Downloading an Object - Range-Based (SDK for Java)
Function
This API downloads partial data of an object by specifying a range. If the specified range is from 0 to 1,000, data from byte 1 to byte 1,001 (1,001 bytes in total) are returned. If the specified range is invalid, the whole object is returned.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- Objects in the Archive storage class can be downloaded only when they are restored.
- If the specified range is invalid (for example, the start or end position is set to a negative integer, or the start position is greater than the end position), the API throws an exception. If the specified range is valid and the end position is greater than the object size, the entire object is returned.
Method
obsClient.getObject(GetObjectRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for downloading an object. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
| objectKey | String | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| versionId | String | No | Explanation: Object version ID. Value range: The value must contain 32 characters. Default value: None |
| imageProcess | String | No | Explanation: Image processing command or style. Example for resizing and rotating an image: image/resize,m_fixed,w_100,h_100/rotate,90 Value range: Command format: image/commands Style format: style/style name For details about image processing parameters, see Processing Images. Default value: If no commands are entered, the original image is returned. |
| rangeStart | Long | No | Explanation: Start position for object download. Value range: A non-negative integer. Default value: None |
| rangeEnd | Long | No | Explanation: End position for object download. Restrictions: The upper limit of the value is the object length minus 1, in bytes. Default value: None |
| ifMatchTag | String | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
| ifNoneMatchTag | String | No | Explanation: Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned. Value range: The value must contain 32 characters. Default value: None |
| IfModifiedSince | Date | No | Explanation: The object is returned if it has been modified since the specified time; otherwise, an error is returned. Default value: None |
| IfUnmodifiedSince | Date | No | Explanation: The object is returned if it has not been modified since the specified time; otherwise, an error is returned. Default value: None |
| sseCHeader | No | Explanation: Server-side decryption header. For details, see Table 7. | |
| replaceMetadata | No | Explanation: Additional information about the object. For details, see Table 3. | |
| progressListener | No | Explanation: Data transmission listener for obtaining the download progress. For details, see Table 4. | |
| encodeHeaders | boolean | No | Explanation: Whether to enable OBS to automatically encode request headers. Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser to access the object metadata, the browser automatically decodes the data. Value range: true: Encoding with SDK is enabled. false: Encoding with SDK is disabled. Default value: true |
| contentType | String | No | Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK) Default value: None |
| contentLanguage | String | No | Explanation: Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol. Default value: None |
| expires | String | No | Explanation: Expires header in the response. It specifies the cache expiration time of the web page when the object is downloaded. Default value: None |
| cacheControl | String | No | Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
| contentDisposition | String | No | Explanation: Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box. Default value: None |
| contentEncoding | String | No | Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object in a download. Default value: None |
| Method | Return Value Type | Mandatory (Yes/No) | Description |
| void | Yes | Explanation: Used for obtaining the progress. For details, see Table 5. Default value: None |
| status | Yes | Explanation: Progress data. For details, see Table 6. Default value: None |
| Method | Return Value Type | Description |
| getAverageSpeed() | double | Average upload speed, in byte/s. |
| getInstantaneousSpeed() | double | Instantaneous upload speed, in byte/s. |
| getTransferPercentage() | int | Upload progress, in percentage. |
| getNewlyTransferredBytes() | long | Number of new bytes, in bytes. |
| getTransferredBytes() | long | Number of bytes that have been transmitted, in bytes. |
| getTotalBytes() | long | Number of bytes to be transmitted, in bytes. |
| algorithm | Yes | Explanation: SSE-C is used for encrypting objects on the server side. Value range: AES256, indicating Advanced Encryption Standard (AES) is used to encrypt the object in SSE-C. For details, see Table 9. Default value: None | |
| sseAlgorithm | No | Explanation: Encryption algorithm. Restrictions: Only AES256 is supported. Value range: See Table 8. Default value: None | |
| sseCKey | byte[] | Yes | Explanation: Key used for encrypting the object when SSE-C is used, in byte[] format. Default value: None |
| sseCKeyBase64 | String | No | Explanation: Base64-encoded key used for encrypting the object when SSE-C is used. Default value: None |
| id | String | Yes | Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| Constant | Default Value | Description |
| STANDARD | STANDARD | Standard storage class. |
| WARM | WARM | Infrequent Access storage class. |
| COLD | COLD | Archive storage class. |
| contentLength | Long | No | Explanation: Object size. Default value: If this parameter is not specified, the SDK automatically calculates the size of the object. |
| contentType | String | No | Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK) Default value: If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file. |
| contentEncoding | String | No | Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object. Default value: None |
| expires | String | No | Explanation: The time a cached web page object expires. Restrictions: The time must be in the GMT format. Default value: None |
| contentMd5 | String | No | Explanation: Base64-encoded MD5 value of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the object data. If the two values are not the same, HTTP status code 400 is returned. Restrictions:
Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864. Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
| crc64 | String | No | Explanation: The 64-bit CRC value calculated for the object based on the ECMA-182 standard. The CRC64 value is the unique identifier of the object content. It can be used to determine whether the object content is changed. If an object has different CRC64 values when being uploaded and downloaded, its content has been changed. CRC64 reflects changes to the content of the object, not its metadata. Restrictions:
Value range: A 64-bit CRC value calculated based on the ECMA-182 standard Default value: None |
| storageClass | No | Explanation: Storage class of an object that can be specified at object creation. If this header is not set, the default storage class of the bucket is used as the storage class of the object. Value range: See Table 11. Default value: None | |
| webSiteRedirectLocation | String | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. To another object in the same bucket: WebsiteRedirectLocation:/anotherPage.html To an external URL: WebsiteRedirectLocation:http://www.example.com/ Restrictions:
| nextPosition | long | No | Explanation: Start position for the next append upload. Value range: 0 to the object length, in bytes. Default value: None |
| appendable | boolean | No | Explanation: Whether the object is appendable. Value range: true: The object is appendable. false: The object is not appendable. Default value: None |
| userMetadata | Map<String, Object> | No | Explanation: User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java). Restrictions:
Responses
| Parameter | Type | Description |
| bucketName | String | Explanation: Bucket name. Restrictions:
| objectKey | String | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| owner | Explanation: Owner of the object. For details, see Table 10. | |
| metadata | Explanation: Object metadata. For details, see Table 12. | |
| objectContent | InputStream | Explanation: Object data stream. Default value: None |
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.GetObjectRequest; import com.obs.services.model.ObsObject; import java.io.InputStream; public class GetObject002 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use a permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Use a temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Perform a partial download. GetObjectRequest request = new GetObjectRequest("examplebucket", "objectname"); // Set the start point and end point. request.setRangeStart(0L); request.setRangeEnd(1000L); ObsObject obsObject = obsClient.getObject(request); // Read data. byte[] buf = new byte[1024]; InputStream in = obsObject.getObjectContent(); for (int n = 0; n != -1; ) { n = in.read(buf, 0, buf.length); if (n > 0) { System.out.println(new String(buf, 0, n)); } } System.out.println("GetObject successfully"); in.close(); } catch (ObsException e) { System.out.println("GetObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("GetObject failed"); // Print other error information. e.printStackTrace(); } } } |
Helpful Links
- Downloading Objects
- (GitHub) Sample Code for Downloading an Object
- OBS Error Codes
- FAQ for Object Download Failure
- This API can be used to concurrently download parts of a large object. For details about the sample code, see ConcurrentDownloadObjectSample.
