Cloud Data Center
DataArts Fabric
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
Cloud Container Instance (CCI)
Industry Video Management Service
Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Creating a Bucket (SDK for Java)
Updated on 2025-07-29 GMT+08:00
Function
This API creates an OBS bucket. Buckets are containers for storing objects (files uploaded to OBS) in OBS.
When creating a bucket, you can also configure parameters such as the storage class, region, and access control list (ACL) as needed.
NOTICE:
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
  • To create a bucket, you must have the obs:bucket:CreateBucket permission. IAM is recommended for granting permissions. For details, see IAM Custom Policies.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
    When creating a bucket, if you use the endpoint obs.myhuaweicloud.com for client initialization, you do not have to specify a region (indicated by location) where the bucket will be created, because OBS automatically creates the bucket in the CN North-Beijing1 (cn-north-1) region. However, if the endpoint you use is not obs.myhuaweicloud.com, you must specify a region that matches the used endpoint, or status code 400 is returned.
    For example, if the endpoint used for initialization is obs.ap-southeast-1.myhuaweicloud.com, you must set Location to ap-southeast-1 when creating a bucket.
  • A maximum of 100 buckets and parallel file systems in total can be created globally for an account. There is no limit on the number or size of objects stored in a bucket.
  • The created bucket name must be unique in OBS. If you repeatedly create buckets with the same name in the same region, an HTTP status code 200 will be returned. In other cases, creating a bucket with an existing bucket name will have an HTTP status code 409 returned, indicating that such a bucket already exists.
  • The name of a deleted bucket can be reused for another bucket or a parallel file system at least 30 minutes after the deletion.
  • Not all regions support the creation of multi-AZ buckets. You can check whether a region allows you to create multi-AZ buckets by referring to Product Pricing Details.
Method
  • Method 1: Create a bucket with a specified name.
    createBucket(String bucketName)
  • Method 2: Create a bucket with a specified name in a specified region.
    createBucket(String bucketName, String location)
  • Method 3: Create a bucket with a specified name in a specified region.
    createBucket(ObsBucket bucket)
  • Method 4: Create a bucket and configure access permissions, storage class, location, cluster type, bucket type (object bucket or parallel file system), enterprise project ID, and extension permissions for the bucket.
    createBucket(CreateBucketRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
CreateBucketRequest
Yes
Explanation:
Request parameters for creating a bucket. For details, see Table 2.
Table 2 CreateBucketRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
location
String
Yes if the region where the OBS service resides is not the default region
Explanation:
Region where a bucket will be located
Restrictions:
If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required.
Value range:
To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator.
Default value:
If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default.
acl
AccessControlList
No
Explanation:
An ACL that can be specified at bucket creation. You can use either a pre-defined or a user-defined ACL. For more information about ACLs, see ACLs.
Value range:
  • To use a pre-defined ACL, see Table 3 for the available options.
  • To use a user-defined ACL, see Table 5 to configure the required parameters.
Default value:
AccessControlList.REST_CANNED_PRIVATE
storageClass
StorageClassEnum
No
Explanation:
Bucket storage class that can be specified at bucket creation.
Value range:
See Table 12.
Default value:
STANDARD
extensionPermissionMap
Map<ExtensionBucketPermissionEnum, Set<String>>
No
Explanation:
A permission map for granting bucket ACL permissions to one or more accounts. ExtensionBucketPermissionEnum specifies the permissions to grant, and Set<String> describes the list of account IDs (indicated by domain_id) the granted permissions apply to.
Value range:
Default value:
None
epid
String
No
Explanation:
Enterprise project ID that can be specified at bucket creation. If you have enabled Enterprise Project Management Service (EPS), you can obtain the project ID from the EPS console.
Restrictions:
The value of epid is a Universally Unique Identifier (UUID). epid is not required if you have not enabled EPS yet.
Example: 9892d768-2d13-450f-aac7-ed0e44c2585f
Default value:
None
availableZone
AvailableZoneEnum
No
Explanation:
Data redundancy type that can be specified at bucket creation.
