Result Table
Function
DLI outputs the Flink job output data to Redis. Redis is a key-value storage system that supports multiple types of data structures. It can be used in scenarios such as caching, event publish/subscribe, and high-speed queuing. Redis supports direct read/write of strings, hashes, lists, queues, and sets. Redis works with in-memory datasets and provides persistence. For more information about Redis, visit https://redis.io/.
- For details about how to set up an enhanced datasource connection, see Enhanced Datasource Connections in the Data Lake Insight User Guide.
- For details about how to configure security group rules, see Security Group Overview in the Virtual Private Cloud User Guide.
Caveats
- When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
- Storing authentication credentials such as usernames and passwords in code or plaintext poses significant security risks. It is recommended using DEW to manage credentials instead. Storing encrypted credentials in configuration files or environment variables and decrypting them when needed ensures security. For details, see Flink OpenSource SQL Jobs Using DEW to Manage Access Credentials.
- If the Redis key field is not defined in the statement for creating the Redis result table, the generated UUID is used as the key.
- To specify a key in Redis, you need to define a primary key in the Redis result table of Flink. The value of the primary key is the Redis key.
- If the primary key defined for the Redis result table, it cannot be a composite primary key and only can be one field.
- Constraints on schema-syntax:
- If schema-syntax is map or array, there can be only one non-primary key and it must be of the same map or array type.
- If schema-syntax is fields-scores, the number of non-primary keys must be an even number, and the second key of every two keys except the primary key must be of the double type. The double value is the score of the previous key. The following is an example:
CREATE TABLE redisSink ( order_id string, order_channel string, order_time double, pay_amount STRING, real_pay double, pay_time string, user_id double, user_name string, area_id double, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = 'RedisIP', 'password' = 'RedisPassword', 'data-type' = 'sorted-set', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'fields-scores' );
- Restrictions on data-type:
- If data-type is string, only one non-primary key field is allowed.
- If data-type is sorted-set and schema-syntax is fields or array, default-score is used as the score.
- If data-type is sorted-set and schema-syntax is map, there can be only one non-primary key in addition to the primary key and the non-primary key must be of the map type. The map values of the non-primary key must be of the double type, indicating the score. The keys in the map are the values in the Redis set.
- If data-type is sorted-set and schema-syntax is array-scores, only two non-primary keys are allowed and must be of the array type. The first key indicates values in the Redis set. The second key is of the array<double> type, indicating index scores. The following is an example:
CREATE TABLE redisSink ( order_id string, arrayField Array<String>, arrayScore array<double>, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = 'RedisIP', 'password' = 'RedisPassword', 'data-type' = 'sorted-set', "default-score" = '3', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'array-scores' );
Syntax
1 2 3 4 5 6 7 8 9 | create table dwsSink ( attr_name attr_type (',' attr_name attr_type)* (','PRIMARY KEY (attr_name, ...) NOT ENFORCED) ) with ( 'connector' = 'redis', 'host' = '' ); |
Parameters
| Parameter | Mandatory | Default Value | Data Type | Description |
| connector | Yes | None | String | Connector to be used. Set this parameter to redis. |
| host | Yes | None | String | Redis connector address. |
| port | No | 6379 | Integer | Redis connector port. |
| password | No | None | String | Redis authentication password. |
| namespace | No | None | String | Redis key namespace. For example, if the value is set to "person" and the key is "jack", the value in the Redis is person:jack. |
| delimiter | No | : | String | Delimiter between the Redis key and namespace. |
| data-type | No | hash | String | Redis data type. Available values are as follows:
For details about the constraints, see Constraints on data-type. |
| schema-syntax | No | fields | String | Redis schema semantics. Available values are as follows:
For details about the constraints, see Constraints on schema-syntax. |
| deploy-mode | No | standalone | String | Deployment mode of the Redis cluster. The value can be standalone, master-replica, or cluster. The default value is standalone. For details about the setting, see the instance type description of the Redis cluster. |
