log
Updated on 2023-10-25 GMT+08:00
This function is used to return the natural logarithm of a given base and exponent.
Syntax
log(DOUBLE base, DOUBLE a)
Parameters
Table 1 Parameters
Mandatory
Type
base
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
a
Yes
Return Values
The return value is of the DOUBLE type.
  • If the value of base or a is NULL, NULL is returned.
  • If the value of base or a is negative or 0, NULL is returned.
  • If the value of base is 1 (would cause a division by zero), NULL is returned.
Example Code
The value 2 is returned.
select log(2, 4);
The value NULL is returned.
select log(2, null);
select log(null, 4);
