Setting a Callback for a Resumable Upload (SDK for Java)
Function
You can specify the callback parameters in a resumable upload (uploadFile) request. After the object is successfully uploaded, OBS calls back the upload result to a specific server and returns the callback result to you.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- The total size of the file to be uploaded using the resumable upload API must be at least 100 KB.
- You must enable the resumable upload option when you use this API, so the progress of the last upload can be obtained for upload resumption.
- A callback can be performed only after objects are successfully uploaded.
Method
obsClient.uploadFile(UploadFileRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for uploading an object. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
| objectKey | String | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| objectMetadata | No | Explanation: Object metadata. For details, see Table 14. Default value: None | |
| acl | No | Explanation: An ACL that can be specified at bucket creation. You can use either a pre-defined or a user-defined ACL. For more information about ACLs, see ACLs. Value range:
Default value: AccessControlList.REST_CANNED_PRIVATE | |
| sseKmsHeader | No | Explanation: Server-side encryption header. For details, see Table 9. Default value: None | |
| sseCHeader | No | Explanation: Server-side encryption header. For details, see Table 8. Default value: None | |
| enableCheckpoint | boolean | No | Explanation: Whether to enable the resumable mode. Value range: true: The resumable mode is enabled. false: The resumable mode is disabled. Default value: false |
| checkpointFile | String | No | Explanation: Path of a file generated for recording the progress of a resumable download. The file contains the information about parts and the progress. Restrictions: This parameter is valid only in the resumable mode. Default value: If this parameter is left blank, the progress file will be in the same directory as the local file to be uploaded. |
| uploadFile | String | Yes | Explanation: Full path of the file or folder to be uploaded, for example, aa/bb.txt or aa/. Default value: None |
| extensionPermissionMap | Map<ExtensionObjectPermissionEnum, Set<String>> | No | Explanation: A permission map for granting bucket ACL permissions to one or more accounts. ExtensionObjectPermissionEnum specifies the permissions to grant, and Set<String> describes the list of account IDs (indicated by domain_id) the granted permissions apply to. Value range:
| progressListener | No | Explanation: Data transmission listener, used for obtaining the upload progress. For details, see Table 4. | |
| partSize | long | No | Explanation: Part size. Value range: The value ranges from 100 KB to 5 GB, in bytes. Default value: 9 MB |
| taskNum | int | No | Explanation: Maximum number of files that can be uploaded concurrently in a multipart upload. Value range: The value ranges from 1 to 10000. You are advised to set this parameter based on the device performance. Default value: 1, indicating concurrent uploads are not used. |
| encodeHeaders | boolean | No | Explanation: Whether to enable OBS to automatically encode request headers. Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser, the browser automatically decodes the data. Value range: true: Encoding with SDK is enabled. false: Encoding with SDK is disabled. Default value: true |
| callback | No | Explanation: Upload callback configuration. Default value: None |
| Constant | Description |
| AccessControlList.REST_CANNED_PRIVATE | Private read/write. A bucket or object can only be accessed by its owner. |
| AccessControlList.REST_CANNED_PUBLIC_READ | Public read. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket. If this permission is granted on an object, anyone can read the content and metadata of the object. |
| AccessControlList.REST_CANNED_PUBLIC_READ_WRITE | Public read/write. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, anyone can read the content and metadata of the object. |
| AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED | Public read on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
| AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED | Public read/write on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
| AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL | If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have control over object x. If user A sets bucket-owner-full-control for object x, user B then has control over object x. |
| Method | Return Value Type | Mandatory (Yes/No) | Description |
| void | Yes | Explanation: Used for obtaining the upload progress. For details, see Table 5. Default value: None |
| status | Yes | Explanation: Progress data. For details, see Table 6. Default value: None |
| Method | Return Value Type | Description |
| getAverageSpeed() | double | Average upload speed, in byte/s. |
| getInstantaneousSpeed() | double | Instantaneous upload speed, in byte/s. |
| getTransferPercentage() | int | Upload progress, in percentage. |
| getNewlyTransferredBytes() | long | Number of new bytes, in bytes. |
| getTransferredBytes() | long | Number of bytes that have been transmitted, in bytes. |
