Configuring Object Metadata (SDK for Java)
Function
This API configures metadata for an object when uploading it. Object metadata include the object length, MIME type, MD5 value (for verification), storage class, and custom object metadata. You can configure metadata for an object that is being uploaded in streaming, file-based, or multipart mode or when copying an object.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To configure the metadata of an object when uploading it, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- An object can have multiple pieces of metadata. The metadata size cannot exceed 8 KB in total.
- Currently, metadata names cannot contain non-ASCII characters. If such characters are contained in a metadata value, the value must be Base64-encoded.
Method
obsClient.putObject(PutObjectRequest request)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
request |
Yes |
Explanation: Request parameters for uploading an object. For details, see Table 2. |
Parameter |
Type |
Description |
bucketName |
String |
Yes |
Explanation: Bucket name. Restrictions:
Default value: None |
objectKey |
String |
Yes |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
metadata |
No |
Explanation: Object metadata. For details, see Table 14. Default value: None |
acl |
No |
Explanation: ACL that can be pre-defined when an object is created. Refer to Table 15 to choose the option you need. For details about ACLs, see ACLs. Value range:
sseKmsHeader |
No |
Explanation: Server-side encryption header. For details, see Table 9. Default value: None |
sseCHeader |
No |
Explanation: Server-side encryption header. For details, see Table 8. Default value: None |
input |
java.io.InputStream |
No |
Explanation: Data stream of the object to be uploaded. Default value: None |
file |
java.io.File |
No |
Explanation: File stream of the object to be uploaded. Default value: None |
extensionPermissionMap |
Map<ExtensionObjectPermissionEnum, Set<String>> |
No |
Explanation: A permission map for granting bucket ACL permissions to one or more accounts. ExtensionObjectPermissionEnum specifies the permissions to grant, and Set<String> describes the list of account IDs (indicated by domain_id) the granted permissions apply to. Value range:
expires |
int |
No |
Explanation: Expiration time of the object. The calculation starts from the time when the object was last modified. Once the object expires, it is automatically deleted. Restrictions: This parameter can be configured when uploading an object or using the x-obs-expires header in a metadata API call. Value range: An integer greater than 0, in days. Default value: None |
progressListener |
No |
Explanation: Upload progress. For details, see Table 4. |
encodeHeaders |
boolean |
No |
Explanation: Whether to enable OBS to automatically encode request headers. Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser to access the object metadata, the browser automatically decodes the data. Value range: true: Encoding with SDK is enabled. false: Encoding with SDK is disabled. Default value: true |
Constant |
Description |
AccessControlList.REST_CANNED_PRIVATE |
Private read/write. A bucket or object can only be accessed by its owner. |
AccessControlList.REST_CANNED_PUBLIC_READ |
Public read. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket. If this permission is granted on an object, anyone can read the content and metadata of the object. |
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE |
Public read/write. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, anyone can read the content and metadata of the object. |
AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED |
Public read on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED |
Public read/write on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL |
If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets bucket-owner-full-control for object x, user B then has the control over object x. |
Method |
Return Value Type |
Description |
void |
Yes |
Explanation: Used for obtaining the upload progress. For details, see Table 5. Default value: None |
Parameter |
Type |
Description |
status |
Yes |
Explanation: Progress data. For details, see Table 6. Default value: None |
Method |
Return Value Type |
Description |
getAverageSpeed() |
double |
Average transmission rate. |
getInstantaneousSpeed() |
double |
Instantaneous transmission rate. |
getTransferPercentage() |
int |
Transmission progress, in percentage. |
getNewlyTransferredBytes() |
long |
Number of the newly transmitted bytes. |
getTransferredBytes() |
long |
Number of bytes that have been transmitted. |
getTotalBytes() |
long |
Number of the bytes to be transmitted. |
Constant |
Description |
GRANT_READ |
Grants a specific tenant the permissions to read the object and object metadata. |
GRANT_READ_ACP |
Grants a specific tenant the permissions to obtain the object ACL. |
GRANT_WRITE_ACP |
Grants a specific tenant the permissions to write the object ACL. |
GRANT_FULL_CONTROL |
Grants a specific tenant the permissions to read the content, metadata, and ACL of the object and write the object ACL. |
Parameter |
Type |
Description |
algorithm |
Yes |
