Restoring Multi-Versioning Backup Data (Deprecated, Not Recommended)
Function
The multi-versioning feature is to be deprecated and is not recommended. Recommended functions: Hudi multi-versioning cleanup and Hudi archive.
After the multiversion function is enabled, you can run the RESTORE TABLE statement to restore a table or partition of a specified version. For details about the syntax for enabling or disabling the multiversion function, see Enabling or Disabling Data Multi-Versioning (Deprecated, Not Recommended).
Currently, the multiversion function supports only OBS tables created using the Hive syntax. For details about the syntax for creating a table, see Creating an OBS Table Using the Hive Syntax.
Syntax
- Restore the non-partitioned table data to the backup data of a specified version.
RESTORE TABLE [db_name.]table_name TO VERSION 'version_id';
- Restore the data of a single partition in a partitioned table to the backup data of a specified version.
RESTORE TABLE [db_name.]table_name PARTITION (column = value, ...) TO VERSION 'version_id';
Keywords
- RESTORE TABLE: Used to restore backup data
- PARTITION: Used to specify the partition column
- TO VERSION: Used to specify the version number You can run the SHOW HISTORY command to obtain the version number. For details, see Viewing Multi-Versioning Backup Data (Deprecated, Not Recommended).
Parameters
Parameter |
Description |
db_name |
Database name, which consists of letters, digits, and underscores (_). The value cannot contain only digits or start with a digit or underscore (_). |
table_name |
Table name |
column |
Partition column name |
value |
Value corresponding to the partition column name |
version_id |
Target version of the backup data to be restored You can run the SHOW HISTORY command to obtain the version number. For details, see Viewing Multi-Versioning Backup Data (Deprecated, Not Recommended). |
Precautions
Example
- Restore the data in non-partitioned table test_table to version 20210930.
1RESTORE TABLE test_table TO VERSION '20210930';
- Restore the data of partition dt in partitioned table test_table to version 20210930.
1RESTORE TABLE test_table PARTITION (dt='2021-07-27') TO VERSION '20210930';