| getTotalBytes() | long | Number of bytes to be transmitted, in bytes. |
| GRANT_READ | Grants a specific tenant the permissions to read the object and object metadata. |
| GRANT_READ_ACP | Grants a specific tenant the permissions to obtain the object ACL. |
| GRANT_WRITE_ACP | Grants a specific tenant the permissions to write the object ACL. |
| GRANT_FULL_CONTROL | Grants a specific tenant the permissions to read the content, metadata, and ACL of the object and write the object ACL. |
| algorithm | Yes | Explanation: SSE-C is used for encrypting objects on the server side. Value range: AES256, indicating AES is used to encrypt the object in SSE-C. For details, see Table 10. Default value: None | |
| sseAlgorithm | No | Explanation: Encryption algorithm. Restrictions: Only AES256 is supported. Value range: See Table 12. Default value: None | |
| sseCKey | byte[] | Yes | Explanation: Key used for encrypting the object when SSE-C is used, in byte[] format. Default value: None |
| sseCKeyBase64 | String | No | Explanation: Base64-encoded key used for encrypting the object when SSE-C is used. Default value: None |
| encryption | Yes | Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms. For details, see Table 11. Default value: None | |
| sseAlgorithm | No | Explanation: Encryption algorithm. Restrictions: Only KMS is supported. Value range: See Table 12. Default value: None | |
| kmsKeyId | String | No | Explanation: ID of the KMS master key when SSE-KMS is used. Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
| Constant | Default Value | Description |
| STANDARD | STANDARD | Standard storage class. |
| WARM | WARM | Infrequent Access storage class. |
| COLD | COLD | Archive storage class. |
| contentLength | Long | No | Explanation: Object size. Restrictions:
Default value: If this parameter is not specified, the SDK automatically calculates the size of the object. |
| contentType | String | No | Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK). Default value: If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file. |
| contentEncoding | String | No | Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object. Default value: None |
| contentDisposition | String | No | Explanation: Provides a default name for the requested object. When the object with the default name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box. Default value: None |
| cacheControl | String | No | Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
| contentLanguage | String | No | Explanation: Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol. Default value: None |
| expires | String | No | Explanation: The time a cached web page object expires. Restrictions: The time must be in the GMT format. Default value: None |
| storageClass | No | Explanation: Object storage class. When creating an object, you can use this header to specify the storage class for the object. If this parameter is not specified, the object inherits the storage class of the bucket. Value range: See Table 13. Default value: None | |
| webSiteRedirectLocation | String | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. To another object in the same bucket: WebsiteRedirectLocation:/anotherPage.html To an external URL: WebsiteRedirectLocation:http://www.example.com/ Restrictions:
| nextPosition | long | No | Explanation: Start position for the next append upload. Value range: 0 to the object length, in bytes. Default value: None |
| appendable | boolean | No | Explanation: Whether the object is appendable. Value range: true: The object is appendable. false: The object is not appendable. Default value: None |
| userMetadata | Map<String, Object> | No | Explanation: User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java). Restrictions:
| owner | No | Explanation: Bucket owner information. For details, see Table 16. | |
| delivered | boolean | No | Explanation: Whether the bucket ACL is applied to all objects in the bucket. Value range: true: The bucket ACL is applied to all objects in the bucket. false: The bucket ACL is not applied to any objects in the bucket. Default value: false |
| grants | Set<GrantAndPermission> | No | Explanation: Grantee information. For details, see Table 17. |
| id | String | Yes | Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| grantee | Yes | Explanation: Grantees (users or user groups). Value range: Grantee (user) information. For details, see Table 19. Grantee (user group) information. For details, see Table 20. | |
| permission | Yes | Explanation: Permissions to grant. Value range: See Table 18. Default value: None | |
| PERMISSION_READ | READ | Read permission. A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
| PERMISSION_WRITE | WRITE | Write permission. A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not available for objects. |
| PERMISSION_READ_ACP | READ_ACP | Permission to read an ACL. A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
| PERMISSION_WRITE_ACP | WRITE_ACP | Permission to modify an ACL. A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
| PERMISSION_FULL_CONTROL | FULL_CONTROL | Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
| grantId | String | Yes if Type is set to GranteeUser | Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the grantee. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| ALL_USERS | All users. |
