Submitting a Spark Job Using an SDK
This section describes how to submit a Spark job using DLI SDK V2.
DLI SDK V2 is currently in the limited use phase. To use it, submit a service ticket.
- Starting May 2024, users who use DLI for the first time can directly use DLI SDK V2 without applying for it.
- For users who started using DLI before May 2024, to use this function, they must submit a service ticket to apply for it.
Preparations
Obtain an AK/SK, project ID, and region information.
- In the upper right corner, hover over the username and choose My Credentials from the drop-down list.
- In the navigation pane on the left, choose Access Keys. On the displayed page, click Create Access Key. Confirm that you want to proceed with the operation and click OK.
- On the displayed page, click Download. Open the file to obtain the AK/SK information.
- In the navigation pane on the left, choose API Credentials. In the Projects pane, locate project_id and obtain the region information.
Example Code
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 | private static final Logger logger = LoggerFactory.getLogger(SparkJobExample.class); public static void main(String[] args) { String yourAccessKey = System.getenv("HUAWEICLOUD_SDK_AK"); String yourSecretKey = System.getenv("HUAWEICLOUD_SDK_SK"); DliClient dliClient = DliClient.newBuilder() .withRegion(DliRegion.valueOf("RegionName")) .withCredential(new BasicCredentials() .withAk(yourAccessKey) .withSk(yourSecretKey) .withProjectId("YouProjectId")) .build(); try { // Step 1: Submit a Spark job to DLI for execution. String jobId = runSparkJob(dliClient, "YourQueueName"); // Step 2: If you wish to wait for the job execution to finish within the current thread, cycle through checking the status until the job completes. checkRunning(dliClient, jobId); // Step 3: To query one or more specific jobs based on conditions, use the following method: // This is an example. In addition to jobId, you can also specify other filter criteria. For details, see Table 2 in https://console.huaweicloud.com/apiexplorer/#/openapi/DLI/doc?api=ListSparkJobs. listSparkJob(dliClient, jobId); /* * Other scenarios: * 1. During job execution, if you wish to cancel the job, you can call the API to cancel the batch processing job. * Key SDK API: com.huaweicloud.sdk.dli.v1.DliClient#cancelSparkJob(CancelSparkJobRequest), * Note: Batch processing jobs in the Successful or Failed state cannot be canceled. * 2. To query details about a specific job based on the job ID, perform the following operations: * Key SDK API: com.huaweicloud.sdk.dli.v1.DliClient#showSparkJob(ShowSparkJobRequest), */ } catch (DLIException e) { // Handle the exception based on service requirements. The following is an example. } } |
Creating a Spark Job
- Function:
Execute Spark jobs.
- Reference link:
Key SDK API: com.huaweicloud.sdk.dli.v1.DliClient#createSparkJob(CreateSparkJobRequest)
- Sample code:
private static String runSparkJob(DliClient client, String queueName) { // Set the parameters according to the actual situation. The following is an example. Map<String, Object> confMap = new HashMap<>(); confMap.put("SparkConfKey", "SparkConfValue"); CreateSparkJobResponse resp = client.createSparkJob(new CreateSparkJobRequest() .withBody(new CreateSparkJobRequestBody() .withQueue(queueName) .withSparkVersion("2.4.5") .withName("demo_spark_app") .withFile("obs://your_bucket/your_spark_app.jar") // Mandatory .withClassName("YourClassFullName") // Mandatory .withArgs(Arrays.asList("YourAppArg1", "YourAppAgr2", "...")) .withConf(confMap) .withJars(Arrays.asList("YourDepJar1", "YourDepJar2", "...")) .withDriverCores(2) .withDriverMemory("8GB") .withNumExecutors(3) .withExecutorCores(4) .withExecutorMemory("16GB"))); return resp.getId(); }
Querying the Status of a Batch Processing Job
- Function:
Execute Spark jobs.
- Reference link:
Key SDK API: com.huaweicloud.sdk.dli.v1.DliClient#showSparkJobStatus(ShowSparkJobStatusRequest)
- Sample code:
private static void checkRunning(DliClient client, String jobId) throws DLIException { while (true) { ShowSparkJobStatusResponse resp; try { resp = client.showSparkJobStatus(new ShowSparkJobStatusRequest().withBatchId(jobId)); } catch (Exception e) { throw new DLIException("Failed to get job status by id: " + jobId, e); } String status = resp.getState(); logger.info(String.format("SparkJob id %s status: %s", jobId, status)); if ("success".equals(status)) { return; } if ("dead".equals(status)) { throw new DLIException("Run job failed"); } try { Thread.sleep(1000L); } catch (InterruptedException e) { throw new DLIException("Check job running interrupted."); } } }
Querying the Batch Processing Job List
- Function:
Query the batch processing job list.
- Reference link:
Key SDK API: com.huaweicloud.sdk.dli.v1.DliClient#listSparkJobs(ListSparkJobsRequest)
- Sample code:
private static void listSparkJob(DliClient client, String jobId) throws DLIException { ListSparkJobsResponse resp; try { resp = client.listSparkJobs(new ListSparkJobsRequest() // You can also use the .withXxx() method to specify other criteria to return Spark jobs that meet the criteria. This is an example. // See Table 2 in https://console.huaweicloud.com/apiexplorer/#/openapi/DLI/doc?api=ListSparkJobs. .withJobId(jobId) .withQueueName("YourQueueName") .withStart(1234567L) // You can specify the job start time. .withEnd(2345678L)); // You can specify the job end time. } catch (Exception e) { throw new DLIException("Failed to list Spark jobs: ", e); } logger.info(String.format("List SparkJobs : %s", resp.toString())); // For details about the response parameters in resp, see Table 3 and Table 4 in https://console.huaweicloud.com/apiexplorer/#/openapi/DLI/doc?api=ListSparkJobs. }
