- What's New
- Getting Started
User Guide
- Management Platform
- Developer Center
Developer Guide
Product Development
- Obtaining Development Resources
- Creating a Project and Product
- Developing a Product Model
Developing a Codec
- Development Guide
- Offline Development
- Codec Development Examples
Reference
- Message Processing Flow
- decode API Description
- Description of encode API
- getManufacturerId Interface Description
- getModel Interface Description
- Precautions on Interface Implementation
- Input/Output Format of the Codec Plug-In
- Implementation Sample Interpretation
- Appendix: Encryption Algorithms Supported by the JDK
- Developing an Application
- Developing a Device
- Self-Service Testing
- Product Release
- Device Interconnection
- Application Interconnection
SDK Usage Guide on the Device Side
LiteOS SDK Integration Development Guide
- Overview
Processfor Connecting Devices to OceanConnect on the Device Side
- Preparations
- Entrypoint Function for LiteOS SDK Device-Cloud Interconnect Components
- Initializing LiteOS SDK Device-Cloud Interconnect Components
- Creating a Data Reporting Task
- Command Processing Function for LiteOS SDK Device-Cloud Interconnect Components
- Main Function Body for LiteOS SDK Device-Cloud Interconnect Components
- Data Structure
- Appendix 1 LWM2M
SDK Usage Guide on the Application Side
Huawei IoT Platform Java SDK Usage Guide
- Before You Start
- Requirements for the Development Environment
- Downloading Related Development Resources
- Importing the Java SDK Demo
- Initializing and Configuring Certificates
- Calling Service APIs
- Implementing Callback APIs and Making, Exporting, and Uploading a Callback Certificate
- Service API Calling Process and Precautions
- Testing the SDK
Product Development
API Reference
Northbound API Reference
- Overview
- API Usage Statement
- Secure Application Access
- Device Management
- Data Collection
Subscription Management
- Subscribing to Service Data of the IoT Platform
- Subscribing to Management Data of the IoT Platform
- Querying a Subscription
- Querying Subscription in Batches
- Deleting a Subscription
- Deleting Subscriptions in Batches
Push Notification
- Pushing Device Registration Notifications
- Pushing Device Binding Notifications
- Pushing Device Information Change Notifications
- Pushing Device Data Change Notifications
- Pushing Batch Device Data Change Notifications
- Pushing Device Service Capability Change Notifications
- Pushing Device Service Capability Addition Notifications
- Pushing Device Service Capability Deletion Notifications
- Pushing Device Deletion Notifications
- Pushing Device Acknowledgment Notifications
- Pushing Device Command Response Notifications
- Pushing Command Status Change Notifications
- Pushing Rule Event Notifications
- Pushing Device Shadow Status Change Notifications
- Pushing Software Upgrade Status Change Notifications
- Pushing Software Upgrade Result Notifications
- Pushing Firmware Upgrade Status Change Notifications
- Pushing Firmware Upgrade Result Notifications
- Command Delivery
- Batch Processing
- Device Group Management
- Device Upgrade
Northbound Java SDK API Reference
- SDK Demo Architecture and Usage Guide
- SDK Initialization Configuration and Test
Service API List
- Device Management
- Batch Processing
- Subscription Management
Message Push
- Pushing Device Service Information Change Notifications
- Pushing Device Event Notifications
- Pushing Device Model Addition Notifications
- Pushing Device Model Deletion Notifications
- Pushing NB-IoT Command Status Change Notifications
- Command Delivery (NB-IoT Commands)
- Command Delivery (Non-NB-IoT Commands)
- Data Collection
Device Upgrade
- Querying a Version Package List
- Querying a Specified Version Package
- Deleting a Specified Version Package
- Creating a Software Upgrade Task
- Creating a Firmware Upgrade Task
- Querying the Result of a Specified Upgrade Task
- Querying Details About Subtasks of a Specified Upgrade Task