Restrictions:
Multi-AZ redundancy is not available for the Archive storage. If the region where the bucket is located does not support multi-AZ storage, the bucket adopts single-AZ storage by default.
Value range:
To configure multi-AZ storage for the bucket, set this parameter to MULTI_AZ. To configure single-AZ storage (default value assigned by OBS) for the bucket, you do not need to specify this parameter.
Default value:
If this parameter is left blank, single AZ is used by default.
bucketType
BucketTypeEnum
No
Explanation:
Type of the bucket to create.
Value range:
For details, see Table 14.
Default value:
OBJECT, indicating an object bucket
Table 3 Pre-defined ACL
Constant
Private read/write.
A bucket or object can only be accessed by its owner.
AccessControlList.REST_CANNED_PUBLIC_READ
Public read.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket.
If this permission is granted on an object, anyone can read the content and metadata of the object.
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE
Public read/write.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED
Public read on a bucket as well as objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket.
This permission cannot be granted on objects.
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED
Public read/write on a bucket as well as objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket.
AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL
If this permission is granted on an object, only the bucket and object owners have the full control over the object.
By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object.
For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets bucket-owner-full-control for object x, user B then has the control over object x.
Table 4 ExtensionBucketPermissionEnum
Constant
GRANT_READ
Grants the READ permission to an account ID.
The account with the READ permission can list objects, multipart uploads, and object versions in the bucket you are creating, and can obtain bucket metadata.
GRANT_WRITE
Grants the WRITE permission to an account ID.
The account with the WRITE permission can create, delete, and overwrite objects in the bucket you are creating, and can initiate or abort multipart uploads, as well as upload, copy, and assemble parts.
GRANT_READ_ACP
Grants the READ_ACP permission to an account ID.
The account with the READ_ACP permission can read the ACL of the bucket you are creating.
GRANT_WRITE_ACP
Grants the WRITE_ACP permission to an account ID.
The account with the WRITE_ACP permission can modify the ACL of the bucket you are creating.
GRANT_FULL_CONTROL
Grants the FULL_CONTROL permission to an account ID.
The account with the FULL_CONTROL permission can perform any operation on the bucket you are creating.
GRANT_READ_DELIVERED
Grants the READ permission to an account ID. By default, this READ permission applies to all objects in the bucket.
GRANT_FULL_CONTROL_DELIVERED
Grants the FULL_CONTROL permission to an account ID. By default, this FULL_CONTROL permission applies to all objects in the bucket.
Table 5 AccessControlList
Type
Mandatory (Yes/No)
owner
Owner
No
Explanation:
Bucket owner information. For details, see Table 6.
delivered
boolean
No
Explanation:
Whether the bucket ACL is applied to all objects in the bucket.
Value range:
true: The bucket ACL is applied to all objects in the bucket.
false: The bucket ACL is not applied to any objects in the bucket.
Default value:
false
grants
Set<GrantAndPermission>
No
Explanation:
Grantee information. For details, see Table 7.
Table 6 Owner
Type
Mandatory (Yes/No)
id
String
Yes
Explanation:
Account (domain) ID of the bucket owner.
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
displayName
String
No
Explanation:
Account name of the owner.
Value range:
To obtain the account name, see How Do I Get My Account ID and User ID?
Default value:
None
Table 7 GrantAndPermission
Type
Mandatory (Yes/No)
grantee
GranteeInterface
Yes
Explanation:
Grantees (users or user groups). For details, see Table 8.
permission
Permission
Yes
Explanation:
Permissions to grant.
Value range:
For details, see Table 11.
Default value:
None
delivered
boolean
No
Explanation:
Value range:
Default value:
false
Table 8 GranteeInterface
Type
Mandatory (Yes/No)
CanonicalGrantee
CanonicalGrantee
Yes
Explanation:
Grantee (user) information. For details, see Table 9.
GroupGrantee
GroupGrantee
Yes
Explanation:
Grantee (user group) information.
Value range:
For details, see Table 10.
