Deleting a Bucket (SDK for Java)
Function
This API deletes an empty bucket. You can delete buckets you no longer use to free up space. The name of a deleted bucket can be reused for another bucket at least 30 minutes after the deletion.
The data you proactively deleted from OBS cannot be recovered. Exercise caution when using this API.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- Only empty buckets can be deleted. An empty bucket means that:
- The bucket does not contain any object (including noncurrent versions and delete markers).
- The bucket does not contain any fragments, which means that there are no multipart uploads that have not been completed in the bucket.
- To delete a bucket, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucket in IAM or DeleteBucket in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- Only empty buckets (without objects and part fragments) can be deleted.
- Bucket deletion is a non-idempotence operation and an error will be reported if the bucket you want to delete does not exist.
Method
obsClient.deleteBucket(String bucketName)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
This example deletes bucket exampleBucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HeaderResponse; public class DeleteBucket001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Example bucket name String exampleBucket = "examplebucket"; // Delete the bucket. HeaderResponse response = obsClient.deleteBucket(exampleBucket); System.out.println("DeleteBucket successfully"); System.out.println("StatusCode:"+response.getStatusCode()); System.out.println("RequestId:"+response.getRequestId()); } catch (ObsException e) { System.out.println("DeleteBucket failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message: " + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); } catch (Exception e) { System.out.println("DeleteBucket failed"); // Print other error information. e.printStackTrace(); } } } |
Helpful Links
- Deleting an Object
- Managing Fragments
- Listing Objects and Listing Initiated Multipart Uploads in a Bucket. These two operations can help you determine whether a bucket is empty.
- Deleting Buckets
- (GitHub) Sample Code for Deleting a Bucket
- OBS Error Codes
- Why Can't I Delete a Bucket?
