- What's New
- Function Overview
- Product Bulletin
Billing
- Billing Overview
- Billing for Compute Resources
- Billing for Storage Resources
- Billing for Scanned Data
- Package Billing
- Billing Examples
- Renewing Subscriptions
- Bills
- Arrears
- Billing Termination
Billing FAQ
- What Billing Modes Does DLI Offer?
- When Is a Data Lake Queue Idle?
- How Do I Troubleshoot DLI Billing Issues?
- Why Am I Still Being Billed on a Pay-per-Use Basis After I Purchased a Package?
- How Do I View the Usage of a Package?
- How Do I View a Job's Scanned Data Volume?
- Would a Pay-Per-Use Elastic Resource Pool Not Be Billed if No Job Is Submitted for Execution?
- Do I Need to Pay Extra Fees for Purchasing a Queue Billed Based on the Scanned Data Volume?
- How Is the Usage Beyond the Package Limit Billed?
- What Are the Actual CUs, CU Range, and Specifications of an Elastic Resource Pool?
- Change History
- Getting Started
User Guide
- DLI Job Development Process
- Preparations
Creating an Elastic Resource Pool and Queues Within It
- Overview of DLI Elastic Resource Pools and Queues
- Creating an Elastic Resource Pool and Creating Queues Within It
- Managing Elastic Resource Pools
Managing Queues
- Viewing Basic Information About a Queue
- Queue Permission Management
- Allocating a Queue to an Enterprise Project
- Creating an SMN Topic
- Managing Queue Tags
- Setting Queue Properties
- Testing Address Connectivity
- Deleting a Queue
- Auto Scaling of Standard Queues
- Setting a Scheduled Auto Scaling Task for a Standard Queue
- Changing the CIDR Block for a Standard Queue
- Example Use Case: Creating an Elastic Resource Pool and Running Jobs
- Example Use Case: Configuring Scaling Policies for Queues in an Elastic Resource Pool
- Creating a Non-Elastic Resource Pool Queue (Discarded and Not Recommended)
- Creating Databases and Tables
Data Migration and Transmission
- Overview
Migrating Data from External Data Sources to DLI
- Overview of Data Migration Scenarios
- Using CDM to Migrate Data to DLI
- Example Typical Scenario: Migrating Data from Hive to DLI
- Example Typical Scenario: Migrating Data from Kafka to DLI
- Example Typical Scenario: Migrating Data from Elasticsearch to DLI
- Example Typical Scenario: Migrating Data from RDS to DLI
- Example Typical Scenario: Migrating Data from GaussDB(DWS) to DLI
Configuring DLI to Read and Write Data from and to External Data Sources
- Configuring DLI to Read and Write External Data Sources
- Configuring the Network Connection Between DLI and Data Sources (Enhanced Datasource Connection)
- Using DEW to Manage Access Credentials for Data Sources
- Using DLI Datasource Authentication to Manage Access Credentials for Data Sources
Managing Enhanced Datasource Connections
- Viewing Basic Information About an Enhanced Datasource Connection
- Enhanced Connection Permission Management
- Binding an Enhanced Datasource Connection to an Elastic Resource Pool
- Unbinding an Enhanced Datasource Connection from an Elastic Resource Pool
- Adding a Route for an Enhanced Datasource Connection
- Deleting the Route for an Enhanced Datasource Connection
- Modifying Host Information in an Elastic Resource Pool
- Enhanced Datasource Connection Tag Management
- Deleting an Enhanced Datasource Connection
- Example Typical Scenario: Connecting DLI to a Data Source on a Private Network
- Example Typical Scenario: Connecting DLI to a Data Source on a Public Network
- Configuring an Agency to Allow DLI to Access Other Cloud Services
- Submitting a SQL Job Using DLI
- Submitting a Flink Job Using DLI
- Submitting a Spark Job Using DLI
- Submitting a DLI Job Using a Notebook Instance
- Using Cloud Eye to Monitor DLI
- Using CTS to Audit DLI
- Permissions Management
- Common DLI Management Operations
Best Practices
- Overview
- Analyzing Driving Behavior Data in IoV Scenarios Using DLI
- Converting Data Format from CSV to Parquet
- Analyzing E-Commerce BI Reports Using DLI
- Analyzing Billing Consumption Data Using DLI
- Analyzing Real-time E-Commerce Business Data Using DLI
Connecting BI Tools to DLI for Data Analysis
- Overview
- Configuring DBeaver to Connect to DLI for Data Query and Analysis
- Configuring DBT to Connect to DLI for Data Scheduling and Analysis
- Configuring Yonghong BI to Connect to DLI for Data Query and Analysis
- Configuring Superset to Connect to DLI for Data Query and Analysis
- Configuring Power BI to Connect to DLI Using Kyuubi for Data Query and Analysis
- Configuring FineBI to Connect to DLI Using Kyuubi for Data Query and Analysis
- Configuring Tableau to Connect to DLI Using Kyuubi for Data Query and Analysis
- Configuring Beeline to Connect to DLI Using Kyuubi for Data Query and Analysis
Developer Guide
- Connecting to DLI Using a Client
- SQL Jobs
Flink Jobs
- Stream Ecosystem
Flink OpenSource SQL Jobs
- Reading Data from Kafka and Writing Data to RDS
- Reading Data from Kafka and Writing Data to GaussDB(DWS)
- Reading Data from Kafka and Writing Data to Elasticsearch
- Reading Data from MySQL CDC and Writing Data to GaussDB(DWS)
- Reading Data from PostgreSQL CDC and Writing Data to GaussDB(DWS)
- Configuring High-Reliability Flink Jobs (Automatic Restart upon Exceptions)
- Flink Jar Job Examples
- Writing Data to OBS Using Flink Jar
- Using Flink Jar to Connect to Kafka that Uses SASL_SSL Authentication
- Using Flink Jar to Read and Write Data from and to DIS
- Flink Job Agencies
Spark Jar Jobs
- Using Spark Jar Jobs to Read and Query OBS Data
- Using the Spark Job to Access DLI Metadata
