Uploading an Object - Streaming (SDK for Node.js)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API uploads an object to a bucket.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
- The object size in a single upload ranges from 0 to 5 GB.
- To upload files larger than 5 GB, refer to Multipart Upload APIs (SDK for Node.js).
Method
ObsClient.putObject(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key |
string |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
ACL |
No |
Explanation: Access control list (ACL) that can be pre-defined when an object is created. For details about ACLs, see ACLs. Restrictions: None Value range: See Table 2. Default value: None |
StorageClass |
No |
Explanation: When creating an object, you can use this header to specify the storage class for the object. Restrictions: None Value range: See Table 3. Default value: If this parameter is not specified, the object inherits the storage class of the bucket. |
Body |
string | stream.Readable |
No |
Explanation: Content of the part to upload, which can be in string or stream.Readable form. Restrictions:
Value range: None Default value: None |
SourceFile |
string |
No |
Explanation: Source file path of the object to be uploaded Restrictions:
Offset |
number |
No |
Explanation: Start offset of a part in the source file. Restrictions: Offset and SourceFile are used together to specify what data is uploaded from the source file. Value range: A non-negative integer smaller than the size of the object to be uploaded, in bytes Default value: 0 |
ProgressCallback |
function |
No |
Explanation: Callback function for obtaining the upload progress Restrictions: None Value range: None Default value: None
This callback function contains the following parameters in sequence: number of uploaded bytes, total bytes, and used time (in seconds). |
ContentMD5 |
string |
No |
Explanation: Base64-encoded MD5 value of the data to be uploaded. It is used for the OBS server to verify data integrity. Restrictions: Base64-encoded, 128-bit MD5 value of the request body. Value range: Base64-encoded, 128-bit MD5 value of the request body calculated based on the RFC 1864 standard. Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
WebsiteRedirectLocation |
string |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. The request is redirected to object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL: WebsiteRedirectLocation:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
ContentType |
string |
No |
Explanation: MIME type of the file to be uploaded. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Restrictions: None Value range: See What Is Content-Type (MIME)? (SDK for Node.js) Default value: If you do not specify Content-Type when uploading an object, the SDK determines the object type based on the suffix of the specified object name and automatically assigns a value to Content-Type. |
ContentLength |
int64 |
No |
Explanation: Size of the object to be uploaded. Restrictions:
Value range: 0 GB to 5 GB Default value: If this parameter is not specified, the SDK automatically calculates the size of the object. |
SseKms |
string |
Yes when SSE-KMS is used |
Explanation: SSE-KMS is used for encrypting objects on the server side. Restrictions: Currently, only KMS is supported. Value range: kms Default value: None |
SseKmsKey |
string |
No |
Explanation: ID of the KMS master key when SSE-KMS is used. Restrictions: Valid value formats are as follows:
In the preceding formats:
SseC |
string |
Yes when SSE-C is used |
Explanation: SSE-C is used for encrypting objects on the server side. Restrictions: Only AES256 is supported. Value range: AES256 Default value: None |
SseCKey |
string |
Explanation: Key used for encrypting the object when SSE-C is used Restrictions: A Base64-encoded, 256-bit value, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw= Value range: None Default value: None |
Metadata |
object |
No |
Explanation: Custom metadata of the object to be uploaded. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata. Restrictions:
GrantRead |
string |
No |
Explanation: ID (domain_id) of an account the READ permission is granted to. The account with the READ permission can read the current object and obtain its metadata. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
GrantReadAcp |
string |
No |
Explanation: ID (domain_id) of an account the READ_ACP permission is granted to. The account with the READ_ACP permission can read the ACL of the current object. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
GrantWriteAcp |
string |
No |
Explanation: ID (domain_id) of an account the WRITE_ACP permission is granted to. The account with the WRITE_ACP permission can modify the ACL of the current object. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
GrantFullControl |
string |
No |
Explanation: ID (domain_id) of an account the FULL_CONTROL permission is granted to. The account with the FULL_CONTROL permission can read the current object, obtain its metadata, and obtain and modify its ACL. Restrictions: Use commas (,) to separate multiple accounts. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? (Node.js SDK) Default value: None |
Expires |
number |
No |
Explanation: Expiration time of the object (calculated from the latest modification time of the object). Expired objects are automatically deleted. Restrictions:
Value range: 1 to (263 - 1), in days Default value: None |
Constant |
Default Value |
Description |
ObsClient.enums.AclPrivate |
private |
Private read and write A bucket or object can only be accessed by its owner. |
ObsClient.enums.AclPublicRead |
public-read |
Public read and private write If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket. If this permission is granted on an object, everyone can obtain the content and metadata of the object. |
ObsClient.enums.AclPublicReadWrite |
public-read-write |
Public read and write If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, everyone can obtain the content and metadata of the object. |
ObsClient.enums.AclPublicReadDelivered |
public-read-delivered |
Public read on a bucket as well as the objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions and read the content and metadata of objects in the bucket.
