Initiating a Multipart Upload (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API initiates a multipart upload and returns a globally unique upload ID. You can use this upload ID in your subsequent requests for uploading, assembling, and listing parts. Initiating multipart upload tasks do not affect existing objects with the same names as the involved objects in those tasks. There can be more than one multipart upload for the same object. Each multipart upload initiation request can contain additional headers such as contentType, contentEncoding, and the headers for ACL and custom metadata. These headers are recorded in the multipart upload metadata. After the API for initiating a multipart upload is successfully called, an upload ID will be returned. This ID will be used in subsequent operations.
Restrictions
- To initiate a multipart upload, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
- After a multipart upload was initiated and one or more parts have been uploaded, you will be charged for storing these parts until you complete or cancel the upload.
Method
ObsClient.initiateMultipartUpload(params)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
Bucket | string | Yes | Explanation: Bucket name Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
ACL | No | Explanation: An access control list (ACL) that can be pre-defined when creating a bucket. For details about ACLs, see ACLs. Restrictions: None Value range: See Table 2. Default value: private | |
WebsiteRedirectLocation | string | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Value range: None Restrictions:
ContentType | string | No | Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Restrictions: None Value range: See What Is Content-Type (MIME)? (SDK for Node.js) Default value: If you do not specify this parameter when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to this parameter. |
StorageClass | No | Explanation: Object storage class. If this parameter is not specified, the object inherits the storage class of its bucket. Restrictions: None Value range: See Table 3. Default value: STANDARD | |
Metadata | object | No | Explanation: Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
Value range: None Default value: None |
GrantRead | string | No | Explanation: ID (domain_id) of an account the READ permission is granted to. The account with the READ permission can read the current object and obtain its metadata. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
GrantReadAcp | string | No | Explanation: ID (domain_id) of an account the READ_ACP permission is granted to. The account with the READ_ACP permission can read the ACL of the current object. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
GrantWriteAcp | string | No | Explanation: ID (domain_id) of an account the WRITE_ACP permission is granted to. The account with the WRITE_ACP permission can modify the ACL of the current object. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
GrantFullControl | string | No | Explanation: ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission can read the current object, obtain its metadata, and obtain and modify its ACL. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
Expires | number | No | Explanation: Expiration time of the object (calculated from the latest modification time of the object). Expired objects are automatically deleted. Restrictions:
Value range: 1 to (263 - 1), in days Default value: None |
SseKms | string | Yes when SSE-KMS is used | Explanation: SSE-KMS is used for encrypting objects on the server side. Restrictions: Currently, only KMS is supported. Value range: kms Default value: None |
SseKmsKey | string | No | Explanation: ID of the KMS master key when SSE-KMS is used. Restrictions: Valid value formats are as follows:
In the preceding formats:
SseC | string | Yes when SSE-C is used | Explanation: SSE-C is used for encrypting objects on the server side. Restrictions: Only AES256 is supported. Value range: AES256 Default value: None |
SseCKey | string | Yes when SSE-C is used | Explanation: Key used for encrypting the object when SSE-C is used Restrictions: A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw= Value range: None Default value: None |
EncodingType | string | No | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied. |
Constant | Default Value | Description |
ObsClient.enums.AclPrivate | private | Private read and write A bucket or object can only be accessed by its owner. |
ObsClient.enums.AclPublicRead | public-read | Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket. If this permission is granted on an object, everyone can obtain the content and metadata of the object. |
ObsClient.enums.AclPublicReadWrite | public-read-write | Public read and write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, everyone can obtain the content and metadata of the object. |
ObsClient.enums.AclPublicReadDelivered | public-read-delivered | Public read on a bucket as well as the objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions and read the content and metadata of objects in the bucket. NOTE: AclPublicReadDelivered does not apply to objects. |
ObsClient.enums.AclPublicReadWriteDelivered | public-read-write-delivered | Public read and write on a bucket as well as the objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket. NOTE: AclPublicReadWriteDelivered does not apply to objects. |
ObsClient.enums.AclBucketOwnerFullControl | bucket-owner-full-control | If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this policy to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets the bucket-owner-full-control policy for object x, user B then has the control over object x. |
ObsClient.enums.StorageClassStandard | STANDARD | Standard storage class. Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
ObsClient.enums.StorageClassWarm | WARM | Infrequent Access storage class. Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed. |
ObsClient.enums.StorageClassCold | COLD | Archive storage class. Used for storing rarely accessed (once a year) data. |
Responses
Type | Description |
NOTE: This API returns a Promise response, which requires the Promise or async/await syntax. | Explanation: Returned results. For details, see Table 5. |
Parameter | Type | Description |
CommonMsg | Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 6. | |
InterfaceResult | Explanation: Results outputted for a successful call. For details, see Table 7. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Status | number | Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code | string | Explanation: Error code returned by the OBS server. |
Message | string | Explanation: Error description returned by the OBS server. |
HostId | string | Explanation: Request server ID returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server. |
Id2 | string | Explanation: Request ID2 returned by the OBS server. |
Indicator | string | Explanation: Error code details returned by the OBS server. |
RequestId | string | Explanation: Request ID returned by the OBS server |
Bucket | string | Explanation: Name of the bucket involved in the multipart upload. |
Key | string | Explanation: Object name in the multipart upload. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. |
UploadId | string | Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8. |
SseKms | string | Explanation: SSE-KMS is used for encrypting objects on the server side. |
SseKmsKey | string | Explanation: ID of the KMS master key when SSE-KMS is used. |
SseC | string | Explanation: SSE-C is used for encrypting objects on the server side. |
SseCKeyMd5 | string | Explanation: MD5 value of the key used for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ== |
EncodingType | string | Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied. |
Code Examples
This example initiates a multipart upload for object example/objectname.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 | // Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function initiateMultipartUpload() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object (example/objectname in this example). Key: "example/objectname", }; // Initiate the multipart upload. const result = await obsClient.initiateMultipartUpload(params); if (result.CommonMsg.Status <= 300) { console.log("Initiate multipart upload successfully with bucket(%s) and object(%s)!", params.Bucket, params.Key); console.log("RequestId: %s", result.CommonMsg.RequestId); // A globally unique identifier of the multipart upload task, which will be used in uploading and assembling parts. console.log("UploadId: %s", result.InterfaceResult.UploadId); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; initiateMultipartUpload(); |
Helpful Links
