Updated on 2026-09-20 GMT+08:00
Before You Start
- Make sure that you are familiar with basic OBS concepts, such as buckets, objects, access keys (AKs/SKs), and endpoints and domain names.
- Some features are available only in certain regions. If the HTTP status code 405 is returned when you call an API, check whether the feature is supported in the region. For details, refer to Functions or submit a service ticket to contact technical support.
The following table lists the feature changes for the Node.js SDK.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
