Downloading an Object - Binary (SDK for Python)
Function
This API downloads a file using a stream from OBS to your local computer. If loadStreamInMemory is set to True, downloadpath will be invalid. The binary stream of the file will be downloaded to the local computer.
Restrictions
- To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- Objects in the Archive storage class can be downloaded only when they are restored.
Method
ObsClient.getObject(bucketName, objectKey, downloadPath, getObjectRequest, headers, loadStreamInMemory, progressCallback, extensionHeaders)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | str | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| objectKey | str | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| downloadPath | str | No | Explanation: The download path with the file name contained, for example, aa/bb.txt. Default value: None |
| getObjectRequest | No | Explanation: Additional parameters of an object download request Value range: See Table 2. Default value: None | |
| headers | No | Explanation: Headers in the request used for obtaining the storage class, redundancy policy, and other basic information about the object Value range: See Table 3. Default value: None | |
| loadStreamInMemory | bool | No | Explanation: Whether to load the data stream of the object to memory Value range: True: The obtained data stream is loaded to memory with downloadPath ignored. False: The obtained data stream is not loaded to memory. Default value: False |
| progressCallback | callable | No | Explanation: Callback function for obtaining the download progress Default value: None NOTE: This function contains the following parameters in sequence: number of downloaded bytes, total number of bytes, and used time (in seconds). For details about the sample code, see Downloading an Object - Obtaining the Download Progress (SDK for Python). |
| extensionHeaders | dict | No | Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None |
| cache_control | str | No | Explanation: Cache-Control is rewritten in the response. Default value: None |
| content_disposition | str | No | Explanation: Content-Disposition is rewritten in the response. Default value: None |
| content_encoding | str | No | Explanation: Content-Encoding is rewritten in the response. Default value: None |
| content_language | str | No | Explanation: Content-Language is rewritten in the response. Default value: None |
| content_type | str | No | Explanation: Content-Type is rewritten in the response. Default value: None |
| expires | str | No | Explanation: Expires is rewritten in the response. Default value: None |
| versionId | str | No | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9 Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is obtained. |
| imageProcess | str | No | Explanation: Image processing command or style. Example for resizing and rotating an image: image/resize,m_fixed,w_100,h_100/rotate,90 Value range: Command format: image/commands Style format: style/style name For details about image processing parameters, see Processing Images. Default value: If no commands are entered, the original image will be returned. |
| range | str | No | Explanation: Download range. For example, 0-999 indicates the download range is from byte 1 to byte 1,000. Value range: Value range: 0 to the object length minus 1. Format: x-y, indicating the range is from byte x+1 to byte y+1 Restrictions: The upper limit of range is the length of the object minus 1. If the specified value exceeds this limit, the length of the object minus 1 is used. Default value: None |
| if_match | str | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
| if_none_match | str | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
| if_modified_since | str or | No | Explanation: The object is returned if it has been modified since the specified time; otherwise, an error is returned. Restrictions: The value must be in the GMT format. For example, Wed, 25 Mar 2020 02:39:52 GMT. You can refer to Table 4 to specify time. For example, DateTime(year=2023, month=9, day=12) Default value: None |
| if_unmodified_since | str or | No | Explanation: The object is returned if it has not been modified since the specified time; otherwise, an error is returned. Restrictions: The value must be in the GMT format. For example, Wed, 25 Mar 2020 02:39:52 GMT. You can refer to Table 4 to specify time. For example, DateTime(year=2023, month=9, day=12) Default value: None |
| origin | str | No | Explanation: Origin of the cross-domain request specified by the preflight request. Generally, it is a domain name. Restrictions: Each origin can contain only one wildcard character (*). Default value: None |
| requestHeaders | str | No | Explanation: HTTP headers in a cross-origin request Only CORS requests matching the allowed headers are valid. Restrictions: Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
| sseHeader | No | Explanation: Server-side decryption headers. For details, see Table 5. Restrictions: If the object uploaded to the server is encrypted on the server using the encryption key provided by the client, downloading the object requires including the encryption key in the message. Default value: None |
| Parameter | Type | Description |
| year | int | Explanation: Year in UTC Default value: None |
| month | int | Explanation: Month in UTC Default value: None |
| day | int | Explanation: Day in UTC Default value: None |
| hour | int | Explanation: Hour in UTC Restrictions: The value is in 24-hour format. Default value: 0 |
| min | int | Explanation: Minute in UTC Default value: 0 |
| sec | int | Explanation: Second in UTC Default value: 0 |
| encryption | str | Yes | Explanation: SSE-C used for encrypting objects Value range: AES256 Default value: None |
| key | str | Yes | Explanation: Key used in SSE-C encryption. It corresponds to the encryption method. For example, if encryption is set to AES256, the key is calculated using the AES-256 algorithm. Value range: The value must contain 32 characters. Default value: None |
Responses
| Explanation: SDK common results |
| status | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| reason | str | Explanation: Reason description. Default value: None |
| errorCode | str | Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| errorMessage | str | Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| requestId | str | Explanation: Request ID returned by the OBS server Default value: None |
| indicator | str | Explanation: Error indicator returned by the OBS server. Default value: None |
| hostId | str | Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
| resource | str | Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
| header | list | Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
| body | object | Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
| GetResult.body Type | Description |
| Explanation: Response to the request for downloading an object |
