Configuring Bucket Encryption (SDK for Python)
Function
After you enable encryption for a bucket, the objects you upload to this bucket will be encrypted with the specified encryption method before they are stored in OBS. When you later download these encrypted objects, OBS decrypts them first and then returns them to you.
This API configures or updates encryption for a bucket.
Restrictions
- To configure encryption for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutEncryptionConfiguration in IAM or PutEncryptionConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketEncryption(bucketName, encryption, key, extensionHeaders)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | str | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| encryption | str | Yes | Explanation: Server-side encryption method. Value range:
| key | str | No | Explanation: KMS master key used for SSE-KMS Value range: Valid value formats are as follows:
In the preceding formats:
Default value: If this parameter is not specified, the default master key will be used. |
| extensionHeaders | dict | No | Explanation: Extension headers. Value range: See User-defined Headers (SDK for Python). Default value: None |
Responses
| Type | Description |
| Explanation: SDK common results |
| Parameter | Type | Description |
| status | int | Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| reason | str | Explanation: Reason description Default value: None |
| errorCode | str | Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| errorMessage | str | Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
| requestId | str | Explanation: Request ID returned by the OBS server Default value: None |
| indicator | str | Explanation: Error indicator returned by the OBS server Default value: None |
| hostId | str | Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
| resource | str | Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
| header | list | Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
| body | object | Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, this parameter is left blank. The value varies with the API being called. For details, see the sections "Bucket-Related APIs" and "Object-Related APIs". Default value: None |
Code Examples
This example configures encryption for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 | import os import traceback from obs import ObsClient, CustomDomainConfiguration # Obtain an AK/SK pair using environment variables (recommended) or import it in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # If you use a temporary AK/SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK/SK pair and a security token to access OBS, you must specify security_token when creating an instance. obs_client = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucket_name = 'examplebucket' # Specify the encryption method. SSE-KMS is used as an example. encryption = 'kms' # (Optional) KMS master key used for SSE-KMS # key = 'key_id' resp = obs_client.setBucketEncryption(bucket_name, encryption) # If status code 2xx is returned, the API call succeeds. Otherwise, the API call fails. if resp.status < 300: print('Set Bucket Encryption Succeeded') print('requestId:', resp.requestId) else: print('Set Bucket Encryption Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except Exception: print('Set Bucket Encryption Failed') print(traceback.format_exc()) |
