Accessing OBS Using a Signed URL (SDK for Java)
Function
ObsClient allows you to create a URL with Query parameters that carry authentication information by specifying the AK and SK, HTTP method, and request parameters. This URL can be shared with other users for temporary access. When generating a URL, you need to specify the validity period of the URL to restrict the access duration of visitors.
If you want to grant other users the permission to perform operations on buckets or objects (for example, upload or download objects), you need to generate a URL for the corresponding request (for example, a URL with the PUT request for uploading an object) and provide the URL to other users.
- If CORS is not configured, you need to configure CORS rules on OBS Console. For details, see Configuring CORS.
- If the signatures do not match, check whether signature parameters are correct. For details, see Authentication of Signature in a URL. For example, during an object upload, the backend uses Content-Type to calculate the signature and generate an authorized URL, but if Content-Type is not set or is set to an incorrect value when the frontend uses the authorized URL, a CORS error occurs. To avoid this issue, ensure that Content-Type fields are the same at the frontend and backend.
- A CDN acceleration domain name cannot be used to create a signed URL.
If you have any questions during development, post them on the Issues page of GitHub.
Operations That Can Be Performed Using a Signed URL
The following table lists operations that can be performed through a signed URL.
| Operation | HTTP Request Method (Value in OBS SDK for Java) | Special Operator (Value in OBS SDK for Java) | Bucket Name Required (Yes/No) | Object Name Required (Yes/No) |
| Create Bucket | HttpMethodEnum.PUT | N/A | Yes | No |
| List Buckets | HttpMethodEnum.GET | N/A | No | No |
| Delete Bucket | HttpMethodEnum.DELETE | N/A | Yes | No |
| List Objects | HttpMethodEnum.GET | N/A | Yes | No |
| List Object Versions | HttpMethodEnum.GET | SpecialParamEnum.VERSIONS | Yes | No |
| List Multipart Uploads | HttpMethodEnum.GET | SpecialParamEnum.UPLOADS | Yes | No |
| Get Bucket Metadata | HttpMethodEnum.HEAD | N/A | Yes | No |
| Get Bucket Location | HttpMethodEnum.GET | SpecialParamEnum.LOCATION | Yes | No |
| Get Bucket Storageinfo | HttpMethodEnum.GET | SpecialParamEnum.STORAGEINFO | Yes | No |
| Set Bucket Quota | HttpMethodEnum.PUT | SpecialParamEnum.QUOTA | Yes | No |
| Get Bucket Quota | HttpMethodEnum.GET | SpecialParamEnum.QUOTA | Yes | No |
| Set Bucket Storage Policy | HttpMethodEnum.PUT | SpecialParamEnum.STORAGEPOLICY | Yes | No |
| Get Bucket Storage Policy | HttpMethodEnum.GET | SpecialParamEnum.STORAGEPOLICY | Yes | No |
| Configure Bucket ACL | HttpMethodEnum.PUT | SpecialParamEnum.ACL | Yes | No |
| Obtain Bucket ACL | HttpMethodEnum.GET | SpecialParamEnum.ACL | Yes | No |
| Set Bucket Logging | HttpMethodEnum.PUT | SpecialParamEnum.LOGGING | Yes | No |
| Get Bucket Logging | HttpMethodEnum.GET | SpecialParamEnum.LOGGING | Yes | No |
| Set Bucket Policy | HttpMethodEnum.PUT | SpecialParamEnum.POLICY | Yes | No |
| Get Bucket Policy | HttpMethodEnum.GET | SpecialParamEnum.POLICY | Yes | No |
| Delete Bucket Policy | HttpMethodEnum.DELETE | SpecialParamEnum.POLICY | Yes | No |
| Set Lifecycle Rule | HttpMethodEnum.PUT | SpecialParamEnum.LIFECYCLE | Yes | No |
