HBase Result Table
Function
DLI outputs the job data to HBase. HBase is a reliable, high-performance, scalable, column-oriented distributed cloud storage system suitable for mass data storage and distributed computing scenarios. You can use HBase to establish a storage system capable of handling terabytes to petabytes of data, easily filtering and analyzing data with millisecond response times, swiftly uncovering data insights. HBase supports structured and semi-structured key-value data storage, including message data, report data, recommendation data, risk management data, log data, and order data. Using DLI, you can efficiently write vast quantities of data into HBase with high speed and minimal latency.
- An enhanced datasource connection has been created for DLI to connect to HBase, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
- For details about how to set up an enhanced datasource connection, see Enhanced Datasource Connections.
- For details about how to configure security group rules, see Security Group Overview.
- If MRS HBase is used, IP addresses of all hosts in the MRS cluster have been added to host information of the enhanced datasource connection.
For details, see Modifying Host Information.
Caveats
- When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
- Storing authentication credentials such as usernames and passwords in code or plaintext poses significant security risks. It is recommended using DEW to manage credentials instead. Storing encrypted credentials in configuration files or environment variables and decrypting them when needed ensures security. For details, see Flink OpenSource SQL Jobs Using DEW to Manage Access Credentials.
- The column families in created HBase result table must be declared as the ROW type, the field names map the column family names, and the nested field names map the column qualifier names. There is no need to declare all the families and qualifiers in the schema. Users can declare what is used in the query. Except the ROW type fields, the single atomic type field (for example, STRING or BIGINT) will be recognized as the HBase rowkey. The rowkey field can be an arbitrary name, but should be quoted using backticks if it is a reserved keyword.
Syntax
create table hbaseSink (
attr_name attr_type
(',' attr_name attr_type)*
','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
) with (
'connector' = 'hbase-2.2',
'table-name' = '',
'zookeeper.quorum' = ''
); Parameters
Parameter | Mandatory | Default Value | Data Type | Description |
connector | Yes | None | String | Connector to be used. Set this parameter to hbase-2.2. |
table-name | Yes | None | String | Name of the HBase table to connect. |
zookeeper.quorum | Yes | None | String | HBase ZooKeeper instance information, in the format of ZookeeperAddress:ZookeeperPort. The following uses an MRS HBase cluster as an example to describe how to obtain the IP address and port number of ZooKeeper used by this parameter:
zookeeper.znode.parent | No | /hbase | String | Root directory in ZooKeeper. The default value is /hbase. |
null-string-literal | No | null | String | Representation for null values for string fields. The HBase sink encodes/decodes empty bytes as null values for all types except the string type. |
sink.buffer-flush.max-size | No | 2mb | MemorySize | Maximum size in memory of buffered rows for each write request. This can improve performance for writing data to the HBase database, but may increase the latency. You can set this parameter to 0 to disable it. |
sink.buffer-flush.max-rows | No | 1000 | Integer | Maximum number of rows to buffer for each write request. This can improve performance for writing data to the HBase database, but may increase the latency. You can set this parameter to 0 to disable it. |
sink.buffer-flush.interval | No | 1s | Duration | Interval for refreshing the buffer, during which data is refreshed by asynchronous threads. This can improve performance for writing data to the HBase database, but may increase the latency. You can set this parameter to 0 to disable it. Note: If sink.buffer-flush.max-size and sink.buffer-flush.max-rows are both set to 0 and the buffer refresh interval is configured, the buffer is asynchronously refreshed. The format is {length value}{time unit label}, for example, 123ms, 321s. The supported time units include d, h, min, s, and ms (default unit). |
sink.parallelism | No | None | Integer | Defines the parallelism of the HBase sink operator. By default, the parallelism is determined by the framework: using the same parallelism as the upstream join operator. |
properties.connector.auth.open | No | None | Boolean | true indicates that Kerberos authentication is enabled for the HBase cluster. This parameter is mandatory if Kerberos authentication is enabled. |
properties.connector.kerberos.principal | No | None | String | Username for logging in to the security cluster. This parameter is mandatory if Kerberos authentication is enabled. |
properties.connector.kerberos.keytab | No | None | String | OBS path to which the user.keytab file is uploaded. This parameter is mandatory if Kerberos authentication is enabled. |
properties.connector.kerberos.krb5 | No | None | String | OBS path to which the krb5.conf file is uploaded. This parameter is mandatory if Kerberos authentication is enabled. Note: The renew_lifetime configuration item under [libdefaults] must be removed from krb5.conf. Otherwise, the "Message stream modified (41)" error may occur. |
Data Type Mapping
HBase stores all data as byte arrays. The data needs to be serialized and deserialized during read and write operations.
