On this page
Show all
Spark Open Source Commands
Updated on 2024-02-07 GMT+08:00
This section describes the open source Spark SQL syntax supported by DLI. For details about the syntax, parameters, and examples, see Spark SQL Syntax.
Table 1 DLI Spark open source commands
Function
Syntax Example
DLI Spark 2.4.5
DLI Spark 3.3.1
Creating a database
CREATE DATABASE testDB;
Supported
Supported
Creating a DLI table
create table if not exists testDB.testTable1(
id int,
age int,
money double
Supported
Supported
Creating an OBS table
create table if not exists testDB.testTable2(
id int,
age int,
money double
LOCATION 'obs://bucketName/filePath'
partitioned by (dt string)
row format delimited fields terminated by ','
STORED as TEXTFILE;
Supported
Supported
Inserting test data
insert into table testDB.testTable2 values
(1, 18, 3.14, "20240101" ),
(2, 18, 3.15, "20240102" );
Supported
Supported
Changing database attributes
ALTER DATABASE testDB SET DBPROPERTIES ('Edited-by' = 'John');
Not supported
Not supported
Changing the path for storing database files on OBS
ALTER DATABASE testDB SET LOCATION 'obs://bucketName/filePath';
Not supported
Not supported
Changing a table name
ALTER TABLE testDB.testTable1 RENAME TO testDB.testTable101;
Supported
Supported
Changing the name of a partition in a table
ALTER TABLE testDB.testTable2 PARTITION ( dt='20240101') RENAME TO PARTITION ( dt='20240103');
It only supports renaming partitions of tables stored in OBS, and the storage path of the table in OBS will not change.
Supported
Supported
Adding a column
ALTER TABLE testDB.testTable1 ADD COLUMNS (name string);
Supported
Supported
Dropping a column
ALTER TABLE testDB.testTable1 DROP columns (money);
Not supported
Not supported
Changing the name of a column
ALTER TABLE testDB.testTable1 RENAME COLUMN age TO years_of_age;
Not supported
Not supported
Modifying column comments
ALTER TABLE testDB.testTable1 ALTER COLUMN age COMMENT "new comment";
Not supported
Supported
Replacing a specified column
ALTER TABLE testDB.testTable1 REPLACE COLUMNS (name string, ID int COMMENT 'new comment');
Not supported
Not supported
Customizing table attributes
ALTER TABLE testDB.testTable1 SET TBLPROPERTIES ('aaa' = 'bbb');
Supported
Supported
Adding or modifying table comments
ALTER TABLE testDB.testTable1 SET TBLPROPERTIES ('comment' = 'test');
Supported
Not supported
Changing the storage format of a table
ALTER TABLE testDB.testTable1 SET fileformat csv;
Not supported
Not supported
Deleting a table attribute
ALTER TABLE testDB.testTable1 UNSET TBLPROPERTIES ('test');
Supported
Supported
Deleting table comments
ALTER TABLE testDB.testTable1 UNSET TBLPROPERTIES ('comment');
Supported
Supported
Displaying column information
DESCRIBE database_name.table_name col_name;
Example: DESCRIBE testDB.testTable1 id;
Supported
Supported
DESCRIBE table_name table_name.col_name;
Example: DESCRIBE testTable1 testTable1.id;
It only supports viewing the column information for tables in the current database.
Supported
Supported
Returning metadata information of a query statement
DESCRIBE QUERY SELECT age, sum(age) FROM testDB.testTable1 GROUP BY age;
Not supported
Supported
Returning metadata information of inserted data
DESCRIBE QUERY VALUES(100, 10, 10000.20D) AS testTable1(id, age, money);
Not supported
Supported
Returning metadata information of a table
DESCRIBE QUERY TABLE testTable1;
Not supported
Supported
Returning metadata information of a column in a table
DESCRIBE FROM testTable1 SELECT age;
Not supported
Supported
Returning the table creation statements for a table
SHOW CREATE TABLE testDB.testTable1 AS SERDE;
When executing this statement in Spark 3.3.1, it only applies to query the table creation statements for Hive tables.
Not supported
Supported
SHOW CREATE TABLE testDB.testTable1;
Supported
Supported