| Get Lifecycle Rule | HttpMethodEnum.GET | SpecialParamEnum.LIFECYCLE | Yes | No |
| Delete Lifecycle Rule | HttpMethodEnum.DELETE | SpecialParamEnum.LIFECYCLE | Yes | No |
| Set Website Hosting | HttpMethodEnum.PUT | SpecialParamEnum.WEBSITE | Yes | No |
| Get Website Hosting | HttpMethodEnum.GET | SpecialParamEnum.WEBSITE | Yes | No |
| Delete Website Hosting | HttpMethodEnum.DELETE | SpecialParamEnum.WEBSITE | Yes | No |
| Set Bucket Versioning | HttpMethodEnum.PUT | SpecialParamEnum.VERSIONING | Yes | No |
| Get Bucket Versioning | HttpMethodEnum.GET | SpecialParamEnum.VERSIONING | Yes | No |
| Set CORS Rule | HttpMethodEnum.PUT | SpecialParamEnum.CORS | Yes | No |
| Get CORS Rule | HttpMethodEnum.GET | SpecialParamEnum.CORS | Yes | No |
| Delete CORS Rule | HttpMethodEnum.DELETE | SpecialParamEnum.CORS | Yes | No |
| Set Bucket Tagging | HttpMethodEnum.PUT | SpecialParamEnum.TAGGING | Yes | No |
| Get Bucket Tagging | HttpMethodEnum.GET | SpecialParamEnum.TAGGING | Yes | No |
| Delete Bucket Tagging | HttpMethodEnum.DELETE | SpecialParamEnum.TAGGING | Yes | No |
| Upload Object | HttpMethodEnum.PUT | N/A | Yes | Yes |
| Append Object | HttpMethodEnum.POST | SpecialParamEnum.APPEND | Yes | Yes |
| Get Object | HttpMethodEnum.GET | N/A | Yes | Yes |
| Copy Object | HttpMethodEnum.PUT | N/A | Yes | Yes |
| Delete Object | HttpMethodEnum.DELETE | N/A | Yes | Yes |
| Delete Objects | HttpMethodEnum.POST | SpecialParamEnum.DELETE | Yes | Yes |
| Get Object Metadata | HttpMethodEnum.HEAD | N/A | Yes | Yes |
| Configure Object ACL | HttpMethodEnum.PUT | SpecialParamEnum.ACL | Yes | Yes |
| Obtain Object ACL | HttpMethodEnum.GET | SpecialParamEnum.ACL | Yes | Yes |
| Initiate Multipart Upload | HttpMethodEnum.POST | SpecialParamEnum.UPLOADS | Yes | Yes |
| Upload Part | HttpMethodEnum.PUT | N/A | Yes | Yes |
| Copy Part | HttpMethodEnum.PUT | N/A | Yes | Yes |
| List Parts | HttpMethodEnum.GET | N/A | Yes | Yes |
| Assemble Parts | HttpMethodEnum.POST | N/A | Yes | Yes |
| Delete Multipart Upload | HttpMethodEnum.DELETE | N/A | Yes | Yes |
| Restore Archive Objects | HttpMethodEnum.POST | SpecialParamEnum.RESTORE | Yes | Yes |
Process
To access OBS using a signed URL generated by the OBS SDK for Java, perform the following steps:
| Procedure | Code Example | ||
| Check the validity period of the signed URL. | Set the expires parameter to determine the validity period of the URL. | ||
| Determine the API that you want to access using the signed URL. For details about APIs that support signed URLs, see APIs that support URLs. After determining the API, you can determine the HttpMethodEnum and SpecialParamEnum parameters. For example, if you want to set the object ACL using the signed URL, set HttpMethodEnum to HttpMethodEnum.PUT and SpecialParamEnum to SpecialParamEnum.ACL. | The following code sets the ACL of exampleobject in the bucket examplebucke:
For details about the complete code, see Code Example: Setting an Object ACL Using a Signed URL. | ||
| Confirm the headers that need to be included when you call the API. | The following code is used to download objects encrypted using SSE-C in bucket examplebucket. The x-obs-server-side-encryption-customer-algorithm, x-obs-server-side-encryption-customer-key, and x-obs-server-side-encryption-customer-key-MD5 headers are added to the code.