When serializing and de-serializing, Flink HBase connector uses utility class org.apache.hadoop.hbase.util.Bytes provided by HBase (Hadoop) to convert Flink data types to and from byte arrays.
Flink HBase connector encodes null values to empty bytes, and decodes empty bytes to null values for all data types except the string type. For string type, the null literal is determined by the null-string-literal option.
Flink SQL Type | HBase Conversion |
CHAR/VARCHAR/STRING | byte[] toBytes(String s) String toString(byte[] b) |
BOOLEAN | byte[] toBytes(boolean b) boolean toBoolean(byte[] b) |
BINARY/VARBINARY | Returns byte[] as is. |
DECIMAL | byte[] toBytes(BigDecimal v) BigDecimal toBigDecimal(byte[] b) |
TINYINT | new byte[] { val } bytes[0] // returns first and only byte from bytes |
SMALLINT | byte[] toBytes(short val) short toShort(byte[] bytes) |
INT | byte[] toBytes(int val) int toInt(byte[] bytes) |
BIGINT | byte[] toBytes(long val) long toLong(byte[] bytes) |
FLOAT | byte[] toBytes(float val) float toFloat(byte[] bytes) |
DOUBLE | byte[] toBytes(double val) double toDouble(byte[] bytes) |
DATE | Number of days since 1970-01-01 00:00:00 UTC. The value is an integer. |
TIME | Number of milliseconds since 1970-01-01 00:00:00 UTC. The value is an integer. |
TIMESTAMP | Number of milliseconds since 1970-01-01 00:00:00 UTC. The value is of the long type. |
ARRAY | Not supported |
MAP / MULTISET | Not supported |
ROW | Not supported |
Example
In this example, data is read from the Kafka data source and written to the HBase result table. The procedure is as follows (the HBase version used in this example is 2.2.3):
- Create an enhanced datasource connection in the VPC and subnet where HBase and Kafka locate, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections. Add MRS host information in the enhanced datasource connection by referring to Modifying Host Information.
- Set HBase and Kafka security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the HBase and Kafka addresses by referring to Testing Address Connectivity. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
- Use the HBase shell to create HBase table order that has only one column family detail. For details, see Using HBase from Scratch.
create 'order', {NAME => 'detail'} - Create a Flink OpenSource SQL job. Enter the following job script and submit the job. The job script uses Kafka as the data source and HBase as the result table (the Rowkey is order_id and the column family name is detail). When you create a job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
CREATE TABLE orders ( order_id string, order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string ) WITH ( 'connector' = 'kafka', 'topic' = 'KafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); create table hbaseSink( order_id string, detail Row( order_channel string, order_time string, pay_amount double, real_pay double, pay_time string, user_id string, user_name string, area_id string) ) with ( 'connector' = 'hbase-2.2', 'table-name' = 'order', 'zookeeper.quorum' = 'ZookeeperAddress:ZookeeperPort', 'sink.buffer-flush.max-rows' = '1' ); insert into hbaseSink select order_id, Row(order_channel,order_time,pay_amount,real_pay,pay_time,user_id,user_name,area_id) from orders; - Connect to the Kafka cluster and enter the following data to Kafka:
{"order_id":"202103241000000001", "order_channel":"webShop", "order_time":"2021-03-24 10:00:00", "pay_amount":"100.00", "real_pay":"100.00", "pay_time":"2021-03-24 10:02:03", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} {"order_id":"202103241606060001", "order_channel":"appShop", "order_time":"2021-03-24 16:06:06", "pay_amount":"200.00", "real_pay":"180.00", "pay_time":"2021-03-24 16:10:06", "user_id":"0001", "user_name":"Alice", "area_id":"330106"} {"order_id":"202103251202020001", "order_channel":"miniAppShop", "order_time":"2021-03-25 12:02:02", "pay_amount":"60.00", "real_pay":"60.00", "pay_time":"2021-03-25 12:03:00", "user_id":"0002", "user_name":"Bob", "area_id":"330110"} - Run the following statement on the HBase shell to view the data result:
scan 'order'
The data result is as follows:202103241000000001 column=detail:area_id, timestamp=2021-12-16T21:30:37.954, value=330106 202103241000000001 column=detail:order_channel, timestamp=2021-12-16T21:30:37.954, value=webShop 202103241000000001 column=detail:order_time, timestamp=2021-12-16T21:30:37.954, value=2021-03-24 10:00:00 202103241000000001 column=detail:pay_amount, timestamp=2021-12-16T21:30:37.954, value=@Y\x00\x00\x00\x00\x00\x00 202103241000000001 column=detail:pay_time, timestamp=2021-12-16T21:30:37.954, value=2021-03-24 10:02:03 202103241000000001 column=detail:real_pay, timestamp=2021-12-16T21:30:37.954, value=@Y\x00\x00\x00\x00\x00\x00 202103241000000001 column=detail:user_id, timestamp=2021-12-16T21:30:37.954, value=0001 202103241000000001 column=detail:user_name, timestamp=2021-12-16T21:30:37.954, value=Alice 202103241606060001 column=detail:area_id, timestamp=2021-12-16T21:30:44.842, value=330106 202103241606060001 column=detail:order_channel, timestamp=2021-12-16T21:30:44.842, value=appShop 202103241606060001 column=detail:order_time, timestamp=2021-12-16T21:30:44.842, value=2021-03-24 16:06:06 202103241606060001 column=detail:pay_amount, timestamp=2021-12-16T21:30:44.842, value=@i\x00\x00\x00\x00\x00\x00 202103241606060001 column=detail:pay_time, timestamp=2021-12-16T21:30:44.842, value=2021-03-24 16:10:06 202103241606060001 column=detail:real_pay, timestamp=2021-12-16T21:30:44.842, value=@f\x80\x00\x00\x00\x00\x00 202103241606060001 column=detail:user_id, timestamp=2021-12-16T21:30:44.842, value=0001 202103241606060001 column=detail:user_name, timestamp=2021-12-16T21:30:44.842, value=Alice 202103251202020001 column=detail:area_id, timestamp=2021-12-16T21:30:52.181, value=330110 202103251202020001 column=detail:order_channel, timestamp=2021-12-16T21:30:52.181, value=miniAppShop 202103251202020001 column=detail:order_time, timestamp=2021-12-16T21:30:52.181, value=2021-03-25 12:02:02 202103251202020001 column=detail:pay_amount, timestamp=2021-12-16T21:30:52.181, value=@N\x00\x00\x00\x00\x00\x00 202103251202020001 column=detail:pay_time, timestamp=2021-12-16T21:30:52.181, value=2021-03-25 12:03:00 202103251202020001 column=detail:real_pay, timestamp=2021-12-16T21:30:52.181, value=@N\x00\x00\x00\x00\x00\x00 202103251202020001 column=detail:user_id, timestamp=2021-12-16T21:30:52.181, value=0002 202103251202020001 column=detail:user_name, timestamp=2021-12-16T21:30:52.181, value=Bob
FAQ
Q: What should I do if the Flink job execution fails and the log contains the following error information?
org.apache.zookeeper.ClientCnxn$SessionTimeoutException: Client session timed out, have not heard from server in 90069ms for connection id 0x0
A: The datasource connection is not bound or the binding fails. Configure the datasource connection by referring to Enhanced Datasource Connections or configure the security group of the Kafka cluster to allow access from the DLI queue.
