locate
This function is used to return the position of substr in str. You can specify the starting position of your search using "start_pos," which starts from 1.
Syntax
locate(string <substr>, string <str>[, bigint <start_pos>])
Parameters
Parameter |
Mandatory |
Type |
Description |
str |
Yes |
STRING |
Target string to be searched for If the value is of the BIGINT, DOUBLE, DECIMAL, or DATETIME type, the value is implicitly converted to the STRING type for calculation. For other types of values, an error is reported. |
substr |
Yes |
STRING |
Substring to be matched If the value is of the BIGINT, DOUBLE, DECIMAL, or DATETIME type, the value is implicitly converted to the STRING type for calculation. For other types of values, an error is reported. |
start_pos |
No |
BIGINT |
Start position for the search |
Return Values
The return value is of the BIGINT type.
- If substr cannot be matched in str, 0 is returned.
- If the value of str or substr is NULL, NULL is returned.
- If the value of start_pos is NULL, 0 is returned.
Example Code
- Search for the position of string ab in string abhiab. An example command is as follows:
The value 1 is returned.
select locate('ab', 'abhiab');
The value 5 is returned.
select locate('ab', 'abhiab', 2);
The value 0 is returned.
select locate('ab', 'abhiab', null);
- Search for the position of string hi in string hanmeimei and lilei. An example command is as follows:
select locate('hi', 'hanmeimei and lilei');
