Configuring Bucket Encryption (SDK for Java)
Function
After you enable encryption for a bucket, the objects you upload to this bucket will be encrypted with the specified encryption method before they are stored in OBS. When you later download these encrypted objects, OBS decrypts them first and then returns them to you. This API is used to configure or update encryption for a bucket.
Restrictions
- To configure encryption for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutEncryptionConfiguration in IAM or PutEncryptionConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.setBucketEncryption(SetBucketEncryptionRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for configuring encryption for a bucket. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
| bucketEncryption | Yes | Explanation: Bucket encryption configuration. Value range: For details, see Table 3. Default value: None |
| sseAlgorithm | Yes | Explanation: Server-side encryption method. Value range: See Table 4. Default value: None | |
| kmsKeyId | String | No | Explanation: KMS master key used for SSE-KMS. Value range: Valid value formats are as follows:
In the preceding formats:
Default value: If this parameter is not specified, the default master key will be used. |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.BucketEncryption;
import com.obs.services.model.SSEAlgorithmEnum;
public class SetBucketEncryption {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
// String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
// Obtain an endpoint using environment variables or import it in other ways.
// String endPoint = System.getenv("ENDPOINT");
// Create an ObsClient instance.
// Use a permanent AK/SK pair to initialize the client.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Use a temporary AK/SK pair and security token to initialize the client.
// ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
try {
String exampleBucket = "examplebucket";
// Specify the encryption method. SSE-KMS is used as an example.
BucketEncryption encryption = new BucketEncryption(SSEAlgorithmEnum.KMS);
obsClient.setBucketEncryption(exampleBucket, encryption);
System.out.println("SetBucketEncryption successfully");
} catch (ObsException e) {
System.out.println("SetBucketEncryption failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
} What is your overall rating for this page?