For details about the complete code, see Code Example: Downloading an Object Encrypted Using SSE-C. | ||
| Confirm the body that needs to be included when you call the API. | The following code sets the ACL of exampleobject in the bucket examplebucke. The body contains the ACL configuration information.
Restrictions
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.createTemporarySignature(TemporarySignatureRequest request)
The ObsClient.createTemporarySignature function has encoded the generated URL. The browser will automatically decode the URL. You do not need to encode it again.
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for creating a signed URL. For details, see Table 3. |
| bucketName | String | No | Explanation: Bucket name. Restrictions:
Default value: None |
| objectKey | String | No | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| specialParam | No | Explanation: Special parameters that may be used in the request, indicating the sub-operations. Value range: See Table 1. Default value: None | |
| method | Yes | Explanation: HTTP method type. Value range: See Table 1. Default value: None | |
| headers | Map<String, String> | No | Explanation: Headers in the request. In Map, the String key and value indicate the name and value of the request header respectively. Default value: None |
| queryParams | Map<String, Object> | No | Explanation: Query parameters in the request. In Map, the String key indicates the name of the query parameter, and the Object value indicates the value of the query parameter. Default value: None |
| expires | long | Yes | Explanation: Expiration time of the signed URL. Value range:
Default value: 300 |
| requestDate | Date | Yes | Explanation: Time when the request is initiated. Default value: None |
Responses
| Parameter | Type | Description |
| signedUrl | String | Explanation: The signed URL that carries the authentication information. Default value: None |
| actualSignedRequestHeaders | Map<String, String> | Explanation: Actual headers in the request initiated using the signed URL. In Map, the String key and value indicate the name and value of the request header respectively. Default value: None |
Code Example: Creating a Bucket
This example uses HttpMethodEnum.PUT to create bucket examplebucket based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.RequestBody; import okhttp3.Response; import java.util.Map; public class CreateBucket001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.PUT, expireSeconds); request.setBucketName("examplebucket"); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Creating bucket using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a PUT request to create a bucket. String location = "your bucket location"; Request httpRequest = builder.url(response.getSignedUrl()) .put( RequestBody.create( null, ("<CreateBucketConfiguration><Location>" + location + "</Location></CreateBucketConfiguration>").getBytes())) .build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("\tStatus:" + res.code()); if (res.body() != null) { System.out.println("\tContent:" + res.body().string() + "\n"); } res.close(); System.out.println("CreateBucket successfully"); } catch (ObsException e) { System.out.println("CreateBucket failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("CreateBucket failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Uploading an Object
This example uses HttpMethodEnum.PUT to upload object objectname to bucket examplebucket based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.MediaType; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.RequestBody; import okhttp3.Response; import java.util.HashMap; import java.util.Map; public class PutObject001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; Map<String, String> headers = new HashMap<>(); String contentType = "text/plain"; headers.put("Content-Type", contentType); TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.PUT, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); request.setHeaders(headers); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Creating object using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a PUT request to upload an object. Request httpRequest = builder.url(response.getSignedUrl()) .put(RequestBody.create(MediaType.parse(contentType), "Hello OBS".getBytes("UTF-8"))) .build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("PutObject successfully"); } catch (ObsException e) { System.out.println("PutObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("PutObject failed"); // Print other error information. e.printStackTrace(); } } } |
This example uses HttpMethodEnum.GET to download object objectname from bucket examplebucket based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.Response; import java.io.InputStream; import java.util.Map; public class GetObject001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.GET, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Getting object using temporary signature url:"); System.out.println("SignedUrl:" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a GET request to download an object. Request httpRequest = builder.url(response.getSignedUrl()).get().build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); InputStream objectContent = null; if (res.body() != null) { objectContent = res.body().byteStream(); System.out.println("Content:" + res.body().string() + "\n"); } if(objectContent != null) { // objectContent is the file stream to download. // You can read the objectContent stream to download the file. If the stream is not read for a long time, it will be disconnected from the server. } res.close(); System.out.println("getObject successfully"); } catch (ObsException e) { System.out.println("getObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("getObject failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Listing Objects
