How Can I Set the Input Method for a Windows ECS?
Symptom
You cannot switch the input method for a Windows ECS.
Possible Causes
- The ctfmon.exe process is not started.
 - The input indication icon is turned off.
Solutions to a Missing Language Bar
Solution 1: Check whether ctfmon.exe is started.
- Open C:\Windows\System32.
 - Double-click ctfmon.exe and check whether the input method editor (IME) toolbar is shown in the lower right corner and whether you can switch the input method.
- Enable the IME to automatically start upon ECS startup.
- In the Run dialog box, enter regedit and click OK to open the registry editor.
 - In the HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > Run directory, create a file named ctfmon.exe.
      Figure 1 Run directory
       - Right-click the file you created and click Modify. Change the Value data to C:\Windows\System32\ctfmon.exe.
      Figure 2 Editing the value data
       - In the Run dialog box, enter msconfig and click OK to open System Configuration.
 - Click the Startup tab, find and select C:\WINDOWS\system32\ctfmon.exe, and click Apply and then OK. Save the configurations and log out. Restart the ECS.
      Figure 3 Selecting C:\WINDOWS\system32\ctfmon.exe
Solution 2: Enable the input indication icon.
- Log in to the ECS and click Customize in the lower right corner.
    Figure 4 Clicking Customize
     - In the Notification Area Icons window, click Turn system icons on or off.
    Figure 5 Turning system icons on or off
     - Set Input Indicator to On and click OK.
    Figure 6 Turning input indicator on
Adding Another Input Language
The following uses an ECS running Windows Server 2008 as an example to describe how to add the Japanese to IME.
- Log in to the ECS and open the control panel.
 - Click Region and Language.
    Figure 7 Region and Language
     - On the Keyboards and Languages tab, click Change keyboards.
    Figure 8 Keyboards and Languages
     - Right-click the language bar and click Settings to open the Text Services and Input Languages dialog box. On the General tab, click Add.
    Figure 9 Text Services and Input Languages
     - In the Add Input Language dialog box, find and double-click Japanese (Japan) and then Keyboard.
    Figure 10 Adding an input language
     - Select Japanese and Microsoft IME. Click OK and then Apply to save the configurations.
    Figure 11 Selecting Japanese
