Help Center/
      Object Storage Service/
        SDK Reference/
        Node.js/
        Getting Started (SDK for Node.js)/
      Before You Start (SDK for Node.js)
        Updated on 2024-11-13 GMT+08:00
  If you have any questions during development, post them on the Issues page of GitHub.
- Ensure that you are familiar with OBS basic concepts, such as buckets, objects, and access keys (AK and SK).
 - You can see General Ways to Use ObsClient (SDK for Node.js) to learn how to call OBS Node.js SDK APIs in a general manner.
 - ObsClient supports API calling results returned via a callback function or the Promise object.
 - Some features are available only in some regions. If an API call returns the 405 HTTP status code, check whether the region supports this feature.
   Parent topic: Getting Started (SDK for Node.js)