- Using Spark Jobs to Access Data Sources of Datasource Connections
- Spark Jar Jobs Using DEW to Acquire Access Credentials for Reading and Writing Data from and to OBS
- Obtaining Temporary Credentials from a Spark Job's Agency for Accessing Other Cloud Services
SQL Syntax Reference
Spark SQL Syntax Reference
- Common Configuration Items
- Spark SQL Syntax
- Spark Open Source Commands
- Databases
Tables
- Creating an OBS Table
- Creating a DLI Table
- Deleting a Table
- Viewing a Table
- Modifying a Table
Partition-related Syntax
- Adding Partition Data (Only OBS Tables Supported)
- Renaming a Partition (Only OBS Tables Supported)
- Deleting a Partition
- Deleting Partitions by Specifying Filter Criteria (Only Supported on OBS Tables)
- Altering the Partition Location of a Table (Only OBS Tables Supported)
- Updating Partitioned Table Data (Only OBS Tables Supported)
- Updating Table Metadata with REFRESH TABLE
- Backing Up and Restoring Data of Multiple Versions
- Table Lifecycle Management
- Data
- Exporting Query Results
- Creating a Datasource Connection with an HBase Table
- Creating a Datasource Connection with an OpenTSDB Table
- Creating a Datasource Connection with a DWS Table
- Creating a Datasource Connection with an RDS Table
- Creating a Datasource Connection with a CSS Table
- Creating a Datasource Connection with a DCS Table
- Creating a Datasource Connection with a DDS Table
- Creating a Datasource Connection with an Oracle Table
- Views
- Viewing the Execution Plan
- Data Permissions
- Data Types
- User-Defined Functions
Built-In Functions
Date Functions
- Overview
- add_months
- current_date
- current_timestamp
- date_add
- dateadd
- date_sub
- date_format
- datediff
- datediff1
- datepart
- datetrunc
- day/dayofmonth
- from_unixtime
- from_utc_timestamp
- getdate
- hour
- isdate
- last_day
- lastday
- minute
- month
- months_between
- next_day
- quarter
- second
- to_char
- to_date
- to_date1
- to_utc_timestamp
- trunc
- unix_timestamp
- weekday
- weekofyear
- year
String Functions
- Overview
- ascii
- concat
- concat_ws
- char_matchcount
- encode
- find_in_set
- get_json_object
- instr
- instr1
- initcap
- keyvalue
- length
- lengthb
- levenshtein
- locate
- lower/lcase
- lpad
- ltrim
- parse_url
- printf
- regexp_count
- regexp_extract
- replace
- regexp_replace
- regexp_replace1
- regexp_instr
- regexp_substr
- repeat
- reverse
- rpad
- rtrim
- soundex
- space
- substr/substring
- substring_index
- split_part
- translate
- trim
- upper/ucase
- Mathematical Functions
- Aggregate Functions
- Window Functions
- Other Functions
Date Functions
- SELECT
Identifiers
- aggregate_func
- alias
- attr_expr
- attr_expr_list
- attrs_value_set_expr
- boolean_expression
- class_name
- col
- col_comment
- col_name
- col_name_list
- condition
- condition_list
- cte_name
- data_type
- db_comment
- db_name
- else_result_expression
- file_format
- file_path
- function_name
- groupby_expression
- having_condition
- hdfs_path
- input_expression
- input_format_classname
- jar_path
- join_condition
- non_equi_join_condition
- number
- num_buckets
- output_format_classname
- partition_col_name
- partition_col_value
- partition_specs
- property_name
- property_value
- regex_expression
- result_expression
- row_format
- select_statement
- separator
- serde_name
- sql_containing_cte_name
- sub_query
- table_comment
- table_name
- table_properties
- table_reference
- view_name
- view_properties
- when_expression
- where_condition
- window_function
- Operators
Flink SQL Syntax Reference
Flink OpenSource SQL 1.15 Syntax Reference
- Constraints and Definitions
- Overview
- Flink OpenSource SQL 1.15 Usage
- Formats
- Connectors
- DML Snytax
Functions
- UDFs
- Type Inference
- Parameter Transfer
Built-In Functions
- Comparison Functions
- Logical Functions
- Arithmetic Functions
- String Functions
- Temporal Functions
- Conditional Functions
- Type Conversion Functions
- Collection Functions
- JSON Functions
- Value Construction Functions
- Value Retrieval Functions
- Grouping Functions
- Hash Functions
- Table-Valued Functions
- Flink OpenSource SQL 1.12 Syntax Reference
Flink Opensource SQL 1.10 Syntax Reference
- Flink OpenSource SQL 1.10 Syntax
Data Definition Language (DDL)
- Creating a Source Table
Creating a Result Table
- ClickHouse Result Table
- Kafka Result Table
- Upsert Kafka Result Table
- DIS Result Table
- JDBC Result Table
- GaussDB(DWS) Result Table
- Redis Result Table
- SMN Result Table
- HBase Result Table
- Elasticsearch Result Table
- OpenTSDB Result Table
- User-defined Result Table
- Print Result Table
- File System Result Table
- Creating a Dimension Table
- Data Manipulation Language (DML)
- Functions
HetuEngine SQL Syntax Reference
- Before You Start
- Data Type
DDL Syntax
- CREATE SCHEMA
- CREATE TABLE
- CREATE TABLE AS
- CREATE TABLE LIKE
- CREATE VIEW
- ALTER TABLE
- ALTER VIEW
- ALTER SCHEMA
- DROP SCHEMA
- DROP TABLE
- DROP VIEW
- TRUNCATE TABLE
- COMMENT
- VALUES
- SHOW Syntax Overview
- SHOW SCHEMAS (DATABASES)
- SHOW TABLES
- SHOW TBLPROPERTIES TABLE|VIEW
- SHOW TABLE/PARTITION EXTENDED
- SHOW FUNCTIONS
- SHOW PARTITIONS
- SHOW COLUMNS
- SHOW CREATE TABLE
- SHOW VIEWS
- SHOW CREATE VIEW
- DML Syntax
- DQL Syntax
- Auxiliary Command Syntax
- Reserved Keywords
SQL Functions and Operators
- Logical Operators
- Comparison Functions and Operators
- Condition Expression
- Lambda Expression
- Conversion Functions
- Mathematical Functions and Operators
- Bitwise Functions
- Decimal Functions and Operators
- String Functions and Operators
- Regular Expressions
- Binary Functions and Operators
- JSON Functions and Operators
- Date and Time Functions and Operators
- Window Functions
- Array Functions and Operators
- Map Functions and Operators
- URL Function
- UUID Function
- Color Function
- Teradata Function
- Data Masking Functions
- IP Address Functions
- Quantile Digest Functions
- T-Digest Functions
- Implicit Data Type Conversion
- Appendix
Hudi SQL Syntax Reference
- Hudi Table Overview
- DLI Hudi Metadata
- DLI Hudi Development Specifications
- Using Hudi to Develop Jobs in DLI
- DLI Hudi SQL Syntax Reference
- Spark DataSource API Syntax Reference
- Data Management and Maintenance
- Typical Hudi Configuration Parameters
- Delta SQL Syntax Reference
API Reference
- Before You Start
- Overview
- Calling APIs
- Getting Started
- Permission-related APIs
- Global Variable-related APIs
- APIs Related to Resource Tags
APIs Related to Enhanced Datasource Connections
- Creating an Enhanced Datasource Connection
- Listing Enhanced Datasource Connections
- Querying an Enhanced Datasource Connection
- Binding a Queue
- Unbinding a Queue
- Querying Authorization of an Enhanced Datasource Connection
- Creating a Route
- Deleting a Route
- Datasource Authentication-related APIs
APIs Related to Elastic Resource Pools
- Querying All Elastic Resource Pools
- Deleting an Elastic Resource Pool
- Modifying Elastic Resource Pool Information
- Querying All Queues in an Elastic Resource Pool
- Associating a Queue with an Elastic Resource Pool
- Viewing Scaling History of an Elastic Resource Pool
- Modifying the Scaling Policy of a Queue Associated with an Elastic Resource Pool
- Queue-related APIs (Recommended)
- SQL Job-related APIs
- SQL Template-related APIs
Flink Job-related APIs
- Creating a SQL Job
- Updating a SQL Job
- Creating a Flink Jar job
- Updating a Flink Jar Job
- Running Jobs in Batches
- Listing Jobs
- Querying Job Details
- Querying the Job Execution Plan
- Stopping Jobs in Batches
- Deleting a Job
- Deleting Jobs in Batches
- Exporting a Flink Job
- Importing a Flink Job
- Generating a Static Stream Graph for a Flink SQL Job
- APIs Related to Flink Job Templates
- Flink Job Management APIs
- Spark Job-related APIs
- APIs Related to Spark Job Templates
Out-of-Date APIs
- Agency-related APIs (Discarded)
Package Group-related APIs (Discarded)
- Uploading a Package Group (Discarded)
- Listing Package Groups (Discarded)
- Uploading a JAR Package Group (Discarded)
- Uploading a PyFile Package Group (Discarded)
- Uploading a File Package Group (Discarded)
- Querying Resource Packages in a Group (Discarded)
- Deleting a Resource Package from a Group (Discarded)
- Changing the Owner of a Group or Resource Package (Discarded)
- APIs Related to Spark Batch Processing (Discarded)
- SQL Job-related APIs (Discarded)
- Resource-related APIs (Discarded)
- Permission-related APIs (Discarded)
- Queue-related APIs (Discarded)
- Datasource Authentication-related APIs (Discarded)
- APIs Related to Enhanced Datasource Connections (Discarded)
- Template-related APIs (Discarded)
- Table-related APIs (Discarded)
- APIs Related to SQL Jobs (Discarded)
- APIs Related to Data Upload (Discarded)
- Cluster-related APIs
- APIs Related to Flink Jobs (Discarded)
- Public Parameters
- SDK Reference
DLI Basics
- What Are the Differences Between DLI Flink and MRS Flink?
- What Are the Differences Between MRS Spark and DLI Spark?
- How Do I Upgrade the Engine Version of a DLI Job?
- Where Can Data Be Stored in DLI?
- Can I Import OBS Bucket Data Shared by Other Tenants into DLI?
- Regions and AZs
- Can a Member Account Use Global Variables Created by Other Member Accounts?
- Is DLI Affected by the Apache Spark Command Injection Vulnerability (CVE-2022-33891)?
- How Do I Manage Jobs Running on DLI?
- How Do I Change the Field Names of an Existing Table on DLI?
- How Can I Check the Actual and Used CUs for an Elastic Resource Pool as Well as the Required CUs for a Job?
- How Do I Check for a Backlog of Jobs in the Current DLI Queue?
- How Do I View the Load of a DLI Queue?
- How Do I Monitor Job Exceptions on a DLI Queue?
- How Do I Migrate an Old Version Spark Queue to a General-Purpose Queue?
- How Do I Do If I Encounter a Timeout Exception When Executing DLI SQL Statements on the default Queue?
DLI Databases and Tables
- Why Am I Unable to Query a Table on the DLI Console?
- How Do I Do If the Compression Rate of an OBS Table Is High?
- How Do I Do If Inconsistent Character Encoding Leads to Garbled Characters?
- Do I Need to to Regrant Permissions to Users and Projects After Deleting and Recreating a Table With the Same Name?
- How Do I Do If Files Imported Into a DLI Partitioned Table Lack Data for the Partition Columns, Causing Query Failures After the Import Is Completed?
- How Do I Fix Incorrect Data in an OBS Foreign Table Caused by Newline Characters in OBS File Fields?
- How Do I Prevent a Cartesian Product Query and Resource Overload Due to Missing "ON" Conditions in Table Joins?
- How Do I Do If I Can't Query Data After Manually Adding It to the Partition Directory of an OBS Table?
- Why Does the "insert overwrite" Operation Affect All Data in a Partitioned Table Instead of Just the Targeted Partition?
- Why Does the "create_date" Field in an RDS Table (Datetime Data Type) Appear as a Timestamp in DLI Queries?
- How Do I Do If Renaming a Table After a SQL Job Causes Incorrect Data Size?
- How Can I Resolve Data Inconsistencies When Importing Data from DLI to OBS?
