log2
This function is used to return the natural logarithm of a given value with a base of 2.
Syntax
log2(DOUBLE a)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type.
If the value of a is negative, 0, or NULL, NULL is returned.
Example Code
The value NULL is returned.
select log2(null);
select log2(0);
The value 3.1699250014423126 is returned.
select log2(9);
The value 4 is returned.
select log2(16);
