Source Table
Updated on 2024-04-24 GMT+08:00
Function
Flink SQL jobs read from the Doris source table.
  • An enhanced datasource connection has been created for DLI to connect to Doris, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
  • If MRS Doris is used, IP addresses of all hosts in the MRS cluster have been added to host information of the enhanced datasource connection.
    For details, see Modifying Host Information.
  • Kerberos authentication is disabled for the cluster (the cluster is in normal mode)
    After connecting to Doris as user admin, create a role with administrator permissions, and bind the role to the user.
Caveats
  • When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
  • Storing authentication credentials such as usernames and passwords in code or plaintext poses significant security risks. It is recommended using DEW to manage credentials instead. Storing encrypted credentials in configuration files or environment variables and decrypting them when needed ensures security. For details, see Flink OpenSource SQL Jobs Using DEW to Manage Access Credentials.
  • Doris table names are case sensitive.
  • When Doris of CloudTable is used, set the port number in the fenodes field to 8030, for example, xx:8030. In addition, enable ports 8030, 8040, and 9030 in the security group.
  • After HTTPS is enabled, add the following configuration parameters to the with clause for creating a table:
    • 'doris.enable.https' = 'true'
    • 'doris.ignore.https.ca' = 'true'
Syntax
create table dorisSource (
  attr_name attr_type
  (',' attr_name attr_type)*
with (
  'connector' = 'doris',
  'fenodes' = 'FE_IP:PORT,FE_IP:PORT,FE_IP:PORT',
  'table.identifier' = 'database.table',
  'username' = 'dorisUsername',
  'password' = 'dorisPassword'
Parameter Description
Shared configuration
Default Value
Mandatory
Parameter Type Description
fenodes
Yes
IP address and port number of the Doris FE. Use commas (,) to separate them for multiple instances. To obtain the port number, log in to FusionInsight Manager, choose Cluster > Services > Doris > Configurations, and search for http. Search for https instead if HTTPS is enabled.
table.identifier
Yes
Doris table name, for example, db.tbl.
username
Yes
User name for accessing Doris.
password
Yes
Password for accessing Doris.
doris.request.retries
3
No
Number of retry times for sending requests to Doris.
doris.request.connect.timeout.ms
30000
No
Connection timeout interval for sending requests to Doris.
doris.request.read.timeout.ms
30000
No
Read timeout interval for sending requests to Doris.
doris.request.query.timeout.s
3600
No
Timeout interval for querying Doris. The default value is 1 hour. The value -1 indicates that there is no timeout limit.
doris.request.tablet.size
Integer. MAX_VALUE
No
Number of Doris Tablets corresponding to a partition. The smaller the value set, the more partitions will be generated. This increases the degree of parallelism in Flink, but puts more pressure on Doris.
doris.batch.size
1024
No
Maximum number of rows to read from BE at a time. Increasing this value reduces the number of times Flink needs to establish a connection with Doris when reading data from BE, thereby reducing the additional time overhead caused by network latency.
doris.exec.mem.limit
2147483648
No
Memory limit for a single query, with a default value of 2 GB, in bytes.
doris.deserialize.arrow.async
FALSE
No
Whether to support asynchronous conversion of Arrow format to RowBatch required for flink-doris-connector iteration.
doris.deserialize.queue.size
64
No
The internal processing queue for asynchronous conversion of Arrow format is effective when doris.deserialize.arrow.async is set to true.
doris.read.field
No
The column name list for reading from Doris tables, with multiple columns separated by commas.
doris.filter.query
No
The expression used to filter the data to be read, which is passed through to Doris. Doris uses this expression to filter the source data.
Example
This example reads data from a Doris source table and inputs it into the Print connector.
  1. Create an enhanced datasource connection in the VPC and subnet where Doris locates, and bind the connection to the required Flink elastic resource pool. For details, see Enhanced Datasource Connections. Add MRS host information for the enhanced datasource connection. For details, see Modifying Host Information.
  2. Set Doris security groups and add inbound rules to allow access from the Flink queue. Test the connectivity using the Doris address by referring to Testing Address Connectivity. If the connection passes the test, it is bound to the queue.
  3. Create a Doris table and insert 10 data records into the table. The creation statement is as follows:
    CREATE TABLE IF NOT EXISTS dorisdemo
      `user_id` varchar(10) NOT NULL,
      `city` varchar(10),
      `age` int,
      `gender` int
    DISTRIBUTED BY HASH(`user_id`) BUCKETS 10;
    INSERT INTO dorisdemo VALUES ('user1', 'city1', 20, 1);
    INSERT INTO dorisdemo VALUES ('user2', 'city2', 21, 0);
    INSERT INTO dorisdemo VALUES ('user3', 'city3', 22, 1);
    INSERT INTO dorisdemo VALUES ('user4', 'city4', 23, 0);
    INSERT INTO dorisdemo VALUES ('user5', 'city5', 24, 1);
    INSERT INTO dorisdemo VALUES ('user6', 'city6', 25, 0);
    INSERT INTO dorisdemo VALUES ('user7', 'city7', 26, 1);
    INSERT INTO dorisdemo VALUES ('user8', 'city8', 27, 0);
    INSERT INTO dorisdemo VALUES ('user9', 'city9', 28, 1);
    INSERT INTO dorisdemo VALUES ('user10', 'city10', 29, 0);
  4. Create a Flink OpenSource SQL job. Enter the following job script and submit the job. The job script reads from the Doris table and prints the output.
    CREATE TABLE dorisDemo (
      `user_id` String NOT NULL,
      `city` String,
      `age` int,
      `gender` int
    ) with (
      'table.identifier' = 'demo.dorisdemo',
      'username' = 'dorisUser',
      'password' = 'dorisPassword',
      'doris.request.retries'='3',
      'doris.batch.size' = '100'
    CREATE TABLE print (
      `city` String,
      `age` int,
      `gender` int
    ) with (
      'connector' = 'print'
    insert into print select * from dorisDemo;
  5. View the data in the Print result table.
    +I[user5, city5, 24, 1]
    +I[user4, city4, 23, 0]
    +I[user3, city3, 22, 1]
    +I[user10, city10, 29, 0]
    +I[user6, city6, 25, 0]
    +I[user1, city1, 20, 1]
    +I[user9, city9, 28, 1]
    +I[user7, city7, 26, 1]
    +I[user8, city8, 27, 0]
    +I[user2, city2, 21, 0]