This example uses HttpMethodEnum.GET to list object in bucket examplebucket based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.Response; import java.util.Map; public class ListObject001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.GET, expireSeconds); request.setBucketName("examplebucket"); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Getting object list using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a GET request to obtain the object list. Request httpRequest = builder.url(response.getSignedUrl()).get().build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("ListObject successfully"); } catch (ObsException e) { System.out.println("ListObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("ListObject failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Deleting an Object
This example uses HttpMethodEnum.DELETE to delete object objectname from bucket examplebucket based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.Response; import java.util.Map; public class DeleteObject001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.DELETE, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Deleting object using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a DELETE request to delete an object. Request httpRequest = builder.url(response.getSignedUrl()).delete().build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("\tStatus:" + res.code()); if (res.body() != null) { System.out.println("\tContent:" + res.body().string() + "\n"); } res.close(); System.out.println("deleteObjects successfully"); } catch (ObsException e) { System.out.println("deleteObjects failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("deleteObjects failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Initiating a Multipart Upload
This example uses HttpMethodEnum.POST to initiate a multipart upload based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.SpecialParamEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.RequestBody; import okhttp3.Response; import java.util.Map; public class InitiateMultiPartUpload001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.POST, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); request.setSpecialParam(SpecialParamEnum.UPLOADS); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("initiate multipart upload using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a POST request to initiate the multipart upload. Request httpRequest = builder.url(response.getSignedUrl()).post(RequestBody.create(null, "")).build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("InitiateMultiPartUpload successfully"); } catch (ObsException e) { System.out.println("InitiateMultiPartUpload failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("InitiateMultiPartUpload failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Uploading a Part
This example uses HttpMethodEnum.PUT to upload a part based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.RequestBody; import okhttp3.Response; import java.util.HashMap; import java.util.Map; public class UploadPart001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.PUT, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); Map<String, Object> queryParams = new HashMap<String, Object>(); // Set the partNumber parameter, for example, queryParams.put("partNumber", "1"). queryParams.put("partNumber", "partNumber"); queryParams.put("uploadId", "your uploadId"); request.setQueryParams(queryParams); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("upload part using temporary signature url:"); System.out.println("SignedUrl:" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a PUT request to upload a part. Request httpRequest = builder.url(response.getSignedUrl()) .put(RequestBody.create(null, new byte[6 * 1024 * 1024])) .build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("UploadPart successfully"); } catch (ObsException e) { System.out.println("UploadPart failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("UploadPart failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Listing Uploaded Parts
This example uses HttpMethodEnum.GET to list uploaded parts based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.Response; import java.util.HashMap; import java.util.Map; public class ListUploadedParts001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.GET, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); Map<String, Object> queryParams = new HashMap<String, Object>(); queryParams.put("uploadId", "your uploadId"); request.setQueryParams(queryParams); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("list parts using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a GET request to list uploaded parts. Request httpRequest = builder.url(response.getSignedUrl()).get().build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("ListParts successfully"); } catch (ObsException e) { System.out.println("ListParts failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("ListParts failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Assembling Parts