- How Do I Do If I Can't Bind an Enhanced Datasource Connection to a Queue?
- How Do I Resolve a Failure in Connecting DLI to GaussDB(DWS) Through an Enhanced Datasource Connection?
- How Do I Do If the Datasource Connection Is Successfully Created but the Network Connectivity Test Fails?
- How Do I Configure Network Connectivity Between a DLI Queue and a Data Source?
- Why Is Creating a VPC Peering Connection Necessary for Enhanced Datasource Connections in DLI?
- How Do I Do If Creating a Datasource Connection in DLI Gets Stuck in the "Creating" State When Binding It to a Queue?
- How Do I Resolve the "communication link failure" Error When Using a Newly Created Datasource Connection That Appears to Be Activated?
- How Do I Troubleshoot a Connection Timeout Issue That Isn't Recorded in Logs When Accessing MRS HBase Through a Datasource Connection?
- How Do I Fix the "Failed to get subnet" Error When Creating a Datasource Connection in DLI?
- How Do I Do If I Encounter the "Incorrect string value" Error When Executing insert overwrite on a Datasource RDS Table?
- How Do I Resolve the Null Pointer Error When Creating an RDS Datasource Table?
- Error Message "org.postgresql.util.PSQLException: ERROR: tuple concurrently updated" Is Displayed When the System Executes insert overwrite on a Datasource GaussDB(DWS) Table
- RegionTooBusyException Is Reported When Data Is Imported to a CloudTable HBase Table Through a Datasource Table
- How Do I Do If A Null Value Is Written Into a Non-Null Field When Using a DLI Datasource Connection to Connect to a GaussDB(DWS) Table?
- How Do I Do If an Insert Operation Failed After the Schema of the GaussDB(DWS) Source Table Is Updated?
- How Do I Insert Data into an RDS Table with an Auto-Increment Primary Key Using DLI?
SQL Jobs
SQL Job Development
- SQL Jobs
- How Do I Merge Small Files?
- How Do I Use DLI to Access Data in an OBS Bucket?
- How Do I Specify an OBS Path When Creating an OBS Table?
- How Do I Create a Table Using JSON Data in an OBS Bucket?
- How Can I Use the count Function to Perform Aggregation?
- How Do I Synchronize DLI Table Data Across Regions?
- How Do I Insert Table Data into Specific Fields of a Table Using a SQL Job?
- How Do I Troubleshoot Slow SQL Jobs?
- How Do I View DLI SQL Logs?
- How Do I View SQL Execution Records in DLI?
- How Do I Do When Data Skew Occurs During the Execution of a SQL Job?
- Why Does a SQL Job That Has Join Operations Stay in the Running State?
- Why Is a SQL Job Stuck in the Submitting State?
SQL Job O&M
- Why Is Error "path obs://xxx already exists" Reported When Data Is Exported to OBS?
- Why Is Error "SQL_ANALYSIS_ERROR: Reference 't.id' is ambiguous, could be: t.id, t.id.;" Displayed When Two Tables Are Joined?
- Why Is Error "The current account does not have permission to perform this operation,the current account was restricted. Restricted for no budget." Reported when a SQL Statement Is Executed?
- Why Is Error "There should be at least one partition pruning predicate on partitioned table XX.YYY" Reported When a Query Statement Is Executed?
- Why Is Error "IllegalArgumentException: Buffer size too small. size" Reported When Data Is Loaded to an OBS Foreign Table?
- Why Is Error "DLI.0002 FileNotFoundException" Reported During SQL Job Running?
- Why Is a Schema Parsing Error Reported When I Create a Hive Table Using CTAS?
- Why Is Error "org.apache.hadoop.fs.obs.OBSIOException" Reported When I Run DLI SQL Scripts on DataArts Studio?
- Why Is Error "UQUERY_CONNECTOR_0001:Invoke DLI service api failed" Reported in the Job Log When I Use CDM to Migrate Data to DLI?
- Why Is Error "File not Found" Reported When I Access a SQL Job?
- Why Is Error "DLI.0003: AccessControlException XXX" Reported When I Access a SQL Job?
- Why Is Error "DLI.0001: org.apache.hadoop.security.AccessControlException: verifyBucketExists on {{bucket name}}: status [403]" Reported When I Access a SQL Job?
- Why Am I Seeing the Error Message "The current account does not have permission to perform this operation,the current account was restricted. Restricted for no budget" When Executing a SQL Statement?
SQL Job Development
Flink Jobs
Flink Job Consulting
- How Do I Authorize a Subuser to View Flink Jobs?
- How Do I Configure Auto Restart upon Exception for a Flink Job?
- How Do I Save Logs for Flink Jobs?
- Why Is Error "No such user. userName:xxxx." Reported on the Flink Job Management Page When I Grant Permission to a User?
- How Do I Restore a Flink Job from a Specific Checkpoint After Manually Stopping the Job?
- Why Is a Message Displayed Indicating That the SMN Topic Does Not Exist When I Use the SMN Topic in DLI?
Flink SQL Jobs
- How Do I Map an OBS Table to a DLI Partitioned Table?
- How Do I Change the Number of Kafka Partitions in a Flink SQL Job Without Stopping It?
- How Do I Fix the DLI.0005 Error When Using EL Expressions to Create a Table in a Flink SQL Job?
- Why Is No Data Queried in the DLI Table Created Using the OBS File Path When Data Is Written to OBS by a Flink Job Output Stream?
- Why Does a Flink SQL Job Fails to Be Executed, and Is "connect to DIS failed java.lang.IllegalArgumentException: Access key cannot be null" Displayed in the Log?
- Data Writing Fails After a Flink SQL Job Consumed Kafka and Sank Data to the Elasticsearch Cluster
- How Does Flink Opensource SQL Parse Nested JSON?
- Why Is the Time Read by a Flink OpenSource SQL Job from the RDS Database Is Different from the RDS Database Time?
- Why Does Job Submission Fail When the failure-handler Parameter of the Elasticsearch Result Table for a Flink Opensource SQL Job Is Set to retry_rejected?
- How Do I Configure Connection Retries for Kafka Sink If it is Disconnected?