| retry-count | No | 5 | Integer | Number of attempts to connect to the Redis cluster. |
| connection-timeout-millis | No | 10000 | Integer | Maximum timeout for connecting to the Redis cluster. |
| commands-timeout-millis | No | 2000 | Integer | Maximum time for waiting for a completion response. |
| rebalancing-timeout-millis | No | 15000 | Integer | Sleep time when the Redis cluster fails. |
| default-score | No | 0 | Double | Default score when data-type is sorted-set. |
| ignore-retraction | No | false | Boolean | Whether to ignore Retract messages. |
| skip-null-values | No | true | Boolean | Whether null values will be skipped. If this parameter is false, null will be assigned for null values. |
| ignore-retractions | No | false | Boolean | The connector should ignore retraction messages in the update insert/withdraw flow mode. |
| key-column | No | None | String | Schema key of the Redis table. |
| sink.delivery-guarantee | No | at-least-once | String |
| sink.parallelism | No | None | int | Defines the custom parallelism of the sink. If this parameter is not defined, the planner will derive the parallelism for each statement separately by considering the global configuration. |
| key-ttl-mode | No | no-ttl | String | Whether the Redis sink TTL function will be enabled. The value can be no-ttl, expire-msec, expire-at-date or expire-at-timestamp.
| key-ttl | No | None | String | Supplementary parameter of key-ttl-mode. Available values are as follows:
Example
In this example, data is read from the Kafka data source and written to the Redis result table. The procedure is as follows:
- Create an enhanced datasource connection in the VPC and subnet where Redis locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections.
- Set Redis security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the Redis address by referring to Testing Address Connectivity. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
- Create a Flink OpenSource SQL job. Enter the following job script and submit the job. Change the values of the parameters in bold as needed in the following script.
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'kafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); --In the following redisSink table, data-type is set to default value hash, schema-syntax is fields, and order_id is defined as the primary key. Therefore, the value of this field is used as the Redis key. CREATE TABLE redisSink ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = '<yourRedis>', 'password' = '<yourPassword>', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'fields' ); insert into redisSink select * from orders;
- Connect to the Kafka cluster and insert the following test data into Kafka:
{"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} {"order_id":"202103241606060001", "order_channel":"appShop", "order_time":"2021-03-24 16:06:06", "pay_amount":"200.00", "real_pay":"180.00", "pay_time":"2021-03-24 16:10:06", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} - Run the following commands in Redis and view the result:
- Obtain the result whose key is 202103241606060001.
Run following command:
HGETALL 202103241606060001
Command output:1) "user_id" 2) "0001" 3) "user_name" 4) "Alice" 5) "pay_amount" 6) "200.0" 7) "real_pay" 8) "180.0" 9) "order_time" 10) "2021-03-24 16:06:06" 11) "area_id" 12) "330106" 13) "order_channel" 14) "appShop" 15) "pay_time" 16) "2021-03-24 16:10:06"
- Obtain the result whose key is 202103241000000001.
HGETALL 202103241000000001
Command output:1) "user_id" 2) "0001" 3) "user_name" 4) "Alice" 5) "pay_amount" 6) "100.0" 7) "real_pay" 8) "100.0" 9) "order_time" 10) "2021-03-24 10:00:00" 11) "area_id" 12) "330106" 13) "order_channel" 14) "webShop" 15) "pay_time" 16) "2021-03-24 10:02:03"
FAQ
- Q: When data-type is set, why is the final result data less than the input data?
A: This is because the input data contains duplicate data. Deduplication is performed in the Redis set, and the number of records in the result decreases.
- Q: What should I do if Flink job logs contain the following error information?
org.apache.flink.table.api.ValidationException: SQL validation failed. From line 1, column 40 to line 1, column 105: Parameters must be of the same type
A: The array type is used. However, the types of fields in the array are different. You need to ensure that the types of fields in the array in Redis are the same.
org.apache.flink.addons.redis.core.exception.RedisConnectorException: Wrong Redis schema for 'map' syntax: There should be a key (possibly) and 1 MAP non-key column.