| response | object | Explanation: If loadStreamInMemory is set to False and downloadPath is left blank in the request, this parameter is returned and indicates a readable stream. You can read object content from it. Default value: None |
| buffer | object | Explanation: If loadStreamInMemory is set to True in the request, this parameter is returned and indicates the data stream in the memory. Default value: None |
| size | int | Explanation: If loadStreamInMemory is set to True in the request, this parameter is returned and indicates the size of the data stream. Value range: An integer greater than or equal to 0, in bytes Default value: None |
| url | str | Explanation: If loadStreamInMemory is set to False and downloadPath is not left blank, this parameter is returned and indicates the download path. Default value: None |
| deleteMarker | bool | Explanation: Whether the deleted object is a delete marker Value range:
| storageClass | str | Explanation: Object storage class. Value range:
| accessContorlAllowOrigin | str | Explanation: If Origin in the request meets the CORS rules of the bucket, AllowedOrigin in the CORS rules is returned. AllowedOrigin indicates the origin from which the requests can access the bucket. Restrictions: Domain name of the origin. Each origin can contain only one wildcard character (*), for example, https://*.vbs.example.com. Default value: None |
| accessContorlAllowHeaders | str | Explanation: If RequestHeader in the request meets the CORS rules of the bucket, AllowedHeader in the CORS rules is returned. AllowedHeader indicates the allowed headers for cross-origin requests. Only CORS requests matching the allowed headers are valid. Restrictions: Each header can contain only one wildcard character (*). Spaces, ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
| accessContorlAllowMethods | str | Explanation: AllowedMethod in the CORS rules of the bucket. It specifies the HTTP method of cross-origin requests, that is, the operation type of buckets and objects. Value range: The following HTTP methods are supported:
| accessContorlExposeHeaders | str | Explanation: ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, your browser can only access headers Content-Length and Content-Type. If your browser needs to access other headers, add them to a list of the allowed additional headers. Restrictions: Spaces, wildcard characters (*), ampersands (&), colons (:), and less-than signs (<) are not allowed. Default value: None |
| accessContorlMaxAge | int | Explanation: MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request. Restrictions: Each CORS rule can contain only one MaxAgeSeconds. Value range: An integer greater than or equal to 0, in seconds Default value: 100 |
| contentLength | int | Explanation: Object size Value range: The value ranges from 0 TB to 48.8 TB, in bytes. Default value: None |
| cacheControl | str | Explanation: Cache-Control header in the response Default value: None |
| contentDisposition | str | Explanation: Content-Disposition header in the response Default value: None |
| contentEncoding | str | Explanation: Content-Encoding header in the response Default value: None |
| contentLanguage | str | Explanation: Content-Language header in the response Default value: None |
| contentType | str | Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Python SDK) Default value: None |
| expires | str | Explanation: Expires header in the response Default value: None |
| lastModified | str | Explanation: Time when the last modification was made to the object Restrictions: The time must be in the GMT format, for example, Wed, 25 Mar 2020 02:39:52 GMT. Default value: None |
| etag | str | Explanation: Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object contents and is used to determine whether the contents of an object are changed. For example, if the ETag value is A when an object is uploaded and is B when the object is downloaded, this indicates the contents of the object are changed. The ETag reflects changes only to the contents of an object, not its metadata. Objects created by the upload and copy operations have unique ETags after being encrypted using MD5. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
| versionId | str | Explanation: Object version ID. Value range: The value must contain 32 characters. Default value: None |
| restore | str | Explanation: Restore status of an object. This header is returned when an Archive object is being restored or has been restored. For example, ongoing-request="true" indicates that the object is being restored. ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" indicates that the object has been restored. expiry-date indicates when the restored object expires. Restrictions: This parameter is only available for Archive objects. Default value: None |
| expiration | str | Explanation: Expiration details Example: "expiry-date=\"Mon, 11 Sep 2023 00:00:00 GMT\"" Default value: None |
| sseKms | str | Explanation: Objects are encrypted using SSE-KMS on the server side. Value range: kms Default value: None |
| sseKmsKey | str | Explanation: ID of the KMS master key when SSE-KMS is used Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
| sseC | str | Explanation: SSE-C algorithm Value range: AES256 Default value: None |
| sseCKeyMd5 | str | Explanation: MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Default value: None |
| websiteRedirectLocation | str | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
| STANDARD | Standard storage class | Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
| WARM | Infrequent Access storage class | Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
| COLD | Archive storage class | Explanation: Used for storing rarely accessed (once a year) data. |
| INTELLIGENT_TIERING | Intelligent Tiering | Explanation: Is designed to optimize storage costs by automatically moving data to a more economical access tier when data access patterns change. This storage class is ideal for data with constantly changing or unpredictable access patterns. |
Code Examples
This example downloads an object in binary mode.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 | from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName="examplebucket" objectKey="objectname" # If loadStreamInMemory is set to True, downloadpath will be invalid. The binary stream of the file will be downloaded to the memory. #Download an object in a binary stream. resp = obsClient.getObject(bucketName=bucketName,objectKey=objectKey, loadStreamInMemory=True) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Get Object Succeeded') print('requestId:', resp.requestId) # Obtain the object content. print('buffer:', resp.body.buffer) print('size:', resp.body.size) else: print('Get Object Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Get Object Failed') print(traceback.format_exc()) |
In a binary download, if loadStreamInMemory is set to True, the object content is contained in the body.buffer parameter in the returned result.