- How Do I Write Data to Different Elasticsearch Clusters in a Flink Job?
- Why Does DIS Stream Not Exist During Job Semantic Check?
- Why Is Error "Timeout expired while fetching topic metadata" Repeatedly Reported in Flink JobManager Logs?
Flink Jar Jobs
- Can I Upload Configuration Files for Flink Jar Jobs?
- Why Does a Flink Jar Package Conflict Result in Job Submission Failure?
- Why Does a Flink Jar Job Fail to Access GaussDB(DWS) and a Message Is Displayed Indicating Too Many Client Connections?
- Why Is Error Message "Authentication failed" Displayed During Flink Jar Job Running?
- Why Is Error Invalid OBS Bucket Name Reported After a Flink Job Submission Failed?
- Why Does the Flink Submission Fail Due to Hadoop JAR File Conflict?
- How Do I Locate a Flink Job Submission Error?
Flink Job Performance Tuning
- What Is the Recommended Configuration for a Flink Job?
- Flink Job Performance Tuning
- How Do I Prevent Data Loss After Flink Job Restart?
- How Do I Locate a Flink Job Running Error?
- How Can I Check if a Flink Job Can Be Restored From a Checkpoint After Restarting It?
- Why Are Logs Not Written to the OBS Bucket After a DLI Flink Job Fails to Be Submitted for Running?
- Why Is the Flink Job Abnormal Due to Heartbeat Timeout Between JobManager and TaskManager?
Spark Jobs
Spark Job Development
- Spark Jobs
- How Do I Use Spark to Write Data into a DLI Table?
- How Do I Set Up AK/SK So That a General Queue Can Access Tables Stored in OBS?
- How Do I View the Resource Usage of DLI Spark Jobs?
- How Do I Use Python Scripts to Access the MySQL Database If the pymysql Module Is Missing from the Spark Job Results Stored in MySQL?
- How Do I Run a Complex PySpark Program in DLI?
- How Do I Use JDBC to Set the spark.sql.shuffle.partitions Parameter to Improve the Task Concurrency?
- How Do I Read Uploaded Files for a Spark Jar Job?
- Why Can't I Find the Specified Python Environment After Adding the Python Package?
- Why Is a Spark Jar Job Stuck in the Submitting State?
Spark Job O&M
- What Can I Do When Receiving java.lang.AbstractMethodError in the Spark Job?
- Why Do I Get "ResponseCode: 403" and "ResponseStatus: Forbidden" Errors When a Spark Job Accesses OBS Data?
- Why Do I Encounter the Error "verifyBucketExists on XXXX: status [403]" When Using a Spark Job to Access an OBS Bucket That I Have Permission to Access?
- Why Does a Job Running Timeout Occur When Processing a Large Amount of Data with a Spark Job?
- Why Does a Spark Job Fail to Execute with an Abnormal Access Directory Error When Accessing Files in SFTP?
- Why Does the Job Fail to Be Executed Due to Insufficient Database and Table Permissions?
- Why Is the global_temp Database Missing in the Job Log of Spark 3.x?
- Why Does Using DataSource Syntax to Create an OBS Table of Avro Type Fail When Accessing Metadata With Spark 2.3.x?
- DLI Resource Quotas
DLI Permissions Management
- How Do I Do If I Receive an Error Message Stating That I Do Not Have Sufficient Permissions When Creating a Table After Upgrading the Engine Version of a Queue?
- What Is Column-Level Authorization for DLI Partitioned Tables?
- How Do I Do If I Encounter Insufficient Permissions While Updating Packages?
- Why Is Error "DLI.0003: Permission denied for resource..." Reported When I Run a SQL Statement?
- How Do I Do If I Can't Query Table Data After Being Granted Table Permissions?
- Will Granting Duplicate Permissions to a Table After Inheriting Database Permissions Cause an Error?
- Why Can't I Query a View After I'm Granted the Select Table Permission on the View?
- How Do I Do If I Receive a Message Saying I Don't Have Sufficient Permissions to Submit My Jobs to the Job Bucket?
- How Do I Resolve an Unauthorized OBS Bucket Error?
- DLI APIs
DLI Basics
More Documents
- DLI Introduction
- Getting Started
- DLI Console Overview
- SQL Editor
- Job Management
- Queue Management
- Data Management
- Job Templates
- Datasource Connections
- Global Configuration
- UDFs
- Change History
- Before You Start
- Overview
- Calling APIs
- Getting Started
- Package Group-related APIs
- Granting OBS Permissions to DLI
- Querying the Job List
- Deleting a Job
- APIs Related to Spark jobs
- Querying an Enhanced Datasource Connection List
- Binding a Queue
- Unbinding a Queue
- Modifying the Host Information
- Public Parameters
- Change History
SQL Syntax Reference (ME-Abu Dhabi Region)
- Common Configuration Items of Batch SQL Jobs
- SQL Syntax Overview of Batch Jobs
- Databases
- Deleting a Table
- Checking Tables
- Modifying a Table
Syntax for Partitioning a Table
- Importing Data to the Table
- Inserting Data
- Clearing Data
- Exporting Search Results
- Creating a Datasource Connection with a DWS table
- Views
- Checking the Execution Plan
- Data Permissions Management
- Data Types
Built-in Functions
Date Functions
- Overview
- add_months
- current_date
- current_timestamp
- date_add
- dateadd
- date_sub
- date_format
- datediff
- datediff1
- datepart
- datetrunc
- day/dayofmonth
- from_unixtime
- getdate
- hour
- isdate
- last_day
- lastday
- minute
- month
- months_between
- next_day
- quarter
- second
- to_char
- to_date
- to_date1
- to_utc_timestamp
- trunc
- unix_timestamp
- weekday
- weekofyear
- year
String Functions
- Overview
- ascii
- concat
- concat_ws
- char_matchcount
- encode
- find_in_set
- get_json_object
- instr
- instr1
- initcap
- keyvalue
- length
- lengthb
- levenshtein
- locate
- lower/lcase
- lpad
- ltrim
- parse_url
- printf
- regexp_count
- regexp_extract
- replace
- regexp_replace
- regexp_replace1
- regexp_instr
- regexp_substr
- repeat
- reverse
- rpad
- rtrim
- soundex
- space
- substr/substring
- substring_index
- split_part
- translate
- trim
- upper/ucase
- Window Functions
- Other Functions
Date Functions
- Basic SELECT Statements
- Filtering
- Sorting
- Grouping
- JOIN
- Subquery
- Alias
- Set Operations
- WITH...AS
- CASE...WHEN
- OVER Clause
- DIS Result Table
- JDBC Result Table
- SMN Result Table
- Functions
Historical Versions
Flink SQL Syntax
- SQL Syntax Constraints and Definitions
- SQL Syntax Overview of Stream Jobs
- Creating a Source Stream
Creating a Sink Stream
