Database-Related SDKs
Creating a Database
DLI provides an API for creating a database. You can use the API to create a database. The sample code is as follows:
1 2 3 4 5 6 7 8 |
def create_db(dli_client): try: db = dli_client.create_database('db_for_test') except DliException as e: print(e) return print(db) |
- The default database is a built-in database. You are not allowed to create a database named default.
- For details about the dependencies and complete sample code, see Overview.
Deleting a Database
DLI provides an API for deleting a database. The example code is as follows:
1 2 3 4 5 6 |
def delete_db(dli_client, db_name): try: dli_client.delete_database(db_name) except DliException as e: print(e) return |
- A database that contains tables cannot be deleted. To delete a database that contains tables, delete the tables first.
- A deleted database cannot be restored. Therefore, exercise caution when deleting a database.
Querying All Databases
DLI provides an API for querying the database list. The example code is as follows:
1 2 3 4 5 6 7 8 9 |
def list_all_dbs(dli_client): try: dbs = dli_client.list_databases() except DliException as e: print(e) return for db in dbs: print(db) |