Explanation: SSE-C is used for encrypting objects on the server side. Value range: AES256, indicating AES is used to encrypt the object in SSE-C. For details, see Table 10. Default value: None |
sseAlgorithm |
No |
Explanation: Encryption algorithm. Restrictions: Only AES256 is supported. Value range: See Table 12. Default value: None |
sseCKey |
byte[] |
Yes |
Explanation: Key used for encrypting the object when SSE-C is used, in byte[] format. Default value: None |
sseCKeyBase64 |
String |
No |
Explanation: Base64-encoded key used for encrypting the object when SSE-C is used. Default value: None |
Parameter |
Type |
Description |
encryption |
Yes |
Explanation: SSE-KMS is used for encrypting objects on the server side. Value range: kms. For details, see Table 11. Default value: None |
sseAlgorithm |
No |
Explanation: Encryption algorithm. Restrictions: Only KMS is supported. Value range: See Table 12. Default value: None |
kmsKeyId |
String |
No |
Explanation: ID of the KMS master key when SSE-KMS is used. Value range: Valid value formats are as follows:
In the preceding formats:
Default value:
Constant |
Default Value |
Description |
STANDARD |
STANDARD |
Standard storage class |
WARM |
WARM |
Infrequent Access storage class. |
COLD |
COLD |
Archive storage class. |
Parameter |
Type |
Description |
contentLength |
Long |
No |
Explanation: Object size. Restrictions:
Default value: If this parameter is not specified, the SDK automatically calculates the size of the file. |
contentType |
String |
No |
Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK) Default value: If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file. |
contentEncoding |
String |
No |
Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object. Default value: None |
contentDisposition |
String |
No |
Explanation: Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box. Default value: None |
cacheControl |
String |
No |
Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
contentLanguage |
String |
No |
Explanation: Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol. Default value: None |
expires |
String |
No |
Explanation: The time a cached web page object expires. Restrictions: The time must be in the GMT format. Default value: None |
contentMd5 |
String |
No |
Explanation: Base64-encoded MD5 value of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the file data. If the two values are not the same, HTTP status code 400 is returned. Restrictions:
Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864. Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
storageClass |
No |
Explanation: Object storage class that can be specified at object creation. If this parameter is not specified, the object inherits the storage class of the bucket where it is to be uploaded by default. Value range: See Table 13. Default value: None |
webSiteRedirectLocation |
String |
No |
Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. The request is redirected to an object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ Restrictions:
nextPosition |
long |
No |
Explanation: Start position for the next append upload. Value range: 0 to the object length, in bytes. Default value: None |
appendable |
boolean |
No |
Explanation: Whether the object is appendable. Value range: true: The object is appendable. false: The object is not appendable. Default value: None |
userMetadata |
Map<String, Object> |
No |
Explanation: User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java). Restrictions:
Parameter |
Type |
Type |
owner |
No |
Explanation: Bucket owner information. For details, see Table 16. |
delivered |
boolean |
No |
Explanation: Whether the bucket ACL is applied to all objects in the bucket. Value range: true: The bucket ACL is applied to all objects in the bucket. false: The bucket ACL is not applied to any objects in the bucket. Default value: false |
grants |
Set<GrantAndPermission> |
No |
Explanation: Grantee information. For details, see Table 17. |
Parameter |
Type |
Description |
id |
String |
Yes |
Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
displayName |
String |
No |
Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
Parameter |
Type |
Description |
grantee |
Yes |
Explanation: Grantees (users or user groups). For details, see Table 19. |
permission |
Yes |
Explanation: Permissions to grant. Value range: See Table 18. Default value: None |
delivered |
boolean |
No |
Constant |
Default Value |
Description |
PERMISSION_READ |
READ |
Read permission. A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
PERMISSION_WRITE |
WRITE |
Write permission. A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not available for objects. |
PERMISSION_READ_ACP |
READ_ACP |
Permission to read an ACL. A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
PERMISSION_WRITE_ACP |
WRITE_ACP |
Permission to modify an ACL. A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
PERMISSION_FULL_CONTROL |
FULL_CONTROL |
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
Parameter |
Type |
Description |
Yes |
Explanation: Grantee (user) information. For details, see Table 20. |
Yes |
Explanation: Grantee (user group) information. Value range: See Table 21. Default value: None |
Parameter |
Type |
Description |
grantId |