Default value:
None
Table 9 CanonicalGrantee
Type
Mandatory (Yes/No)
grantId
String
Yes if Type is set to GranteeUser
Explanation:
Account (domain) ID of the grantee.
Value range:
Default value:
None
displayName
String
No
Explanation:
Account name of the grantee.
Value range:
Default value:
None
Table 10 GroupGrantee
Constant
ALL_USERS
All users.
AUTHENTICATED_USERS
Authorized users. This constant is deprecated.
LOG_DELIVERY
Log delivery group. This constant is deprecated.
Table 11 Permission
Constant
Default Value
PERMISSION_READ
READ
Read permission.
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
PERMISSION_WRITE
WRITE
Write permission.
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not available for objects.
PERMISSION_READ_ACP
READ_ACP
Permission to read an ACL.
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
PERMISSION_WRITE_ACP
WRITE_ACP
Permission to modify an ACL.
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
PERMISSION_FULL_CONTROL
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Table 12 StorageClassEnum
Constant
Default Value
STANDARD
STANDARD
Standard storage class.
WARM
WARM
Infrequent Access storage class.
COLD
COLD
Archive storage class.
Table 13 AvailableZoneEnum
Constant
Default Value
MULTI_AZ
3az
Multi-AZ redundancy
Table 14 BucketTypeEnum
Constant
Default Value
OBJECT
OBJECT
Object buckets
PFS
POSIX
Parallel file systems
Responses
Table 15 ObsBucket
Type
statusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
bucketName
String
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
Default value:
None
owner
Owner
Explanation:
creationDate
java.util.Date
Explanation:
Time when the bucket was created.
Default value:
None
location
String
Explanation:
Restrictions:
Value range:
Default value:
storageClass
StorageClassEnum
Explanation:
Value range:
See Table 12.
Default value:
STANDARD
acl
AccessControlList
Explanation:
Value range:
Default value:
bucketTypeEnum
BucketTypeEnum
Explanation:
Type of the bucket created
Value range:
Default value:
Code Example: Creating a Bucket with Complex Configurations
This example creates a bucket and configures its ACL, storage class, and region.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.AccessControlList;
import com.obs.services.model.AvailableZoneEnum;
import com.obs.services.model.CreateBucketRequest;
import com.obs.services.model.ObsBucket;
import com.obs.services.model.StorageClassEnum;
public class CreateBucket001 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use the permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk,endPoint);
        // Use the temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            CreateBucketRequest request = new CreateBucketRequest();
            // Example bucket name
            String exampleBucket = "examplebucket";
            // Example bucket location
            String exampleLocation = "ap-southeast-1";
            request.setBucketName(exampleBucket);
            // Set the bucket ACL to Private (the default value).
            request.setAcl(AccessControlList.REST_CANNED_PRIVATE);
            // Set the bucket storage class to Standard.
            request.setBucketStorageClass(StorageClassEnum.STANDARD);
            // Set the bucket location (CN-Hong Kong is used as an example). location must match the endpoint.
            request.setLocation(exampleLocation);
            // Specify the multi-AZ redundancy for the bucket. If this parameter is not configured, a single-AZ bucket will be created.
            request.setAvailableZone(AvailableZoneEnum.MULTI_AZ);
            // Create a bucket.
            ObsBucket bucket = obsClient.createBucket(request);
            // The bucket is created.
            System.out.println("CreateBucket successfully");
            System.out.println("RequestId:"+bucket.getRequestId());
        } catch (ObsException e) {
            System.out.println("CreateBucket failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code: " + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message: " + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
        } catch (Exception e) {
            // Print other error information.
            e.printStackTrace();
Code Example: Creating a Bucket with Simple Configurations
This example creates a bucket and specifies its name and endpoint.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
public class CreateBucket002 {
        try {
            // Create a bucket.
            ObsBucket bucket = obsClient.createBucket(exampleBucket);
            System.out.println("StatusCode: " + bucket.getStatusCode());
            System.out.println("RequestId: " + bucket.getRequestId());
咨询盘古Doer