- MRS OpenTSDB Sink Stream
- CSS Elasticsearch Sink Stream
- DCS Sink Stream
- DDS Sink Stream
- DIS Sink Stream
- DMS Sink Stream
- DWS Sink Stream (JDBC Mode)
- DWS Sink Stream (OBS-based Dumping)
- MRS HBase Sink Stream
- MRS Kafka Sink Stream
- Open-Source Kafka Sink Stream
- File System Sink Stream (Recommended)
- OBS Sink Stream
- RDS Sink Stream
- SMN Sink Stream
- Creating a Temporary Stream
- Custom Stream Ecosystem
- Data Type
- Built-In Functions
- Geographical Functions
- SELECT
- Window
- JOIN Between Stream Data and Table Data
- Configuring Time Models
- Pattern Matching
- StreamingML
- Reserved Keywords
Flink SQL Syntax
Identifiers
- aggregate_func
- alias
- attr_expr
- attr_expr_list
- col
- col_comment
- col_name
- col_name_list
- condition
- condition_list
- cte_name
- data_type
- db_comment
- db_name
- file_format
- file_path
- function_name
- having_condition
- input_expression
- join_condition
- number
- partition_specs
- property_name
- property_value
- regex_expression
- result_expression
- select_statement
- separator
- sub_query
- table_comment
- table_name
- table_properties
- table_reference
- when_expression
- where_condition
- window_function
- Operators
- User Guide (Paris Region)
API Reference (Paris Region)
- Before You Start
- Overview
- Calling APIs
- Getting Started
- Deleting a Job
- Binding a Queue
- Unbinding a Queue
- Public Parameters
- Change History
SQL Syntax Reference (Paris Region)
- Databases
- Deleting a Table
- Checking Tables
- Modifying a Table
- Inserting Data
- Clearing Data
- Views
- Data Types
Built-in Functions
Date Functions
- Overview
- add_months
- current_date
- current_timestamp
- date_add
- dateadd
- date_sub
- date_format
- datediff
- datediff1
- datepart
- datetrunc
- day/dayofmonth
- from_unixtime
- getdate
- hour
- isdate
- last_day
- lastday
- minute
- month
- months_between
- next_day
- quarter
- second
- to_char
- to_date
- to_date1
- to_utc_timestamp
- trunc
- unix_timestamp
- weekday
- weekofyear
- year
String Functions
- Overview
- ascii
- concat
- concat_ws
- char_matchcount
- encode
- find_in_set
- get_json_object
- instr
- instr1
- initcap
- keyvalue
- length
- lengthb
- levenshtein
- locate
- lower/lcase
- lpad
- ltrim
- parse_url
- printf
- regexp_count
- regexp_extract
- replace
- regexp_replace
- regexp_replace1
- regexp_instr
- regexp_substr
- repeat
- reverse
- rpad
- rtrim
- soundex
- space
- substr/substring
- substring_index
- split_part
- translate
- trim
- upper/ucase
- Window Functions
- Other Functions
Date Functions
- Filtering
- Sorting
- Grouping
- JOIN
- Subquery
- Alias
- Set Operations
- WITH...AS
- CASE...WHEN
- OVER Clause
- DIS Result Table
- JDBC Result Table
- SMN Result Table
- Functions
Historical Versions
Flink SQL Syntax
- DCS Sink Stream
- DDS Sink Stream
- DIS Sink Stream
- DMS Sink Stream
- OBS Sink Stream
- RDS Sink Stream
- SMN Sink Stream
- Data Type
- SELECT
- Window
- Pattern Matching
- StreamingML
- Reserved Keywords
Flink SQL Syntax
Identifiers
- aggregate_func
- alias
- attr_expr
- attr_expr_list
- col
- col_comment
- col_name
- col_name_list
- condition
- condition_list
- cte_name
- data_type
- db_comment
- db_name
- file_format
- file_path
- function_name
- having_condition
- input_expression
- join_condition
- number
- partition_specs
- property_name
- property_value
- regex_expression
- result_expression
- select_statement
- separator
- sub_query
- table_comment
- table_name
- table_properties
- table_reference
- when_expression
- where_condition
- window_function
- Operators
- DLI Introduction
- Getting Started
- SQL Editor
- Job Management
- Queue Management
- Data Management
- Job Templates
- UDFs
- Change History
- Before You Start
- Overview
- Calling APIs
- Getting Started
- Deleting a Job
- Binding a Queue
- Unbinding a Queue
- Public Parameters
- Change History
SQL Syntax Reference (Kuala Lumpur Region)
- Databases
- Deleting a Table
- Checking Tables
- Modifying a Table
- Inserting Data
- Clearing Data
- Views
- Data Types
Built-in Functions
Date Functions
- Overview
- add_months
- current_date
- current_timestamp
- date_add
- dateadd
- date_sub
- date_format
- datediff
- datediff1
- datepart
- datetrunc
- day/dayofmonth
- from_unixtime
- getdate
- hour
- isdate
- last_day
- lastday
- minute
- month
- months_between
- next_day
- quarter
- second
- to_char
- to_date
- to_date1
- to_utc_timestamp
- trunc
- unix_timestamp
- weekday
- weekofyear
- year
String Functions
- Overview
- ascii
- concat
- concat_ws
- char_matchcount
- encode
- find_in_set
- get_json_object
- instr
- instr1
- initcap
- keyvalue
- length
- lengthb
- levenshtein
- locate
- lower/lcase
- lpad
- ltrim
- parse_url
- printf
- regexp_count
- regexp_extract
- replace
- regexp_replace
- regexp_replace1
- regexp_instr
- regexp_substr
- repeat
- reverse
- rpad
- rtrim
- soundex
- space
- substr/substring
- substring_index
- split_part
- translate
- trim
- upper/ucase
- Window Functions
- Other Functions
Date Functions
- Filtering
- Sorting
- Grouping
- JOIN
- Subquery
- Alias
- Set Operations
- WITH...AS
- CASE...WHEN
- OVER Clause
- DIS Result Table
- JDBC Result Table
- SMN Result Table
- Functions
Historical Versions
Flink SQL Syntax
- CloudTable HBase Sink Stream
- CloudTable OpenTSDB Sink Stream
- DCS Sink Stream
- DDS Sink Stream
- DIS Sink Stream
- DMS Sink Stream
- OBS Sink Stream
- RDS Sink Stream
- SMN Sink Stream
- Data Type
- SELECT
- Window
- Pattern Matching
- StreamingML
- Reserved Keywords
Flink SQL Syntax
Identifiers
- aggregate_func
- alias
- attr_expr
- attr_expr_list
- col
- col_comment
- col_name
- col_name_list
- condition
- condition_list
- cte_name
- data_type
- db_comment
- db_name
- file_format
- file_path
- function_name
- having_condition
- input_expression
- join_condition
- number
- partition_specs
- property_name
- property_value
- regex_expression
- result_expression
- select_statement
- separator
- sub_query
- table_comment
- table_name
- table_properties
- table_reference
- when_expression
- where_condition
- window_function
- Operators
- Videos
Upsert Kafka
Function