This example uses HttpMethodEnum.POST to assemble parts based on a signed URL. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.MediaType; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.RequestBody; import okhttp3.Response; import java.util.HashMap; import java.util.Map; public class CompleteMultiPartUpload001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.POST, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); Map<String, String> headers = new HashMap<>(); String contentType = "application/xml"; headers.put("Content-Type", contentType); request.setHeaders(headers); Map<String, Object> queryParams = new HashMap<>(); queryParams.put("uploadId", "your uploadId"); request.setQueryParams(queryParams); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("complete multipart upload using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // The following content is used as an example. You need to replace it with the responses of the request for listing uploaded parts. String content = "<CompleteMultipartUpload>"; content += "<Part>"; content += "<PartNumber>1</PartNumber>"; content += "<ETag>da6a0d097e307ac52ed9b4ad551801fc</ETag>"; content += "</Part>"; content += "<Part>"; content += "<PartNumber>2</PartNumber>"; content += "<ETag>da6a0d097e307ac52ed9b4ad551801fc</ETag>"; content += "</Part>"; content += "</CompleteMultipartUpload>"; // Make a POST request to assemble the uploaded parts. Request httpRequest = builder.url(response.getSignedUrl()) .post(RequestBody.create(MediaType.parse(contentType), content.getBytes("UTF-8"))) .build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("\tStatus:" + res.code()); if (res.body() != null) { System.out.println("\tContent:" + res.body().string() + "\n"); } res.close(); } catch (ObsException e) { System.out.println("CompleteMultiPartUpload failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("CompleteMultiPartUpload failed"); // Print other error information. e.printStackTrace(); } } } |
Code Example: Processing and Downloading an Image
This example uses HttpMethodEnum.GET to obtain a signed URL for downloading a processed image. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import java.util.HashMap; import java.util.Map; public class GetObject002 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Obtain a signed URL for downloading a processed image. // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.GET, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); // Set the parameters for image processing. Map<String, Object> queryParams = new HashMap<String, Object>(); queryParams.put("x-image-process", "image/resize,m_fixed,w_100,h_100/rotate,100"); request.setQueryParams(queryParams); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); // Obtain the download link for image processing. System.out.println("Getting object using temporary signature url:"); System.out.println("SignedUrl:" + response.getSignedUrl()); } catch (ObsException e) { System.out.println("getObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("getObject failed"); // Print other error information. e.printStackTrace(); } } } |
- The object name and bucket name must be Base64-encoded and have invalid URL characters replaced. The format is encodedObject = url_safe_base64_encode(name). For example, object panda.png is encoded to cGFuZGEucG5n. After Base64 encoding, if the name contains plus signs (+) or slashes (/), replace them, respectively, with hyphens (-) and underscores (_).
- If there is a signature match error, check whether the AK and SK pair is correct and whether the accessed URL is the same as the signed URL generated by the code.
- Currently, the range header is not supported by image persistency.
This example uses HttpMethodEnum.GET to download an object encrypted using SSE-C. The validity period of the URL is 3,600 seconds.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.Response; import java.util.HashMap; import java.util.Map; public class GetObject003 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Download an object encrypted using SSE-C. // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.GET, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); // Set the encryption method to SSE-C. Map<String, String> headers = new HashMap<>(); headers.put("x-obs-server-side-encryption-customer-algorithm", "AES256"); // Set the key used for encryption, which is a Base64-encoded 256-bit value. headers.put( "x-obs-server-side-encryption-customer-key", "your base64 sse-c key generated by AES-256 algorithm"); // Set the MD5 value of the key used for encryption, which is a Base64-encoded, 128-bit MD5 value. headers.put("x-obs-server-side-encryption-customer-key-MD5", "the md5 value of your sse-c key"); request.setHeaders(headers); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Getting object using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a GET request to download an object. Request httpRequest = builder.url(response.getSignedUrl()).get().build(); OkHttpClient httpClient = new OkHttpClient.Builder() .followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("getObject successfully"); } catch (ObsException e) { System.out.println("getObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("getObject failed"); // Print other error information. e.printStackTrace(); } } } |
- HttpMethodEnum is an enumeration function defined in OBS SDK for Java, whose value indicates the request method types.
