Collection Management
- Remarks
- Auditing
- Overview
- Dashboard
- Alarm Management
- Log Analysis
- Why Is an Installed ICAgent Displayed as "Abnormal" on the Agent Management Page?
- FAQs About ICAgent Installation
- Other FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
Monitoring
- Querying Metrics
- Log
Alarm
- Examples
- Appendix
- Change History
- Getting Started
- User Guide
- Obtaining an AK/SK
- How Can I Do If I Do Not Have the Permission to Access SMN?
- How Do I Distinguish Alarms and Events?
- Why the Status of a Workload that Runs Normally Is Abnormal on the AOM Page?
API Reference(ME-Abu Dhabi Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Adding or Modifying One or More Application Discovery Rules
- Deleting an Application Discovery Rule
- Querying Application Discovery Rules
- Auto Scaling
- Log
Monitoring (v1)
- Appendix
User Guide (Ankara Region)
- Getting Started
- User Guide
- Why Is the Application Status Normal but the Component Status Abnormal?
- Best Practices
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Monitoring (v2)
- Auto Scaling
- Log
- Events/Alarms
- Agent
- Application Discovery Rules
- Querying Metadata
- Querying the Calculation Results of a PromQL Expression in a Specified Period Based on Prometheus Instance
- Querying the Calculation Result of a PromQL Expression at a Specified Time Point Based on Prometheus Instance
- Querying the Values of a Tag Based on Prometheus Instance
- Obtaining the Tag Name List Based on Prometheus Instance
- Querying Metadata Based on Prometheus Instance
Monitoring (v1)
- Appendix
- Change History
Managing Files
The Packages page displays all existing packages. You can create packages, and create and execute package installation and uninstallation tasks. For details about created tasks, see Managing Tasks. Each package supports up to 20 versions. Each user can create up to 1000 package versions.
Creating a Package
- Log in to the AOM 2.0 console.
- In the navigation pane, choose Automation (Retiring). The Automation page is displayed.
- In the navigation pane, choose Packages. On the displayed page, click Create Package.
- Set parameters by referring to Table 1.
Figure 1 Creating a package
Table 1 Parameters for creating a package Category
Package Name
Name of a package.
Enter up to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
Version
Version of the software. Enter the actual value.
Enterprise Project
Select the enterprise project to which the package belongs.
Timeout Duration
Timeout duration of a package installation or uninstallation task.
Storage Path
Enter the path for storing the package distributed to the ECS.
Description of the package. Enter up to 128 characters.
Source Files
OBS Region
Region where the OBS bucket resides. Select a region from the drop-down list.
OBS Bucket
OBS bucket where the package is located. Select a bucket from the drop-down list.
OBS Path
Enter the path of an OBS object. Before obtaining an OBS object, choose Settings > Access Credentials to set an access credential.
To copy an OBS object path, perform the following steps:
- Click Go to OBS and go to the Objects page.
- Select a desired object from the object list on the right and click Copy Path in the Operation column.
- If Copy Path is not directly displayed, choose More > Copy Path in the Operation column.
- If a folder is displayed in the Name column, click the folder to expand the object list, select an object, and copy the path.
Platform
Platform on which the package runs. Currently, only Linux is supported.
Operation
After the source file information is added, click Add. You can also edit or delete an added source file.
Platform
Platform on which the software runs. Currently, only Linux is supported.
Script Type
Install
Script for installing the software. Enter up to 1000 characters. Separate commands by ";", "&&", or "||".
After the input, click Check for High-Risk Commands to check the script content. High-risk commands undergo regular expression verification. If the verification fails, risks may occur. For details about high-risk commands, see Table 1.
Uninstall
Script for uninstalling software. Enter up to 1000 characters. Separate commands by ";", "&&", or "||".
Execution Policy
Batch Release
Specifies whether to enable batch release. By default, this function is disabled.
Instances for Each Batch
Number of instances on which tasks can be executed at the same time.
Interval
Interval for executing each batch of tasks.
Review
Review
Specifies whether to enable manual review. By default, this function is disabled.
You can only modify the review configuration by modifying the atomic service card in the tool market.
Reviewer
After manual review is enabled, you need to select a reviewer.
Alternatively, create a topic and add a subscription on the SMN console to notify a reviewer.
- Click Save.
Executing an Installation or Uninstallation Task
After a package is created, install or uninstall it as required. Script execution depends on the UniAgent capability. You need to ensure that the UniAgent has been installed and is running on the ECS where the script is to be executed.
- In the navigation pane, choose Packages. On the Packages page, locate the target package and click Install or Uninstall in the Operation column.
- On the package installation or uninstallation page, select an OS account from the Execution Account drop-down list.
- Select target instances.
- Click Add. The instance selection page is displayed.
- For Instance Type, the default value is ECS. For Method, the default value is Specific. For details about the methods, see Table 2.
Figure 2 Adding instances
Table 2 Selection method description Selection Method
Specific
Enter search criteria and select instances from the instance list. By default, instances are searched by name.
By filter
- Enter filter attributes and values to search for instances.
- If there are multiple filter criteria, the search is performed based on the AND relationship.
- This method also takes effect for instances added later.
By tag
- Set tag keys and values, and specify one or more tags to select instances.
- If there are multiple tags, the search is performed based on the AND relationship.
From CMDB
Enter search criteria or keywords and select instances from CMDB. There are two types of nodes:
- Static: Select an ECS under a specified CMDB application.
- Dynamic: Select a node in the CMDB application to dynamically obtain ECSs under the node. This method also takes effect for instances added later.
- Click OK.
- Click Execute. On the task execution page that is displayed, view the task execution status.
You can also click Save. The created task is displayed on the task management page for subsequent task execution or other operations.
More Operations
After a package is created, you can go to its details page and view the basic information, status, number of tasks referenced by scheduled O&M, number of tasks referenced by standard O&M, and version list of the file package. You can also perform the operations listed in Table 3.
Operation |
Description |
Creating a version |
Click Create Version in the upper right corner. |
Modifying the package information |
Click Modify in the upper right corner to modify parameters. |
Installing or uninstalling a package |
Locate the target version and click Install Package or Uninstall Package in the Operation column. |
Copying and creating a package version |
Locate the target version and click Copy and Create in the Operation column to copy the content of one version for creating another version. |
Releasing a version |
Locate the target version and click Release in the Operation column. |
Modifying a version |
Locate the target version, click Modify in the Operation column, and modify information such as the version, file source, and platform. |
Deleting a version |
Locate the target version and click Delete in the Operation column. |
