Obtaining Object ACL Information (SDK for Go)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources. For more information, see ACLs.
This API returns information about the ACL of an object.
Restrictions
- To obtain an object ACL, you must be the bucket owner or have the required permission (obs:object:GetObjectAcl in IAM or GetObjectAcl in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- You can perform this operation to view the ACL of an object, as long as you have the READ_ACP permission for the object.
Method
func (obsClient ObsClient) GetObjectAcl(input *GetObjectAclInput) (output *GetObjectAclOutput, err error)
Method (with a Signed URL Used)
func (obsClient ObsClient) GetObjectAclWithSignedUrl(signedUrl string, actualSignedRequestHeaders http.Header) (output *GetObjectAclOutput, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | Yes | Explanation: Input parameters for obtaining the ACL of an object. For details, see Table 2. |
| Bucket | string | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| Key | string | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| VersionId | string | No | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9A Value range: The value must contain 32 characters. Default value: None |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 4. | |
| err | error | Explanation: Error messages returned by the API |
| StatusCode | int | Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers Default value: None |
| VersionId | string | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9A Value range: The value must contain 32 characters. Default value: None |
| Owner | Explanation: Account ID of the object owner. For details, see Table 5. Restrictions: Owner and Grants must be used together and they cannot be used with ACL. | |
| Grants | []Grant | Explanation: Grantees' permission information. For details, see Table 6. Default value: None |
| ID | string | Yes if used as a request parameter | Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? |
| Grantee | Yes if used as a request parameter | Explanation: Grantee information. For details, see Table 7. | |
| Permission | Yes if used as a request parameter | Explanation: Granted permission Value range: See Table 8. Default value: None |
| Type | Yes if used as a request parameter | Explanation: Grantee type. For details, see Table 9. | |
| ID | string | Yes if this parameter is used as a request parameter and Type is set to GranteeUser | Explanation: Account (domain) ID of the grantee Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| DisplayName | string | No if used as a request parameter | Explanation: Account name of the grantee Restrictions:
| URI | Yes if this parameter is used as a request parameter and Type is set to GranteeGroup | Explanation: Authorized user group Value range: See Table 10. Default value: None |
| Constant | Default Value | Description |
| PermissionRead | READ | Read permission |
| PermissionWrite | WRITE | Write permission |
| PermissionReadAcp | READ_ACP | Permission to read ACL configurations |
| PermissionWriteAcp | WRITE_ACP | Permission to modify ACL configurations |
| PermissionFullControl | FULL_CONTROL | Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. |
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 | package main import ( "fmt" "os" ) func main() { // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.GetObjectAclInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify an object (example/objectname as an example). input.Key = "example/objectname" // Obtain the object ACL. output, err := obsClient.GetObjectAcl(input) if err == nil { fmt.Printf("Get object(%s)'s acl successful with bucket(%s)!\n", input.Key, input.Bucket) fmt.Printf("Owner.ID:%s\n", output.Owner.ID) for index, grant := range output.Grants { fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n", index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission) } return } fmt.Printf("Get object(%s)'s acl fail with bucket(%s)!\n", input.Key, input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
