Initiating a Multipart Upload (SDK for Python)
Function
This API initiates a multipart upload and returns a globally unique upload ID. You can use the returned upload ID when you later upload, assemble, or list parts. A single object can be involved in multiple multipart uploads. Each multipart upload initiation request can contain additional headers such as acl, metadata, contentType, and encoding_type. These headers are recorded in the multipart upload metadata.
Restrictions
- To initiate a multipart upload, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- After initiating a multipart upload and uploading one or more parts, you must assemble the parts or abort the multipart upload. Only after that can OBS stops billing you for storing the uploaded parts.
Method
ObsClient.initiateMultipartUpload(bucketName, objectKey, acl, storageClass, metadata, websiteRedirectLocation, contentType, sseHeader, expires, extensionGrants, extensionHeaders)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | str | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| objectKey | str | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| acl | str | No | Explanation: ACL that can be pre-defined when a bucket is created. For details about ACLs, see ACLs. Value range: For details about the available options, see HeadPermission. Default value: PRIVATE |
| storageClass | str | No | Explanation: Object storage class. If this parameter is not set, the object inherits the storage class of its bucket. Value range: See Table 3. Default value: STANDARD |
| metadata | dict | No | Explanation: Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
| websiteRedirectLocation | str | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
| contentType | str | No | Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Python SDK) Default value: If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter. |
| sseHeader | No | Explanation: Server-side encryption header. If SSE-C is used, see Table 4. If SSE-KMS is used, see Table 5. Default value: None | |
| expires | int | No | Explanation: Expiration time of the object (calculated from the latest modification time of the object). Expired objects are automatically deleted. Restrictions: This parameter can be configured only when uploading the object. It cannot be modified by calling a metadata modification API. Value range: An integer greater than or equal to 0, in days Default value: None |
| extensionGrants | list of ExtensionGrant | No | Explanation: List of the extended permissions for the object. For details, see Table 6. Default value: None |
| extensionHeaders | dict | No | Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None |
| encoding_type | str | No | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
| Constant | Default Value | Description |
| HeadPermission.PRIVATE | private | Private read/write A bucket or object can only be accessed by its owner. |
| HeadPermission.PUBLIC_READ | public-read | Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket. If it is granted on an object, anyone can read the content and metadata of the object. |
| HeadPermission.PUBLIC_READ_WRITE | public-read-write | Public read/write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If it is granted on an object, anyone can read the content and metadata of the object. |
| HeadPermission.PUBLIC_READ_DELIVERED | public-read-delivered | Public read on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket. NOTE: PUBLIC_READ_DELIVERED cannot be applied to objects. |
| HeadPermission.PUBLIC_READ_WRITE_DELIVERED | public-read-write-delivered | Public read/write on a bucket as well as objects in the bucket If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket. NOTE: PUBLIC_READ_WRITE_DELIVERED cannot be applied to objects. |
| HeadPermission.BUCKET_OWNER_FULL_CONTROL | bucket-owner-full-control | If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. |
| Parameter | Type | Description |
| STANDARD | Standard storage class | Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
| WARM | Infrequent Access storage class | Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
| COLD | Archive storage class | Explanation: Used for storing rarely accessed (once a year) data. |
| INTELLIGENT_TIERING | Intelligent Tiering | Explanation: Is designed to optimize storage costs by automatically moving data to a more economical access tier when data access patterns change. This storage class is ideal for data with constantly changing or unpredictable access patterns. |
| encryption | str | Yes | Explanation: SSE-C used for encrypting objects Value range: AES256 Default value: None |
| key | str | Yes | Explanation: Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm. Value range: The value must contain 32 characters. Default value: None |
| encryption | str | Yes | Explanation: SSE-KMS used for encrypting objects Value range: kms Default value: None |
| key | str | No | Explanation: Master key used in SSE-KMS Value range: The following two formats are supported:
In the preceding formats:
Default value:
| granteeId | str | No | Explanation: Account (domain) ID of the grantee Value range: To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python) Default value: None |
| permission | str | No | Explanation: Granted permissions. For details, see Table 7. Default value: None |
| Constant | Description |
| READ | Read permission A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
| WRITE | Write permission A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. Such permission for an object is not applicable. |
| READ_ACP | Permission to read ACL configurations A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for the bucket or object permanently. |
| WRITE_ACP | Permission to modify ACL configurations A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for the bucket or object permanently. A grantee with this permission can modify the ACL, thus obtaining full access permissions. |
| FULL_CONTROL | Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
Responses
| Explanation: SDK common results |
| status | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| reason | str | Explanation: Reason description. Default value: None |
| errorCode | str | Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| errorMessage | str | Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| requestId | str | Explanation: Request ID returned by the OBS server Default value: None |
| indicator | str | Explanation: Error indicator returned by the OBS server. Default value: None |
| hostId | str | Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
| resource | str | Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
| header | list | Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
| body | object | Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
| GetResult.body Type | Description |
| Explanation: Response to the request for initiating a multipart upload. For details, see Table 11. |
| bucketName | str | Explanation: Name of the bucket involved in the multipart upload Restrictions:
| objectKey | str | Explanation: Name of the object to be uploaded. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| uploadId | str | Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8 Value range: The value must contain 1 to 32 characters. Default value: None |
| sseKms | str | Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms Default value: None |
| sseKmsKey | str | Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
Default value:
| sseC | str | Explanation: Algorithm used to encrypt and decrypt objects with SSE-C Value range: AES256 Default value: None |
| sseCKeyMd5 | str | Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
| encoding_type | str | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
Code Examples
This example initiates a multipart upload for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 | from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" objectKey = "objectname" # Specify a pre-defined ACL (PRIVATE as an example). acl = 'PRIVATE' # Specify a storage class (STANDARD as an example) for the object. storageClass = 'STANDARD' # Specify a custom metadata of the object. metadata = {'key': 'value'} # Specify the MIME type for the object. contentType = 'text/plain' # Specify the lifecycle (7 as an example) for the object, in days. expires = 7 # Initiate a multipart upload. resp = obsClient.initiateMultipartUpload(bucketName, objectKey, acl, storageClass, metadata, contentType=contentType, expires=expires, encoding_type='url') # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Initiate Multipart Upload Succeeded') print('requestId:', resp.requestId) print('bucketName:', resp.body.bucketName) print('objectKey:', resp.body.objectKey) print('uploadId:', resp.body.uploadId) else: print('Initiate Multipart Upload Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Initiate Multipart Upload Failed') print(traceback.format_exc()) |
