Viewing All Partitions in a Specified Table
Function
This statement is used to check all partitions in a specified table.
Syntax
1 2 | SHOW PARTITIONS [db_name.]table_name [PARTITION partition_specs]; |
Keywords
- PARTITIONS: partitions in a specified table
- PARTITION: a specified partition
Parameters
| Parameter | Description |
| db_name | Database name that contains letters, digits, and underscores (_). It cannot contain only digits and cannot start with an underscore (_). |
| table_name | Table name of a database that contains letters, digits, and underscores (_). The name cannot contain only digits or start with an underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. If special characters are required, use single quotation marks ('') to enclose them. |
| partition_specs | Partition information, in the format of "key=value", where key indicates the partition field and value indicates the partition value. If a partition field contains multiple fields, the system displays all partition information that matches the partition field. |
Precautions
The table specified in this statement must exist and must be a partitioned table. Otherwise, an error is reported.
Example
- To show all partitions in the student table, run the following statement:
1SHOW PARTITIONS student;
- Check the dt='2010-10-10' partition in the student table, run the following statement:
1SHOW PARTITIONS student PARTITION(dt='2010-10-10');
