Updated on 2026-09-20 GMT+08:00
Configuring Object Metadata (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
Object metadata contains a set of name-value pairs that are used for describing and managing objects.
Currently, only the system-defined metadata is supported. System-defined metadata consists of system-controlled metadata and user-controlled metadata.
This API sends a HEAD request for obtaining object metadata.
Restrictions
Method
ObsClient.setObjectMetadata(params)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
MetadataDirective
MetadataDirectiveType
Yes
Explanation:
Policy for copying the source object's attributes
Restrictions:
None
Value range:
See Table 7.
Default value:
None
VersionId
string
No
Explanation:
Object version. Example: G001117FCE89978B0000401205D5DC9A
Restrictions:
None
Value range:
The value must contain 32 characters.
Default value:
None
CacheControl
string
No
Explanation:
Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded.
Restrictions:
None
Value range:
See the Cache-Control values defined in HTTP.
Default value:
None
ContentDisposition
string
No
Explanation:
Content-Disposition header in the response. It specifies the name of an object when it is downloaded.
Restrictions:
None
Value range:
See the Content-Disposition values defined in HTTP.
Default value:
None
ContentEncoding
string
No
Explanation:
Content-Encoding header in the response. It specifies the content encoding format when an object is downloaded.
Restrictions:
None
Value range:
See the Content-Encoding values defined in HTTP.
Default value:
None
ContentLanguage
string
No
Explanation:
Content-Language header in the response. It specifies what language the object content is in when being downloaded.
Restrictions:
None
Value range:
See the Content-Language values defined in HTTP.
Default value:
None
ContentType
string
No
Explanation:
Content-Type header in the response. It specifies the file type of an object when it is downloaded.
Restrictions:
None
Value range:
See What Is Content-Type (MIME)? (SDK for Node.js)
Default value:
None
Expires
string
No
Explanation:
Expires header in the response. It specifies the cache expiration time of the web page when the object is downloaded.
Restrictions:
None
Value range:
See the Expires values defined in HTTP.
Default value:
None
WebsiteRedirectLocation
string
No
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL.
The request is redirected to object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection of objects that are in the root directory.
Value range:
None
Default value:
None
StorageClass
StorageClassType
No
Explanation:
Storage class of the object.
Restrictions:
None
Value range:
See Table 2.
Default value:
None
Metadata
object
No
Explanation:
Custom metadata of the object. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata.
Restrictions:
  • The custom metadata cannot exceed 8 KB in total. To measure the size, calculate the sum of bytes of all UTF-8 encoded keys and values.
  • The custom metadata keys are case insensitive, but are stored in lowercase in OBS. The key values are case sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are required, they must be encoded and decoded in URL or Base64 on the client, because the server does not perform such operations.
Value range:
None
Default value:
None
Table 2 StorageClassType
Constant
Default Value
ObsClient.enums.StorageClassStandard
STANDARD
Standard storage class.
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
ObsClient.enums.StorageClassWarm
WARM
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
ObsClient.enums.StorageClassCold
COLD
Archive storage class.
Used for storing rarely accessed (once a year) data.
Responses
Table 3 Responses
Type
Table 4
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 4.
Table 4 Response
Type
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5.
InterfaceResult
Table 6
Explanation:
Results outputted for a successful call. For details, see Table 6.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 5 ICommonMsg
Type
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 6 SetObjectMetadataOutput
Type
RequestId
string
Explanation:
MetadataDirective
Explanation:
Value range:
See Table 7.
CacheControl
string
Explanation:
ContentDisposition
string
Explanation:
ContentEncoding
string
Explanation:
Content-Encoding header in the response. It specifies how the object is encoded when being downloaded.
ContentLanguage
string
Explanation:
ContentType
string
Explanation:
Expires
string
Explanation:
string
Explanation:
Restrictions:
StorageClass
StorageClassType
Explanation:
Storage class configured when copying the object. If this parameter is not specified, the object inherits the storage class of the bucket.
Value range:
See Table 8.
Metadata
object
Explanation:
Restrictions:
Table 7 MetadataDirectiveType
Constant
Default Value
ObsClient.enums.CopyMetadata
COPY
When copying an object, the object's attributes are also copied.
NOTICE:
This value is used only in the API for Copying an Object (SDK for Node.js).
ObsClient.enums.ReplaceMetadata
REPLACE
REPLACE uses the complete header carried in the current request to replace the original one and deletes the metadata that is not specified.
ObsClient.enums.ReplaceNewMetadata
REPLACE_NEW
REPLACE_NEW replaces the metadata that already has a value, assigns a value to the metadata that does not have a value, and retains the metadata that is not specified.
NOTICE:
This value is used only in the API for Configuring Object Metadata (SDK for Node.js).
Table 8 StorageClassType
Constant
Default Value
STANDARD
WARM
COLD
Code Examples
This example configures metadata for object example/objectname in bucket examplebucket. The MIME type of the object is set to image/jpeg, the storage class is set to Archive, and custom metadata is configured for the object.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function setObjectMetadata() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify an object. example/objectname is used in this example.
      Key: "example/objectname",
      // Specify a MIME type (image/jpeg in this example) for the object.
      ContentType: "image/jpeg",
      // Specify a storage class (obsClient.enums.StorageClassCold in this example) for the object.
      StorageClass: obsClient.enums.StorageClassCold,
      // Specify custom metadata.
      Metadata: { "property1": "property-value1", "property2": "property-value2" }
    // Configure the metadata for the object.
    const result = await obsClient.setObjectMetadata(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Set Object(%s)'s metadata successful with bucket(%s)!", params.Key, params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
setObjectMetadata();