String |
Yes if Type is set to GranteeUser |
Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
displayName |
String |
No |
Explanation: Account name of the grantee. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
Constant |
Description |
ALL_USERS |
All users. |
AUTHENTICATED_USERS |
Authorized users. This constant is deprecated. |
LOG_DELIVERY |
Log delivery group. This constant is deprecated. |
Responses
Parameter |
Type |
Description |
statusCode |
int |
Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders |
Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
storageClass |
versionId |
String |
Explanation: Object version ID. If versioning is enabled for the bucket, the object version ID will be returned. Value range: The value must contain 32 characters. Default value: None |
etag |
String |
Explanation: ETag of an object, which is a Base64-encoded 128-bit MD5 digest. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, the object content is changed. The ETag reflects changes only to the contents of the object, not its metadata. An uploaded object or copied object has a unique ETag. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
objectKey |
String |
bucketName |
String |
Code Example: Setting the Length for an Object
This example uploads local file localfile to bucket examplebucket as object objectname and sets its length to 1024 * 1024L.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 |
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.ObjectMetadata;
import java.io.File;
import java.io.IOException;
public class PutObject007 {
public static void main(String[] args) throws IOException {
// Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
// (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
// Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
// String securityToken = System.getenv("SECURITY_TOKEN");
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
// Obtain an endpoint using environment variables or import it in other ways.
//String endPoint = System.getenv("ENDPOINT");
// Create an ObsClient instance.
// Use the permanent AK/SK pair to initialize the client.
ObsClient obsClient = new ObsClient(ak, sk,endPoint);
// Use the temporary AK/SK pair and security token to initialize the client.
// ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
try {
// Set the length for an object.
ObjectMetadata metadata = new ObjectMetadata();
metadata.setContentLength(1024 * 1024L); // 1MB
obsClient.putObject("examplebucket", "objectname", new File("localfile"), metadata);
System.out.println("putObject successfully");
} catch (ObsException e) {
System.out.println("putObject failed");
// Request failed. Print the HTTP status code.
System.out.println("HTTP Code:" + e.getResponseCode());
// Request failed. Print the server-side error code.
System.out.println("Error Code:" + e.getErrorCode());
// Request failed. Print the error details.
System.out.println("Error Message:" + e.getErrorMessage());
// Request failed. Print the request ID.
System.out.println("Request ID:" + e.getErrorRequestId());
System.out.println("Host ID:" + e.getErrorHostId());
e.printStackTrace();
} catch (Exception e) {
// Print other error information.
Code Example: Setting the MIME Type for an Object
This example uploads local file localimage.jpg to bucket examplebucket as object objectname.jpg and sets the MIME type of the object to image/jpeg.
public class PutObject008 {
try {
// Set the MIME type for an object.
// Upload an image.
metadata.setContentType("image/jpeg");
obsClient.putObject("examplebucket", "objectname.jpg", new File("localimage.jpg"), metadata);
Code Example: Setting the MD5 Value for an Object
This example uploads local file localimage.jpg to bucket examplebucket as object objectname and calls ObsClient.base64Md5 to calculate the Content-MD5 header.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 |
import java.nio.file.Files;
import java.nio.file.Paths;
public class PutObject009 {
try {
// Set the MD5 value for an object.
// Upload an image.
// Your file's Base64-encoded MD5
String base64Md5 = obsClient.base64Md5(Files.newInputStream(Paths.get("localimage.jpg")));
metadata.setContentMd5(base64Md5);
obsClient.putObject("examplebucket", "objectname", new File("localimage.jpg"), metadata);
Code Example: Customizing Metadata for an Object
This example uploads local file localfile to object objectname in bucket examplebucket, customizes two pieces of metadata named property1 and property2, and sets their respective values to property-value1 and property-value2.
public class PutObject011 {
try {
// Set user-defined metadata for the object.
metadata.addUserMetadata("property1", "property-value1");
metadata.getMetadata().put("property2", "property-value2");
Code Example: Setting the Storage Class for an Object
This example uploads local file localfile to bucket exampleBucket as object objectname and sets the object storage class to Infrequent Access.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 |
import com.obs.services.model.StorageClassEnum;
public class PutObject010 {
try {
// Set the storage class for an object.
// Set the storage class of the object to Infrequent Access.
metadata.setObjectStorageClass(StorageClassEnum.WARM);
