Updated on 2024-04-15 GMT+08:00
Exporting Monitoring Data
If you want to analyze the bandwidth or traffic usage of EIPs to locate faults, you can export EIP monitoring data.
  1. Hover on the upper left corner to display Service List and choose Management & Deployment > Cloud Eye.
  2. In the navigation pane on the left, choose Cloud Service Monitoring > Elastic IP and Bandwidth.
  3. On the Cloud Service Monitoring page, click Export Data.
  4. Configure the time range, resource type, dimension, monitored object, and metric.
  5. Click Export.
  • The first row in the exported CSV file displays the username, region, service, instance name, instance ID, metric name, metric data, time, and timestamp. You can view historical monitoring data.
  • To convert the time using a Unix timestamp to the time of the target time zone, perform the following steps:
    1. Use Excel to open a .csv file.
    2. Use the following formula to convert the time:
      Target time =[Unix timestamp/1000 + (Target time zone) x 3600]/86400 + 70 x 365 + 19
    3. Set cell format to Date.