Apache Kafka is a fast, scalable, and fault-tolerant distributed message publishing and subscription system. It delivers high throughput and built-in partitions and provides data replicas and fault tolerance. Apache Kafka is applicable to scenarios of handling massive messages. The Upsert Kafka connector allows for reading data from and writing data into Kafka topics in the upsert fashion. Source tables and result tables are supported.
- As a source, the upsert-kafka connector produces a changelog stream, where each data record represents an update or delete event.
The value in a data record is interpreted as an UPDATE of the last value for the same key, if any (if a corresponding key does not exist yet, the UPDATE will be considered an INSERT). Using the table analogy, a data record in a changelog stream is interpreted as an UPSERT, also known as INSERT/UPDATE, because any existing row with the same key is overwritten. Also, null values are interpreted in a special way: A record with a null value represents a DELETE.
- As a sink, the upsert-kafka connector can consume a changelog stream. It will write INSERT/UPDATE_AFTER data as normal Kafka messages value, and write DELETE data as Kafka messages with null values (indicate tombstone for the key). Flink will guarantee the message ordering on the primary key by partition data on the values of the primary key columns, so the UPDATE/DELETE messages on the same key will fall into the same partition.
Type |
Description |
Supported Table Types |
Source table and result table |
- For details about how to set up an enhanced datasource connection, see Enhanced Datasource Connections.
- For details about how to configure security group rules, see Security Group Overview.
Caveats
- When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
- Storing authentication credentials such as usernames and passwords in code or plaintext poses significant security risks. It is recommended using DEW to manage credentials instead. Storing encrypted credentials in configuration files or environment variables and decrypting them when needed ensures security. For details, see Flink OpenSource SQL Jobs Using DEW to Manage Access Credentials.
- The Upsert Kafka always works in the upsert fashion and requires to define the primary key in the DDL. With the assumption that records with the same key should be ordered in the same partition, the primary key semantic on the changelog source means the materialized changelog is unique on the primary keys. The primary key definition will also control which fields should end up in Kafka's key.
- Because the connector is working in upsert mode, the last record on the same key will take effect when reading back as a source.
- For details about how to use data types, see Format.
Syntax
1 2 3 4 5 6 7 8 9 10 11 12 |
create table kafkaTable( attr_name attr_type (',' attr_name attr_type)* (','PRIMARY KEY (attr_name, ...) NOT ENFORCED) ) with ( 'connector' = 'upsert-kafka', 'topic' = '', 'properties.bootstrap.servers' = '', 'key.format' = '', 'value.format' = '' ); |
Parameter Description
Parameter |
Mandatory |
Default Value |
Data Type |
Description |
connector |
Yes |
None |
String |
Connector to be used. For the Upsert Kafka connector, set this parameter to upsert-kafka. |
topic |
Yes |
None |
String |
Kafka topic name |
properties.bootstrap.servers |
Yes |
None |
String |
Comma separated list of Kafka brokers |
key.format |
Yes |
None |
String |
Format used to deserialize and serialize the key part of Kafka messages. The key fields are specified by the PRIMARY KEY syntax. The following formats are supported:
Refer to Format for more details and format parameters. |
key.fields-prefix |
No |
None |
String |
Defines a custom prefix for all fields of the key format to avoid name clashes with fields of the value format. By default, the prefix is empty. If a custom prefix is defined, both the table schema and key.fields will work with prefixed names. When constructing the data type of the key format, the prefix will be removed and the non-prefixed names will be used within the key format. Note that this option requires that value.fields-include be set to EXCEPT_KEY. |
value.format |
Yes |
None |
String |
Format used to deserialize and serialize the value part of Kafka messages. The following formats are supported:
value.fields-include |
Yes |
ALL |
String |
Controls which fields should appear in the value part. Possible values are:
properties.* |
No |
None |
String |
This option can set and pass arbitrary Kafka configurations. The suffix to properties. must match the parameter defined in Kafka Configuration documentation. Flink will remove the properties. key prefix and pass the transformed key and value to the underlying KafkaClient. For example, you can disable automatic topic creation via 'properties.allow.auto.create.topics' = 'false'. But there are some configurations that do not support to set, because Flink will override them, for example, 'key.deserializer' and 'value.deserializer'. |
sink.parallelism |
No |
None |
Integer |
Defines the parallelism of the Upsert Kafka sink operator. By default, the parallelism is determined by the framework: using the same parallelism as the upstream join operator. |
sink.buffer-flush.max-rows |
No |
0 |
Integer |
The max size of buffered records before flushing. When the sink receives many updates on the same key, the buffer will retain the last record of the same key. This can help to reduce data shuffling and avoid possible tombstone messages to Kafka topic. Can be set to 0 to disable it. By default, this is disabled. Note both sink.buffer-flush.max-rows and sink.buffer-flush.interval must be set to be greater than zero to enable sink buffer flushing. |
sink.buffer-flush.interval |
No |
0 |
Duration |
The flush interval mills, over this time, asynchronous threads will flush data. The unit can be millisecond (ms), second (s), minute (min), or hour (h). For example, 'sink.buffer-flush.interval'='10 ms'. By default, this is disabled. Note both sink.buffer-flush.max-rows and sink.buffer-flush.interval must be set to be greater than zero to enable sink buffer flushing. |
Metadata
For a list of available metadata fields, see Kafka Connector.