- Querying an Upgrade Task List
Northbound PHP SDK API Reference
Service API List
- Device Management
- Batch Processing
Message Push
- NB-IoT Device Command Status Change Notification
- Data Collection
Device Upgrade
Northbound Python SDK API Reference
Service API List
- Device Management
- Batch Processing
Message Push
- Data Collection
Device Upgrade
- AgentLite API Reference (Android)
AgentLite API Reference (C)
- Before You Start
- API Description
Common Data Structures
- ST_IOTA_DEVICE_INFO Structure
- IEs in EN_IOTA_BIND_IE_TYPE Messages
- Enumerated Values of the EN_IOTA_BIND_RESULT_TYPE Parameter
- IEs in EN_IOTA_LGN_IE_TYPE Messages
- Enumerated Values of the EN_IOTA_LGN_REASON_TYPE Parameter
- Enumerated Values of the EN_IOTA_CFG_TYPE Parameter
- IEs in EN_IOTA_HUB_IE_TYPE Messages
- Enumerated Values of the EN_IOTA_HUB_RESULT_TYPE Parameter
- IEs in EN_IOTA_DATATRANS_IE_TYPE Messages
- IEs in EN_IOTA_DEVUPDATE_IE_TYPE Messages
- Data Types
- AgentLite API Reference (Java)
- MQTT Interface Reference
- FAQs
- Specifications
- Product Use
Secondary Development
FAQs About Product Development
Profile Definition
- How to Develop a Profile
- Upload Is Unavailable When Uploading a Profile to the Developer Center
- Incorrect File Format Is Displayed When Uploading a Profile to the Developer Center
- Message Is Displayed Indicating That the Manufacturer ID and Device Model Exist When Uploading a Profile to the Developer Center
- How to Select a Data Type When Developing a Profile Online
- Profile Cannot Be Edited
Plug-In Development
- How to Develop Codecs
- Failed to Deploy a Plug-in That Is Developed Online
- What Is the Code Rule for Fields of the string and varstring Types
- What Is the Code Rule for Fields of the array and variant Types
- Whether Plug-Ins That Are Developed Online Support Transparent Transmission
- How to Use messageId During Online Codec Development
- How to Configure a Command Delivery Response During Online Codec Development
- Failed to Deploy a Plug-in That Is Developed Offline
- Failed to Upload a Plug-in That Is Developed Offline
- Plug-In Package Developed Offline Has Been Checked But Cannot Be Found When Uploading to the IoT Platform
- Codec Exception Occurs After a Plug-In Package Developed Offline That Has Been Checked Is Uploaded to the IoT Platform
- Offline Signature Fails
Device Development
- Registered Devices Cannot Connect to the IoT Platform
- Message 513 Is Reported When Devices Are Connected to the IoT Platform
- DTLS Encryption Algorithms Supported by the IoT Platform
- What Does CTNB Mean
- How to Select PSM, DRX, and eDRX
- Devices Cannot Receive Commands from the IoT Platform
- IoT Platform Does Not Receive Data Reported by Devices
- Historical Data Does Not Contain Data Reported By Devices While No Error Occurs
- Duration for Devices to Receive Commands
- Devices Fail to Receive Data Reporting Responses
- Data Reporting Is Successful at One Position But Fails at Another Position
- Command Status Is Not Changed to Successful After a Device Reports the Command Execution Result
- Whether the IoT Platform Can Switch Between the Big-Endian and Little-Endian
- Commands Fail to Be Delivered When a Device in DRX Mode Does Not Report Data in One to Two Days
Profile Definition
FAQs About Application Development
Calling APIs
- Authentication API of the IoT Platform Is Successfully Called Locally But Fails to Be Called on Application Servers
- Error Occurs When an NA Calls an API
- Online Application Simulator Fails to Deliver Commands
- Command Is Successfully Delivered Using the Simulator But Fails to Be Delivered by Calling the API
- Application Server Fails to Deliver Commands and Receives Error Code 403
- How Does an Application Server Deliver a Cache Command
- What Does an Expired Command Mean
- Does the IoT Platform Support Command Resending
- What Does a Timeout Command Mean
- Can the IoT Platform Deliver Commands in Batches
- Are the APIs of the IoT Platform Called Only Using Java
- What Are the Command States on the IoT Platform
