Help Center/ Object Storage Service/ SDK Reference/ Go/ Objects (SDK for Go)/ Restoring an Archive Object (SDK for Go)
Updated on 2025-05-12 GMT+08:00
Function
To obtain the content of an object in the Archive storage class, you need to restore the object first and then you can download it. After an object is restored, a copy of the object is saved in the Standard storage class. By doing so, the object in the Archive storage class and its copy in the Standard storage class co-exist in the bucket. The copy will be automatically deleted once its retention period expires.
This API is used to restore Archive objects in a specified bucket.
Restrictions
  • To restore an Archive object, you must be the bucket owner or have the required permission (obs:object:RestoreObject in IAM or RestoreObject in a bucket policy.) For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • To prolong the validity period of the Archive data restored, you can repeatedly restore the data, but you will be billed for each restore. After a second restore, the validity period of Standard object copies will be prolonged, and you need to pay for storing these copies during the prolonged period.
Method
func (obsClient ObsClient) RestoreObject(input *RestoreObjectInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
*RestoreObjectInput
Yes
Explanation:
Input parameters for restoring an Archive object. For details, see Table 2.
Table 2 RestoreObjectInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Version ID of the Archive object to be restored
Default value:
None. If this parameter is left blank, the latest version of the object is specified.
Days
int
Yes
Explanation:
After an object is restored, a Standard copy of it is generated. This parameter specifies how long the Standard copy can be retained, that is, the validity period of the restored object.
Value range:
The value ranges from 1 to 30, in days.
Default value:
None
Tier
RestoreTierType
No
Explanation:
Retrieval speed tiers. You can select a suitable tier based on your requirements for retrieval speed.
Value range:
For details, see Table 3.
Default value:
Standard
Table 3 RestoreTierType
Constant
Default Value
RestoreTierExpedited
Expedited
Objects can be quickly restored from Archive storage within 1 to 5 minutes.
RestoreTierStandard
Standard
Objects can be restored from Archive storage within 3 to 5 hours.
Responses
Table 4 List of returned results
Type
output
*BaseModel
Explanation:
Returned results. For details, see Table 5.
err
error
Explanation:
Error messages returned by the API
Table 5 BaseModel
Type
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Code Examples
This example restores the Archive object example/objectname in bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.RestoreObjectInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the object (example/objectname in this example).
    input.Key = "example/objectname"
    // Specify the version ID of the object to be restored.
    input.VersionId = "G001117FCE89978B0000401205D5DC9A"
    // Specify how long the restored object will be retained, in days. 1 is used as an example, which can be any value from 1 to 30.
    input.Days = 1
    // Specify the restore speed (obs.RestoreTierExpedited as an example). By default, the object is restored at a standard speed.
    input.Tier = obs.RestoreTierExpedited
    // Restore the Archive object.
    output, err := obsClient.RestoreObject(input)
    if err == nil {
        fmt.Printf("Restore object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Restore object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
  • The object specified in ObsClient.RestoreObject must be in the Archive storage class. Otherwise, an error will be reported.
  • RestoreObjectInput.Days is used to specify how long (1 to 30 days) the restored object will be retained and RestoreObjectInput.Tier is used to specify how fast the object will be restored.
