Adding an Environment
After a component is created, you can add different environments for the component based on hosts and regions for easier management.
- Log in to the AOM 2.0 console.
- In the navigation pane, choose Application Insights (Retiring) > CMDB.
- Select an enterprise project. In the navigation pane, choose Application Management.
- In the tree on the left, locate the target component and click
Figure 1 Adding an environment
- On the Add Environment page, set information such as Environment Type and OS Type.
Table 1 Parameters for adding an environment Parameter
Environment Type
Type of an environment. Options: Development, Test, Pre-release, and Production.
OS Type
OS type of a host. Options: Linux and Windows.
Environment Name
Name of an environment.
Enter 2 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Region
Region where the environment is located. Select a value from the drop-down list.
Description of the environment. Enter up to 255 characters.
A maximum of 20 environments can be created under a component.
- Click OK.
More Operations
After the environment is created, you can also perform the operations listed in Table 2.
Operation |
Description |
Editing an environment |
In the tree on the left, locate the target environment and click |
Deleting an environment |
Binding a resource |
In the tree on the left, locate the target environment. In the right pane, click any resource instance tab. In the lower pane, click Bind Resource. For details, see Binding Resources. |
Viewing environment information |
Locate an environment in the tree on the left and click Environment Info in the right pane. |
