Table-Related SDKs
Updated on 2025-02-11 GMT+08:00
Creating a DLI Table
DLI provides an API for creating DLI tables. Sample code is as follows:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
def create_dli_tbl(dli_client, db_name, tbl_name):
    cols = [
        Column('col_1', 'string'),
        Column('col_2', 'string'),
        Column('col_3', 'smallint'),
        Column('col_4', 'int'),
        Column('col_5', 'bigint'),
        Column('col_6', 'double'),
        Column('col_7', 'decimal(10,0)'),
        Column('col_8', 'boolean'),
        Column('col_9', 'date'),
        Column('col_10', 'timestamp')
    sort_cols = ['col_1']
    tbl_schema = TableSchema(tbl_name, cols, sort_cols)
    try:
        table = dli_client.create_dli_table(db_name, tbl_schema)
    except DliException as e:
        print(e)
        return
    print(table)
For details about the dependencies and complete sample code, see Overview.
Creating an OBS Table
DLI provides an API for creating OBS tables. The example code is as follows:
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
def create_obs_tbl(dli_client, db_name, tbl_name):
    cols = [
    tbl_schema = TableSchema(tbl_name, cols)
    try:
        table = dli_client.create_obs_table(db_name, tbl_schema,
                                            'obs://bucket/obj',
                                            'csv')
        print(e)
        return
    print(table)
  • You need to create an OBS path in advance and specify it when creating an OBS table.
  • For details about the dependencies and complete sample code, see Overview.
Deleting a Table
DLI provides an API for deleting tables. The example code is as follows:
3
4
5
6
7
8
def delete_tbls(dli_client, db_name):
    try:
        tbls = dli_client.list_tables(db_name)
        for tbl in tbls:
            dli_client.delete_table(db_name, tbl.name)
        print(e)
        return
  • A deleted table cannot be restored. Exercise caution when deleting a table.
Querying All Tables
DLI provides an API for querying tables. The example code is as follows:
3
4
5
6
7
8
9
def list_all_tbls(dli_client, db_name):
    try:
        tbls = dli_client.list_tables(db_name, with_detail=True)
        print(e)
        return
    for tbl in tbls:
        print(tbl.name)
Describing Table Information
You can call an API to obtain the metadata description of a table. The sample code is as follows:
def get_table_schema(dli_client, db_name, tbl_name):
 try:
        table_info = dli_client.get_table_schema(db_name, tbl_name)
        print(table_info)
        print(e)
        return
