Updated on 2025-01-09 GMT+08:00
DESCRIBE
Function
This command shows detailed information or statistics about a table.
Syntax
Show statistics about a table:
DESCRIBE [EXTENDED|FORMATTED] [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`;
Show detailed information about a table:
DESCRIBE DETAIL [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`;
Required Permissions
  • SQL permissions
Table 1 Permissions required for executing DESCRIBE
Permission Description
DESCRIBE_TABLE permission on a table
  • Fine-grained permission: dli:table:describeTable
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
DESCRIBE FORMATTED delta_table0;
DESCRIBE FORMATTED delta.`obs://bucket_name0/db0/delta_table0`;
DESCRIBE DETAIL delta_table0;
System Response
Returns details or statistics about a table.
Table 2 Result parameters
format
Format of the table, which is delta in this example
id
Unique ID of the table
name
Table name defined in MetaServer
description
Description about the table
location
Storage path of the table
createdAt
Timestamp when the table was created
lastModified
Timestamp when the table was last modified
partitionColumns
Partition column
numFiles
Number of files in the latest version of the table
sizeInBytes
Size of the latest snapshot of the table, in bytes
properties
All the attributes set for this table
minReaderVersion
Earliest reader version that can read the table
minWriterVersion
Earliest writer version that can write the table
