How Do I Change the Default Boot Kernel in Ubuntu?
The operations described in this section only apply to ECSs running Ubuntu 16.04.
This operation involves modifying the GRUB configuration file. Misoperations may cause the system to fail to start. Before the operation, back up the GRUB configuration file so that it can be restored in case of misoperations.
- Assume that the desired default kernel to boot from is the third one. Open the /etc/default/grub file and change the value of GRUB_DEFAULT to "1>2", as shown in Figure 1.
- 1 in 1>2 indicates the second entry of the main menu.
- 2 in 1>2 indicates the third entry of the submenu.
- There is no space before and after the greater-than sign (>) in 1>2.
- Use a set of quotation marks to enclose 1>2.
- Run the following command to rebuild a grub configuration file:
