Updated on 2025-01-09 GMT+08:00
DROP COLUMN
Function
The ALTER TABLE ... DROP COLUMN command is used to delete a column.
Syntax
ALTER TABLE tableName DROP COLUMN|COLUMNS cols
Parameter Description
Table 1 DROP COLUMN parameters
tableName
Table name.
cols
Columns to be deleted. You can specify multiple columns.
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing ALTER TABLE
Permission Description
ALTER permission on a table
  • Fine-grained permission: dli:table:alter
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
ALTER TABLE table1 DROP COLUMN a.b.c
ALTER TABLE table1 DROP COLUMNS a.b.c, x, y
a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
Response
You can run the DESCRIBE command to check which column is deleted.
