Supported Metrics
This section describes the namespace, list, and measurement dimensions of metrics of EIPs and bandwidths that you can check on Cloud Eye. You can use APIs or the Cloud Eye console to query the metrics of the monitored metrics and generated alarms.
Namespace
Namespace of EIPs and bandwidths: SYS.VPC
Monitoring Metrics
| ID | Name | Description | Value Range | Monitored Object | Monitoring Interval (Raw Data) |
| upstream_bandwidth | Outbound Bandwidth | Network rate of outbound traffic Unit: bit/s | ≥ 0 bit/s | Bandwidth or EIP | 1 minute |
| downstream_bandwidth | Inbound Bandwidth | Network rate of inbound traffic Unit: bit/s | ≥ 0 bit/s | Bandwidth or EIP | 1 minute |
| upstream_bandwidth_usage | Outbound Bandwidth Usage | Usage of outbound bandwidth in the unit of percent. Outbound bandwidth usage = Outbound bandwidth/Purchased bandwidth | 0% to 100% | Bandwidth or EIP | 1 minute |
| downstream_bandwidth_usage | Inbound Bandwidth Usage | Usage of inbound bandwidth in the unit of percent. Inbound bandwidth usage = Inbound bandwidth/Purchased bandwidth | 0-100% | Bandwidth or EIP | 1 minute |
| up_stream | Outbound Traffic | Network traffic going out of the cloud platform Unit: byte | ≥ 0 Bytes | Bandwidth or EIP | 1 minute |
| down_stream | Inbound Traffic | Network traffic going into the cloud platform Unit: byte | ≥ 0 Bytes | Bandwidth or EIP | 1 minute |
If a bandwidth is increased or decreased, there is a delay of 5 to 10 minutes for the monitoring metrics to update for the new bandwidth.
Dimensions
| Key | Value |
| publicip_id | EIP ID |
| bandwidth_id | Bandwidth ID |
- Query a monitoring metric:
dim.0=bandwidth_id,530cd6b0-86d7-4818-837f-935f6a27414d&dim.1=publicip_id,3773b058-5b4f-4366-9035-9bbd9964714a
- Query monitoring metrics in batches:
"name": "bandwidth_id",
"value": "530cd6b0-86d7-4818-837f-935f6a27414d"
"name": "publicip_id",
"value": "3773b058-5b4f-4366-9035-9bbd9964714a"
