Help Center/Object Storage Service/SDK Reference/Java/Logging (SDK for Java)/Configuring Logging for a Bucket (SDK for Java)
Updated on 2025-03-11 GMT+08:00
Function
This API enables logging for a bucket (source) and configures another bucket (target) to store the log files. When a bucket is created, logging is not enabled by default. You can call this API to enable logging for the bucket. With logging enabled, a log message is generated for each operation on the bucket. Multiple log messages are packed into a file. The target bucket for storing log files must be specified when logging is enabled. It can be the bucket logging is enabled for, or any other bucket you have access to. If you specify another bucket for storing logs, the bucket must be in the same region as the logged bucket. You can also specify access permissions and name prefixes for log files.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
  • The source and target buckets must be in the same region.
  • A bucket in the Infrequent Access or Archive storage class cannot be used as a target bucket.
  • OBS creates log files and uploads them to the bucket. Before enabling logging for a bucket, you need to create an IAM agency to delegate OBS to upload log files to the specified bucket. For details about how to create an agency, see Cloud Service Delegation.
  • To configure logging for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketLogging in IAM or PutBucketLogging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.setBucketLogging(final SetBucketLoggingRequestrequest)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
Yes
Explanation:
Request parameters for configuring logging for a bucket. For details, see Table 2.
Table 2 SetBucketLoggingRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Name of the source bucket.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
loggingConfiguration
BucketLoggingConfiguration
Yes
Explanation:
Bucket logging configurations. For details, see Table 3.
Table 3 BucketLoggingConfiguration
Type
Mandatory (Yes/No)
agency
String
Yes if you configure bucket logging
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
Restrictions:
By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located.
Default value:
None
targetBucketName
String
No
Explanation:
Name of the bucket for storing log files.
Restrictions:
  • This bucket must be in the same region as the bucket with logging enabled.
  • A bucket name:
Default value:
None
logfilePrefix
String
No
Explanation:
Name prefix for log files stored in the target bucket.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
targetGrantsList
List<GrantAndPermission>
No
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 4.
Table 4 GrantAndPermission
Type
Mandatory (Yes/No)
grantee
GranteeInterface
Yes
Explanation:
Grantees (users or user groups). For details, see Table 5.
permission
Permission
Yes
Explanation:
Permissions to grant.
Value range:
See Table 8.
Default value:
None
delivered
boolean
No
Explanation:
Whether the bucket ACL is applied to all objects in the bucket.
Value range:
true: The bucket ACL is applied to all objects in the bucket.
false: The bucket ACL is not applied to any objects in the bucket.
Default value:
false
Table 5 GranteeInterface
Type
Mandatory (Yes/No)
CanonicalGrantee
CanonicalGrantee
Yes
Explanation:
Grantee (user) information. For details, see Table 6.
GroupGrantee
GroupGrantee
Yes
Explanation:
Grantee (user group) information.
Value range:
See Table 7.
Default value:
None
Table 6 CanonicalGrantee
Type
Mandatory (Yes/No)
grantId
String
Yes if Type is set to GranteeUser
Explanation:
Account (domain) ID of the grantee.
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
displayName
String
No
Explanation:
Account name of the grantee.
Value range:
To obtain the account name, see How Do I Get My Account ID and User ID?
Default value:
None
Table 7 GroupGrantee
Constant
ALL_USERS
All users.
AUTHENTICATED_USERS
Authorized users. This constant is deprecated.
LOG_DELIVERY
Log delivery group. This constant is deprecated.
Table 8 Permission
Constant
Default Value
PERMISSION_READ
READ
Read permission.
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
PERMISSION_WRITE
WRITE
Write permission.
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not available for objects.
PERMISSION_READ_ACP
READ_ACP
Permission to read an ACL.
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
PERMISSION_WRITE_ACP
WRITE_ACP
Permission to modify an ACL.
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
PERMISSION_FULL_CONTROL
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Responses
Table 9 Common response headers
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Code Example: Enabling Bucket Logging
This example configures logging for bucket examplebucket, with your agency as the agency, targetprefix as the prefix for generated log files, and targetbucketname as the bucket for storing log files.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.BucketLoggingConfiguration;
public class SetBucketLogging001 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use the permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk,endPoint);
        // Use the temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // Enable bucket logging.
            BucketLoggingConfiguration config = new BucketLoggingConfiguration();
           // Set an agency. You need to create one on IAM.
            config.setAgency("your agency");
            config.setTargetBucketName("targetbucketname");
            config.setLogfilePrefix("targetprefix");
            obsClient.setBucketLogging("examplebucket", config);
            System.out.println("setBucketLogging successfully");
        } catch (ObsException e) {
            System.out.println("setBucketLogging failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
Code Example: Granting the Read Permission on a Log Object
This example configures logging for bucket examplebucket, with your agency as the agency, targetprefix as the prefix for generated log files, and targetbucketname as the bucket for storing log files, and then grants all users the read permission for the logs.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
import com.obs.services.model.GrantAndPermission;
import com.obs.services.model.GroupGrantee;
import com.obs.services.model.Permission;
public class SetBucketLogging002
        try {
            // Configure access to logs.
            String targetBucket = "targetbucketname";
             // Configure logging for the bucket.
            config.setTargetBucketName(targetBucket);
            config.setLogfilePrefix("prefix");
            // Grant all users the READ permission for the logs.
            GrantAndPermission grant1 = new GrantAndPermission(GroupGrantee.ALL_USERS, Permission.PERMISSION_READ);
            config.setTargetGrants(new GrantAndPermission[]{grant1});
Code Example: Disabling Bucket Logging
This example disables the logging for bucket examplebucket by clearing the logging configurations of the bucket using ObsClient.setBucketLogging.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
public class SetBucketLogging003
        try {
            // Leave the logging configurations in blank.
            obsClient.setBucketLogging("examplebucket", new BucketLoggingConfiguration());