- Failed to Call the Calling the Registering Directly Connected Devices API
- APIs Fail To Be Called After a Period of Time While Parameters Remain Unchanged
- Commands Fail to Be Sent After a Period of Time While the Previous Commands Are Successfully Sent
- Historical Data Is Not Returned When the Querying Historical Device Data API Is Called
- Devices Registered with the IoT Platform Are Deleted After a Period of Time
Subscription and Push
- Invalid Callback Address Occurs When Calling the Subscription API
- How to Obtain the subscriptionId When Calling the Querying Subscription in Batches API
- Application Server Fails to Receive Data Pushed by the IoT Platform
- How Do I Export the HTTPS Push Certificate
- Difference Between deviceDatachanged and deviceDataschanged
- How Does an Application Server Obtain the IMEI of Devices
- Application Server Receives Data But an Error Is Displayed on the IoT Platform
- Push Messages May Fail to Be Sent to Application Servers
- How Does an Application Servers Obtain The Address Used by the IoT Platform to Push Messages
- Does the IoT Platform Supports Re-push
- How Does an Application Server Receive a Command Status Change Notification
- Application Servers That Have Subscribed to Confirmation Notifications and Command Response Notifications Fail to Receive Push Messages
- Does the IoT Platform Support Only HTTPS Callback Addresses
- Can the IoT Platform Push Data Reported by Different Devices Under the Same Application to Two Servers
- Can a Subscription Address Be a Domain Name
- Can a Callback Address Be Changed
- How Do I Obtain the Callback URL When Calling the Subscription API
Calling APIs
FAQs About Software/Firmware Upgrade
- What Is Software/Firmware Upgrade
- Can IoT Platform Download Software/Firmware Packages From Third-party Servers
- Can the Target Version Be Earlier Than the Source Version?
- How Do I Obtain Software/Firmware Packages and Their Version Numbers
- Software/Firmware Upgrade Task Is Ended Immediately After Being Created
- What Is the Source Version Required for Uploading a Firmware Package on the Management Portal
- When Reporting Data, Devices Receive the Software/Firmware Version Query Command from the IoT Platform
- Are Services Interrupted During the Software/Firmware Upgrade
- What Are Common Software/Firmware Upgrade Errors
- Retry When Some Devices in the Group Failed to Be Upgraded
- Is Resumable Transmission Supported When the IoT Platform Sends Software/Firmware Packages to Devices
- Does the IoT Platform Support Device Registration in Batches
- Does the IoT Platform Perform Flow Control on Applications and Devices
- How Does an Application Server Obtain Data Reported by Devices to the IoT Platform
- Is the Maximum Number of Applications and Devices Restricted on the IoT Platform
- Why Is an Online Device Changed to an Abnormal or Offline State After a Period of Time
- Are Command Delivery and Data Reporting Successful After a Device Becomes Abnormal or Offline
- How Long Does a Device Receive an Immediately-Delivered Command in eDRX Mode
- How Long Is Data Stored on the IoT Platform
- Can Multiple Devices Use One IMEI
On this page
Show all
Firmware
Before upgrading a firmware package, upload the package to the IoT platform. The following figure shows the complete software and firmware upgrade process.
Figure 1 Software or firmware upgrade
The IoT platform automatically loads the existing firmware package and displays it on the Firmware page. You can click a firmware package to view its details and download or delete it.
- You have imported a product model by following the instructions provided in Product Models.
- You have digitally signed the firmware package by following the instructions provided in Firmware.
- You have uploaded a public key file by following the instructions provided in Public Keys.
- Choose Repository > Firmware, and click Upload on the page displayed.
- Specify the parameters, and click Save.
Parent topic: Repository