| AUTHENTICATED_USERS | Authorized users. This constant is deprecated. |
| LOG_DELIVERY | Log delivery group. This constant is deprecated. |
| callbackUrl | String | Yes | Explanation: After an object is uploaded successfully, OBS sends a callback request to the URL using the POST method. Restrictions:
| callbackHost | String | No | Explanation: Value of the Host header in the callback request. Restrictions: If callbackHost is not specified, the value of host parsed from the callbackUrl parameter is used. |
| callbackBody | String | Yes | Explanation: Body of the callback request. Restrictions: The body format must comply with the media type specified in the callbackBodyType field. Default value: The callback body supports system variables and custom variables. Custom variables are those starting with x:. For example, in key=$(key)&hash=$(etag)&fileid=$(x:fileid), variables key and etag are system variables, and x:fileid is a custom variable. If the object to be uploaded is an image, you can use imageInfo.width and imageInfo.height in the parameters to indicate the width and height of the image. Example: key=$(key)&hash=$(etag)&w=$(imageInfo.width)&h=$(imageInfo.height) |
| callbackBodyType | String | No | Explanation: Value of the Content-Type header in the callback request. Value range:
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
| bucketName | String | Explanation: Bucket name. Restrictions:
| objectKey | String | Explanation Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| etag | String | Explanation: ETag of an object, which is a Base64-encoded 128-bit MD5 digest. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded and B when the object is downloaded, the object content has changed. The ETag reflects changes only to the content of the object, not its metadata. An object created by an upload or copy operation has a unique ETag. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
| versionId | String | Explanation: Object version ID. If versioning is enabled for the bucket, the object version ID will be returned. Value range: The value must contain 32 characters. Default value: None |
| callbackResponseBody | java.io.InputStream | Explanation: Callback response body stream. Restrictions: This parameter is returned only when Callback is set in UploadFileRequest. Default value: None |
Sample Code
This example sets a callback for a resumable upload (uploadFile) request.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.Callback; import com.obs.services.model.CompleteMultipartUploadResult; import com.obs.services.model.UploadFileRequest; import java.io.BufferedReader; import java.io.InputStream; import java.io.InputStreamReader; public class UploadFileWithCallback { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN North-Beijing4 is used here as an example. Replace it with the one currently in use. // Obtain an endpoint using environment variables or import it in other ways. // String endPoint = System.getenv("ENDPOINT"); String endPoint = "https://obs.cn-north-4.myhuaweicloud.com"; // Create an ObsClient instance. try (ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint)) { UploadFileRequest request = new UploadFileRequest("example-bucket", "exampleObjectKey"); // Configure the local file to be uploaded. localfile is the path of the file to be uploaded. You must specify a file name with the extension. request.setUploadFile("localfile"); // Set the maximum number of parts that can be concurrently uploaded. request.setTaskNum(5); // Set the part size to 5 MB. request.setPartSize(5 * 1024 * 1024); // Enable the resumable upload. request.setEnableCheckpoint(true); Callback callback = new Callback(); callback.setCallbackUrl("callbackUrl1;callbackUrl2");// Mandatory. A maximum of 10 URLs can be set. Separate them with semicolons (;). callback.setCallbackHost("Host");//Optional. It indicates the value of the Host header in the callback request. If this parameter is not set, the Host field parsed from callbackUrl is used. callback.setCallbackBody("key=$(key)&hash=$(etag)");//Mandatory. Body of the callback request. The key and etag variables are system variables. callback.setCallbackBodyType("application/json");// (Optional) Value of the Content-Type header in the callback request request.setCallback(callback); // Perform a resumable upload. CompleteMultipartUploadResult result = obsClient.uploadFile(request); // Obtain the callback response. InputStream input = result.getCallbackResponseBody(); if(input != null){ BufferedReader reader = new BufferedReader(new InputStreamReader(input)); // Print the callback response. StringBuilder sb = new StringBuilder(); for(String line; (line = reader.readLine())!=null; sb.append(line)); System.out.println(sb); input.close(); System.out.println("UploadFileWithCallback successfully"); } else { System.out.println("UploadFileWithCallback failed, callback response is null"); } } catch (ObsException e) { // If there is an exception, you can call the API again to resume the upload. System.out.println("UploadFileWithCallback failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("UploadFileWithCallback failed"); // Print other error information. e.printStackTrace(); } } } |
Helpful Links