Example
- Example 1: This example reads data from a DMS Kafka data source and writes it to the Print result table.
- Create an enhanced datasource connection in the VPC and subnet where Kafka locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
- Set Kafka security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the Kafka address by referring to Testing Address Connectivity. If the connection passes the test, it is bound to the queue.
- Create a Flink OpenSource SQL job. Enter the following job script and submit the job.
When you create a job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
CREATE TABLE upsertKafkaSource ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, PRIMARY KEY (order_id) NOT ENFORCED ) WITH ( 'connector' = 'upsert-kafka', 'topic' = 'KafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkAddress2:KafkaPort', 'key.format' = 'csv', 'value.format' = 'json' ); CREATE TABLE printSink ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, PRIMARY KEY (order_id) NOT ENFORCED ) WITH ( 'connector' = 'print' ); INSERT INTO printSink SELECT * FROM upsertKafkaSource;
- Insert the following data to the specified topics in Kafka. (Note: Specify the key when inserting data to Kafka.)
{"order_id":"202303251202020001", "order_channel":"miniAppShop", "order_time":"2023-03-25 12:02:02", "pay_amount":"60.00", "real_pay":"60.00", "pay_time":"2023-03-25 12:03:00", "user_id":"0002", "user_name":"Bob", "area_id":"330110"} {"order_id":"202303251505050001", "order_channel":"appshop", "order_time":"2023-03-25 15:05:05", "pay_amount":"500.00", "real_pay":"400.00", "pay_time":"2023-03-25 15:10:00", "user_id":"0003", "user_name":"Cindy", "area_id":"330108"} {"order_id":"202303251202020001", "order_channel":"miniAppShop", "order_time":"2023-03-25 12:02:02", "pay_amount":"60.00", "real_pay":"60.00", "pay_time":"2023-03-25 12:03:00", "user_id":"0002", "user_name":"Bob", "area_id":"330111"}
- View the out file of the TaskManager. The data results are as follows:
+I(202303251202020001,miniAppShop,2023-03-2512:02:02,60.0,60.0,2023-03-2512:03:00,0002,Bob,330110) +I(202303251505050001,appshop,2023-03-25 15:05:05,500.0,400.0,2023-03-2515:10:00,0003,Cindy,330108) -U(202303251202020001,miniAppShop,2023-03-2512:02:02,60.0,60.0,2023-03-2512:03:00,0002,Bob,330110) +U(202303251202020001,miniAppShop,2023-03-2512:02:02,60.0,60.0,2023-03-2512:03:00,0002,Bob,330111)
- Example 2: This example retrieves DMS Kafka source topic data from a Kafka source table and writes it to a Kafka sink topic using Upsert Kafka result table.
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'KafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); CREATE TABLE upsertKafkaSink ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, PRIMARY KEY(order_id) NOT ENFORCED ) WITH ( 'connector' = 'upsert-kafka', 'topic' = 'KafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkAddress2:KafkaPort', 'key.format' = 'csv', 'value.format' = 'json' ); insert into upsertKafkaSink select * from orders;
- Connect to the Kafka cluster and send the following test data to the Kafka source topic:
- Connect to the Kafka cluster and read data from the Kafka sink topic. The result is as follows:
- Example 3: In this scenario, the MRS cluster has enabled Kerberos authentication and Kafka is using the SASL_PLAINTEXT protocol. Data is retrieved from a Kafka source table and written to the Print result table.
- Create an enhanced datasource connection in the VPC and subnet where the MRS cluster locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
- Set MRS cluster security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the Kafka address by referring to Testing Address Connectivity. If the connection passes the test, it is bound to the queue.
CREATE TABLE upsertKafkaSource ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, PRIMARY KEY(order_id) NOT ENFORCED ) WITH ( 'connector' = 'upsert-kafka', 'topic' = 'KafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkAddress2:KafkaPort', 'key.format' = 'csv', 'value.format' = 'json', 'properties.sasl.mechanism' = 'GSSAPI', 'properties.security.protocol' = 'SASL_PLAINTEXT', 'properties.sasl.kerberos.service.name' = 'kafka', -- Configured in MRS 'properties.connector.auth.open' = 'true', 'properties.connector.kerberos.principal' = 'username', --Username 'properties.connector.kerberos.krb5' = 'obs://xx/krb5.conf', --krb5_conf path 'properties.connector.kerberos.keytab' = 'obs://xx/user.keytab' --keytab path ); CREATE TABLE printSink ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, PRIMARY KEY (order_id) NOT ENFORCED ) WITH ( 'connector' = 'print' ); INSERT INTO printSink SELECT * FROM upsertKafkaSource;
+I(202303251202020001,miniAppShop,2023-03-2512:02:02,60.0,60.0,2023-03-2512:03:00,0002,Bob,330110) +I(202303251505050001,appshop,2023-03-2515:05:05,500.0,400.0,2023-03-2515:10:00,0003,Cindy,330108) -U(202303251202020001,miniAppShop,2023-03-2512:02:02,60.0,60.0,2023-03-2512:03:00,0002,Bob,330110) +U(202303251202020001,miniAppShop,2023-03-2512:02:02,60.0,60.0,2023-03-2512:03:00,0002,Bob,330111)
FAQ
None