AclPublicReadDelivered does not apply to objects. |
ObsClient.enums.AclPublicReadWriteDelivered |
public-read-write-delivered |
Public read and write on a bucket as well as the objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
AclPublicReadWriteDelivered does not apply to objects. |
ObsClient.enums.AclBucketOwnerFullControl |
bucket-owner-full-control |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this policy to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets the bucket-owner-full-control policy for object x, user B then has the control over object x. |
Constant |
Default Value |
Description |
ObsClient.enums.StorageClassStandard |
STANDARD |
Standard storage class. Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
ObsClient.enums.StorageClassWarm |
WARM |
Infrequent Access storage class. Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed. |
ObsClient.enums.StorageClassCold |
COLD |
Archive storage class. Used for storing rarely accessed (once a year) data. |
Responses
Type |
Description |
This API returns a Promise response, which requires the Promise or async/await syntax. |
Explanation: Returned results. For details, see Table 5. |
Parameter |
Type |
Description |
CommonMsg |
Explanation: Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 6. |
InterfaceResult |
Explanation: Results outputted for a successful call. For details, see Table 7. Restrictions: This parameter is not included if the value of Status is greater than 300. |
Parameter |
Type |
Description |
Status |
number |
Explanation: HTTP status code returned by the OBS server. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
Code |
string |
Explanation: Error code returned by the OBS server. |
Message |
string |
Explanation: Error description returned by the OBS server. |
HostId |
string |
Explanation: Request server ID returned by the OBS server. |
RequestId |
string |
Explanation: Request ID returned by the OBS server. |
Id2 |
string |
Explanation: Request ID2 returned by the OBS server. |
Indicator |
string |
Explanation: Error code details returned by the OBS server. |
Parameter |
Type |
Description |
RequestId |
string |
Explanation: Request ID returned by the OBS server |
StorageClass |
Explanation: Object storage class. Value range:
VersionId |
string |
Explanation: Object version. If versioning is enabled for the bucket, the object version ID will be returned. |
ETag |
string |
Explanation: Base64-encoded, 128-bit MD5 value of an object. It uniquely identifies the content of an object and can be used to check the object integrity. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. |
SseKms |
string |
Explanation: SSE-KMS is used for encrypting objects on the server side. |
SseKmsKey |
string |
Explanation: ID of the KMS master key when SSE-KMS is used. |
SseC |
string |
Explanation: SSE-C is used for encrypting objects on the server side. |
SseCKeyMd5 |
string |
Explanation: MD5 value of the key used for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key. Restrictions: Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ== |
Constant |
Default Value |
Description |
STANDARD |
WARM |
COLD |
Code Examples: Uploading a Network Stream
Streaming upload uses stream.Readable as the data source of objects. This example uploads an object to bucket examplebucket using a stream.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getNetWorkStream() { // Define the network stream URL. const url = 'https://www.example.com'; // Import HTTP and HTTPS libraries. const http = require('http'); const https = require('https'); // Choose the corresponding library based on the URL. const request = url.startsWith('http') ? http : https; return new Promise((resolve, reject) => { request.get(url, res => { if (res.statusCode === 200) { resolve(res); } else { reject(res); }; }).on(reject); }); }; async function putObject() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object. example/objectname is used in this example. Key: "example/objectname", // Specify the network flow. Body: await getNetWorkStream() }; // Upload the object using the network stream. const result = await obsClient.putObject(params); if (result.CommonMsg.Status <= 300) { console.log("Put object(%s) under the bucket(%s) successful!!", params.Key, params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); console.log("StorageClass:%s, ETag:%s", result.InterfaceResult.StorageClass, result.InterfaceResult.ETag); return; }; console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; putObject(); |
Code Examples: Uploading a File Stream
This example uploads an object to bucket examplebucket using a file stream.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); async function getFileStream() { const fs = require('fs'); // Enter the complete local path of the file to be uploaded. // If no local path is specified, the system uploads the file from the local path of the project that the sample program belongs to by default. return fs.createReadStream('D:\\localpath\\examplefile.txt'); } async function putObject() { try { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify the object. example/objectname is used in this example. Key: "example/objectname", // Specify the file stream. Body: await getFileStream() }; // Upload the object using the file stream. const result = await obsClient.putObject(params); if (result.CommonMsg.Status <= 300) { console.log("Put bucket(%s) successful!", params.Bucket); console.log("RequestId: %s", result.CommonMsg.RequestId); return; } console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response."); console.log("Status: %d", result.CommonMsg.Status); console.log("Code: %s", result.CommonMsg.Code); console.log("Message: %s", result.CommonMsg.Message); console.log("RequestId: %s", result.CommonMsg.RequestId); } catch (error) { console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network."); console.log(error); }; }; putObject(); |