- For details about the encryption key calculation, see How Do I Generate an SSE-C Encryption Key? (SDK for Java)
Integrity Check When Uploading an Object
This example uses content-md5 for integrity check when using a temporary URL to upload an object to OBS.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 | import com.obs.services.ObsClient; import com.obs.services.internal.utils.ServiceUtils; import com.obs.services.model.*; import okhttp3.*; import java.io.ByteArrayOutputStream; import java.io.File; import java.io.FileInputStream; import java.io.IOException; import java.security.NoSuchAlgorithmException; import java.util.HashMap; import java.util.Map; public class Create_TemporarySignature_Uploadobject { public static void main(String[] args) throws IOException, NoSuchAlgorithmException { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; Map<String, String> headers = new HashMap<String, String>(); String localFile_path = "localFile_path"; //Convert the local file into a stream and calculate its MD5 value. try (FileInputStream fileInputStream = new FileInputStream(localFile_path)) { String md5 = ServiceUtils.toBase64(ServiceUtils.computeMD5Hash(fileInputStream)); headers.put("content-md5",md5); } TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.PUT, expireSeconds); request.setBucketName("your_bucketname"); request.setObjectKey("objectkey"); request.setHeaders(headers); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Creating object using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a PUT request to upload the file. Request httpRequest = builder.url(response.getSignedUrl()) .put(RequestBody.create(getBytesByFile(localFile_path))).build(); OkHttpClient httpClient = new OkHttpClient.Builder().followRedirects(false).retryOnConnectionFailure(false) .cache(null).build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("\tStatus:" + res.code()); if (res.body() != null) { System.out.println("\tContent:" + res.body().string() + "\n"); } res.close(); } public static byte[] getBytesByFile(String pathStr) { File file = new File(pathStr); try (FileInputStream fis = new FileInputStream(file); ByteArrayOutputStream bos = new ByteArrayOutputStream(1000)) { byte[] b = new byte[1000]; int n; while ((n = fis.read(b)) != -1) { bos.write(b, 0, n); } return bos.toByteArray(); } catch (Exception e) { e.printStackTrace(); } return null; } } |
The following code sets the ACL of exampleobject in the bucket examplebucke to bucket-owner-full-control.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HttpMethodEnum; import com.obs.services.model.SpecialParamEnum; import com.obs.services.model.TemporarySignatureRequest; import com.obs.services.model.TemporarySignatureResponse; import okhttp3.Call; import okhttp3.OkHttpClient; import okhttp3.Request; import okhttp3.RequestBody; import okhttp3.Response; import java.util.HashMap; import java.util.Map; public class SetObjectAcl001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. If you use a temporary AK/SK pair and a security token to make an API call, uncomment the following line. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use a permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use a temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the validity period of the URL to 3600 seconds. long expireSeconds = 3600L; TemporarySignatureRequest request = new TemporarySignatureRequest(HttpMethodEnum.PUT, expireSeconds); request.setBucketName("examplebucket"); request.setObjectKey("exampleobject"); request.setSpecialParam(SpecialParamEnum.ACL); TemporarySignatureResponse response = obsClient.createTemporarySignature(request); System.out.println("Set object ACL using temporary signature url:"); System.out.println("\t" + response.getSignedUrl()); Request.Builder builder = new Request.Builder(); for (Map.Entry<String, String> entry : response.getActualSignedRequestHeaders().entrySet()) { builder.header(entry.getKey(), entry.getValue()); } // Make a PUT request to upload an object. String OwnerId = "5b690*************abc"; Request httpRequest = builder.url(response.getSignedUrl()) .put(RequestBody.create(null, ("<AccessControlPolicy>" + "<Owner><ID>" + OwnerId + "</ID></Owner>" + "<Delivered>true</Delivered>" + "<AccessControlList>" + "<Grant>" + "<Grantee><ID>" + OwnerId + "</ID></Grantee>" + "<Permission>FULL_CONTROL</Permission>" + "</Grant>" + "</AccessControlList>" + "</AccessControlPolicy>").getBytes())) .build(); OkHttpClient httpClient = new OkHttpClient.Builder().followRedirects(false) .retryOnConnectionFailure(false) .cache(null) .build(); Call c = httpClient.newCall(httpRequest); Response res = c.execute(); System.out.println("Status:" + res.code()); if (res.body() != null) { System.out.println("Content:" + res.body().string() + "\n"); } res.close(); System.out.println("SetObjectAcl successfully"); } catch (ObsException e) { System.out.println("SetObjectAcl failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("SetObjectAcl failed"); // Print other error information. e.printStackTrace(); } } } |
Helpful Links
