Updated on 2024-12-11 GMT+08:00
Modifying an Object (SDK for Java)
Function
This API modifies the content of an object from the specified position.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.modifyObject(ModifyObjectRequestrequest)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
ModifyObjectRequest
Yes
Explanation:
Request parameters for modifying an object. For details, see Table 2.
Table 2 ModifyObjectRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
String
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
position
long
Yes
Explanation:
Position from which the object is modified.
Value range:
A long integer greater than or equal to 0, in bytes.
Default value:
None
input
InputStream
No
Explanation:
Data stream of the object to be uploaded.
Default value:
None
file
File
No
Explanation:
Local file to be uploaded.
Default value:
None
encodeHeaders
boolean
No
Explanation:
Whether to enable OBS to automatically encode request headers.
Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser to access the object metadata, the browser automatically decodes the data.
Value range:
true: Encoding with SDK is enabled.
false: Encoding with SDK is disabled.
Default value:
true
Responses
Table 3 ModifyObjectResult
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Code Examples
This example modifies the content of object objectname at a specified point in parallel file system examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.ModifyObjectRequest;
import com.obs.services.model.ModifyObjectResult;
import java.io.ByteArrayInputStream;
public class ModifyObject001 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use the permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk,endPoint);
        // Use the temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // The first upload
            ModifyObjectRequest request = new ModifyObjectRequest();
            request.setBucketName("examplebucket");
            request.setObjectKey("objectname");
            request.setPosition(0);
            request.setInput(new ByteArrayInputStream("HELLO OBS FIRST".getBytes()));
            ModifyObjectResult result = obsClient.modifyObject(request);
            // The second upload for modification
            request.setInput(new ByteArrayInputStream("hello obs second".getBytes()));
            System.out.println("modifyObject successfully");
            System.out.println("HTTP Code: " + result.getStatusCode());
        } catch (ObsException e) {
            System.out.println("modifyObject failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
