Creating a Replication Policy
A replication policy allows CBR to periodically replicate backups that have not been replicated or failed to be replicated to the destination region.
When both a backup time and a replication time are configured, ensure that replication starts after backup is complete. Or, replication may fail.
- You can set replication policies for server backup vaults.
- A user can create a maximum of 32 replication policies.
- Log in to the management console. Click
in the upper left corner and select a region. - Click
and choose Storage > Cloud Backup and Recovery. - Choose Policies in the navigation pane and click the Replication Policies tab. In the upper right corner, click Create Policy. Select Replication Policy for Type.
- Set the replication policy parameters. Table 1 describes the parameters.
Table 1 Replication policy parameters Parameter
Example Value
Type
Select a policy type. In this section, we select the replication policy.
Replication policy
Name
Replication policy name You can enter a custom name or use the default name policy_xxxx.
A name can contain 1 to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
replication_policy
Status
Whether to enable the replication policy By default, this function is enabled.
CBR replicates backups and deletes expired replicas only after a replication policy is enabled and applied to vaults.
Enabled
Cross-Cloud Replication
Whether to enable cross-cloud replication.
When cross-cloud replication is enabled, the source vault can be replicated to the target cloud and data needs to be stored in a hybrid cloud 2.0 replication vault.
Replication Frequency
Select a replication frequency. By default, the replication task is executed automatically every Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, and Sunday.
- Weekly
Specifies on which days of each week the replication task will be executed. You can select multiple days.
- Day-based
Specifies the interval (every 1 to 30 days) for executing the replication task.
If you select day-based replication, the first replication is supposed to be executed on the day when the replication policy is created. If the replication policy is created after the replication time, the first replication will be executed in the next replication period.
Every day
Execution Time
Execution times of the replication policy in a day The default replication time is 22:00.
Replication tasks can be scheduled at the beginning of each hour, and you can select multiple hours.
It is recommended that replication be performed during off-peak hours or when no services are running.
00:00, 02:00
Target Cloud
This parameter is displayed only when cross-cloud replication is enabled. Select the target cloud to which the backup data is to be replicated.
Only the clouds that support replication are displayed.
Destination Region
This parameter is displayed only when cross-cloud replication are enabled. Select the region to which the backup data is to be replicated.
Only the regions that support replication will be displayed.
- If the selected region contains only one project, you can directly select the region name.
- If the selected region has multiple projects, the default project of the region is preselected. You can select another project if needed.
Cross-Cloud Replication Credential Name
This parameter is displayed only when cross-cloud replication is enabled. Select the cross-cloud replication credential created for the target cloud. If no cross-cloud replication credential has been created, create one by referring to Creating Cross-Cloud Replication Credentials.
Retention Rule
Rule that specifies how backup replicas will be retained in the destination region By default, backup replicas are retained for one month.
- Backup quantity
You can set the maximum number of backup replicas to retain for each resource. The value ranges from 2 to 99999.
- Time period
You can choose to retain backup replicas for one month, three months, six months, one year, or for any desired number (2 to 99999) of days.
- Permanent
- The system automatically deletes the earliest and expired backup replicas every other day to avoid exceeding the maximum number of backup replicas to retain or retaining any backup replica longer than the maximum retention period.
- There will be delays for CBR to delete expired backup replicas, but normally these delays will not be over 24 hours.
- The retention rules apply only to auto-generated backup replicas, but not manual ones. Manual backup replicas need to be deleted manually.
- After a backup replica is used to create an image, the replica will not be deleted by the retention rule.
6 months
- Weekly
- Click Create Now. After the replication policy is created, you can view it in the replication policy list.
- Locate the desired vault and choose More > Apply Replication Policy to apply the replication policy to the vault. Then you can view the applied policy on the vault details page.
After the policy is applied, backups will be periodically replicated to the destination vault based on the policy.
Example
A user applies a replication policy to a vault in a given region at 11:00 a.m. on Thursday. According to this policy, backups will be replicated to the destination region at 02:00 a.m. every day, and only two backup replicas will be retained. According to this vault's backup policy, two backups are automatically generated at 00:00 every day. At 12:00 p.m. on Saturday, the replication vault will contain two backup replicas, which are replicated on Saturday. Backup replicas generated at 02:00 a.m. on Friday have been automatically deleted according to the replication policy.