A: When schema-syntax is map, the table creation statement in Flink can contain only one non-primary key column, and the column type must be map.
org.apache.flink.addons.redis.core.exception.RedisConnectorException: Wrong Redis schema for 'array' syntax: There should be a key (possibly) and 1 ARRAY non-key column.
A: When schema-syntax is array, the table creation statement in Flink can contain only one non-primary key column, and the column type must be array.
- Q: What is the function of schema-syntax since data-type has been set?
A: schema-syntax is used to process special types, such as map and array.
- If it is set to fields, the value of each field is processed. If it is set to array or map, each element in the field is processed. For fields, the field value of the map or array type is directly used as a value in Redis.
- For array or map, each value in the array is used as a Redis value, and the field value of the map is used as the Redis value. array-scores is used to process the sorted-set data type. It indicates that two array fields are used, the first one is the value in the set, and the second one is the score. fields-scores is used to process the sorted-set data type, indicating that the score is derived from the defined field. The field of an odd number except the primary key indicates the value in the set, and its next field indicates its score. Therefore, its next field must be of the double type.
- Q: If data-type is hash, what are the differences between schema-syntax set to fields and that to map?
A: When fields is used, the field name in Flink is used as the Redis field of the hash data type, and the value of that field is used as the value of the hash data type in Redis. When map is used, the field key in Flink is used as the Redis field of the hash data type, and the value of that field is used as the value of the hash data type in Redis. The following is an example:
- For fields:
- The execution script of the Flink job is as follows:
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'kafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); CREATE TABLE redisSink ( order_id string, maptest Map<string, String>, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = 'RedisIP', 'password' = 'RedisPassword', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'fields' ); insert into redisSink select order_id, Map[user_id, area_id] from orders;
- Connect to the Kafka cluster and insert the following test data into the Kafka topic:
{"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} - In the Redis, the result is as follows:
1) "maptest" 2) "{0001=330106}"
- For map:
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'kafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); CREATE TABLE redisSink ( order_id string, maptest Map<string, String>, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = 'RedisIP', 'password' = 'RedisPassword', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'map' ); insert into redisSink select order_id, Map[user_id, area_id] from orders;
1) "0001" 2) "330106"
- For fields:
- Q: If data-type is list, what are the differences between schema-syntax set to fields and that to array?
A: The setting to fields or array does not result in different results. The only difference is that in the Flink table creation statement. fields can be multiple fields. However, array requires that the field is of the array type and the data types in the array must be the same. Therefore, fields are more flexible.
- For fields:
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'kafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); CREATE TABLE redisSink ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = 'RedisIP', 'password' = 'RedisPassword', 'data-type' = 'list', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'fields' ); insert into redisSink select * from orders;
{"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} - View the result.
Run the following command in Redis:
LRANGE 202103241000000001 0 8
The command output is as follows:1) "webShop" 2) "2021-03-24 10:00:00" 3) "100.0" 4) "100.0" 5) "2021-03-24 10:02:03" 6) "0001" 7) "Alice" 8) "330106"
- For array:
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'kafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); CREATE TABLE redisSink ( order_id string, arraytest Array<String>, primary key (order_id) not enforced ) WITH ( 'connector' = 'redis', 'host' = 'RedisIP', 'password' = 'RedisPassword', 'data-type' = 'list', 'deploy-mode' = 'master-replica', 'schema-syntax' = 'array' ); insert into redisSink select order_id, array[order_channel,order_time,pay_time,user_id,user_name,area_id] from orders;
{"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} - In Redis, view the result. (The result is different from that of fields because data of the double type is not added to the table creation statement of the sink in Flink. Therefore, two values are missing. This is not caused by the difference between fields and array.)
1) "webShop" 2) "2021-03-24 10:00:00" 3) "2021-03-24 10:02:03" 4) "0001" 5) "Alice" 6) "330106"
- For fields:
