log10
This function is used to return the natural logarithm of a given value with a base of 10.
Syntax
log10(DOUBLE a)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type.
![](https://support.huaweicloud.com/intl/en-us/sqlref-spark-dli/public_sys-resources/note_3.0-en-us.png)
If the value of a is negative, 0, or NULL, NULL is returned.
Example Code
The value NULL is returned.
select log10(null);
select log10(0);
The value 0.9542425094393249 is returned.
select log10(9);
The value 1 is returned.
select log10(10);
