Help Center/ Elastic Cloud Server/ Troubleshooting/ Disk Space Management Issues/ How Do I Fix File Creation Failures Due to Inode Exhaustion?
Updated on 2025-07-30 GMT+08:00
Symptom
When you create a file or directory, you get the error message "No space left on device", "Cannot create directory", or "Couldn't create temporary archive name."
Possible Causes
In Linux, both of the following use the disk space:
  • Data
  • Inode
An inode (index node) stores metadata of a file system object, such as a file, directory, device file, socket, and pipe in the file system, but does not contain the object's data and filename.
Solution
  1. Run the following command to check the available space on the disk:
    df -h
    Figure 1 Checking the available disk space
    As shown in Figure 1, the disk still has enough available space.
  2. Run the following command to check the available inodes on the disk:
    df -i
    If the value of Use% in the command output is 100%, inodes are used up. Perform the following operations to free up inodes:
    1. Archive files in all directories.
      tar czvf /tmp/backup.tar.gz /home/data
    2. Delete unnecessary files to release inodes.
